Question about Epson Office Equipment & Supplies
I want to print ONLY black & White with my Epson CX4700 scanner/printer. However it will not print if any of the color cartridges are not in place. I do not print color and yet I am having to replace them?????!!! Is there a way to print without the color in place?
  • 265 Answers
I am sorry to tell you that epson printers will not print if any of the cartridges are empty. You need to replace the empty ones before you can print again.
Posted on Jul 20, 2010
How can I set my TX 100 to print in black & white only. Light keeps flickering because it ran out of colors (don't actually need it). This is just a standby printer needed to address envelopes.
Hi!
I'm sorry to say that you won't be able to print if color cartridges ran out of ink. You need to replace the empty ink cartridges for you to be able to print again. This is how Epson printer works.
Thanks for contacting Fixya, hope this helps.
Dec 07, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Why can't I print black and white, without colored ink?
I have the same problem & have been searching for weeks for a replacement printer that will print B & W with one or more colors empty. I haven't had any luck yet - I did run across a post that said: For black and white images and photos, a blend of colors called "composite black" may be used to achieve significantly better image quality and smoother gray tones than can be accomplished with black inks alone. I'm still searching...
Jul 28, 2010 | Epson Stylus CX5000 InkJet Photo Printer
How to print using black ink only on Espon dx5050?
Did you use Epson Genuine Cartridges??
ALL…. Epson & Brother Requires Genuine Cartridges. !!!!!!!!
That sounds like your problem.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother MFC-240C All-In-One InkJet Printer. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
If you have Genuine Epson Cartridges, and have ink in ALL THE CARTRIDGES, to print in black only, Make the following settings on the control panel. SEE BELOW:
Select the number of copies.
Select l [Plain Paper].
Select the paper size you loaded.
To make a color copy, press the
x StartE[Color] button.
To make a black-and-white copy,
press the x Start D [B&W] button.
If you find this information helpful, pls rate me.
You can download the entire manual. Just click on link below. I found on the web:
http://safemanuals.com/314159.php?k=3c8871ac74c76c7b6bdba73063efb872&ID=552849&q=EPSON%20STYLUS%20DX5050
Thanks and Good Luck
and pls rate me.
Feb 16, 2010 | Epson Stylus DX5050 All-In-One InkJet...
I need to print. but one cartridge (blue) is empty how to force the printer to print in black only.
Go into the printer properties for your Epson printer when you're about to print, and for Print Quality, select "Black & White" or "Grayscale" printing.
Feb 13, 2010 | Epson Stylus Multifunction Inkjet Printer/...
My printer wont print black and white only
My Epson Stylus cx8400 uses ink so fast. I would like to turn this into a black and white printer only. The problem is, I am out of one of the color ink cartridges and it won't let me proceed until I replace it. Is there a way, in the mode it's in now, to get this to print with the black and white only? I am nearly out of ink on all color cartridges now and do not want to purchase more at the high cost they are.
Thank you!
Oct 14, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Same problem. changed all cartridges and cannot print in black. I can, however copy in black and white.
Within the Epson Printer Suite there is a tag which tells the printer to print in color , greyscale and Black Ink only.
You have to select the option and then Apply & Save it so that the software is forced to select black cartridge only
Jun 29, 2009 | Epson Stylus CX4800 All-In-One InkJet...
Printing without color?
Im sorry to inform but yes, Epson ink jet printers require all of the ink cartridges to have ink in them in order to print any color, black and white, or grayscale images. Epson printers contain a permanent print head that needs to be charged with all colors to work. Even when users are printing black text only, a small amount of color ink is used to keep the print head charged for color printing and prevent air bubbles from entering the color print nozzles which can damage the print head. Therefore, once one of the cartridges are expended, the printer signals you to replace the cartridge in order for printing to continue.
May 12, 2008 | Epson Stylus CX4200 All-In-One InkJet...
Printing in black & white when color cartridge ran out
One of the possible reason why you can't print black in white because Epson ink jet printers require all of the ink cartridges to have ink in them in order to print any color, black and white, or grayscale images. More than that Epson printers contain a permanent print head that needs to be charged with all colors to work. Even when users are printing black text only, a small amount of color ink is used to keep the print head charged for color printing and prevent air bubbles from entering the color print nozzles which can damage the print head.
Apr 15, 2008 | Epson Stylus Photo 1280 InkJet Printer
342 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
