Question about Kenmore Washing Machines
Washer flashes f35 - Kenmore Washing Machines
    Scholar:
  • 121 Answers
Here is a link to another site that has the answer you are looking for.
http://www.managemylife.com/mmh/questions/140154-what-does-error-code-f35-mean-on-my-kenmore-he3t-steam-washer
Posted on Jul 16, 2010
    Problem Solver:
  • 13 Answers
Here is a great answer in regards to the F35 error:
http://www.managemylife.com/mmh/questions/208490-what-does-f-35-mean-on-washer
    New Friend:
  • 4 Answers
I had this error a couple of times too. The first time I encountered it I got a "SUDS" error and a few minutes later F35. I replaced the pressure switch and it worked great. I recently had the exact same symptoms. I replaced the pressure switch again, no change. Ordered another switch (in case the first new one was bad) - no luck. Ended up having to replace the master control unit. I now have two of the pressure switches and am selling them on eBay at a substantial discount. Go to: eBay Link
-or-
Go to eBay and search for the part number (W10415587). Mine is listed for $50 or $65 instant buy.
Posted on Sep 13, 2013
  • John Wegerbauer
    John Wegerbauer Sep 13, 2013
    -or-
jgwhomeequip
  • 1902 Answers
SOURCE: Whirlpool duet front load washer flashes F35 shortly after start
Sud= The unit has sensed there is too many suds in the unit it will flush and pump out for 5 min and restart on its own..This is caused by too much soap use..
From the book :
SUD Code=
If too much detergent was used:
—Run the unit through a Rinse/Spin cycle.
—Run a Normal cycle without adding any detergent.
This should clear the unit of the excess detergent.
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump,
pressure switch, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Plug in washer or reconnect power.
6. Check drain pump.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic test or any
cycle.
Posted on Feb 13, 2009
  • 530 Answers
SOURCE: F35 flashing
if it is less than one year old call for service it should be covered. if not take the kick panel off and locate the tech sheet it is either in the kick panel or in the cabinet to the right. it will give you a list of error codes find out what it means and let me know thanks
Posted on Jun 25, 2009
jyackle5
  • 8197 Answers
SOURCE: the washer stops and flashes f35 and some times
F35
This typically indicates slow drain condition. Check for any clogs or kinks in the drain line. Also check that the pump is not clogged and that no pump impeller blades are missing/broken and that the impeller moves freely. Any broken/missing blades or if the impeller won't turn freely will indicate a faulty pump. Hard objects can sometimes make it to the pump and cause damage. Hope this helped and best wishes.
Good luck
Posted on Oct 05, 2009
  • 1417 Answers
SOURCE: Code F35
hello
what The F35 error code indicates that the water temperature sensor reading is out of range (below 23 degrees F or above 217 degrees F)
The f35 error shows you and indication that ice maker sensor readings are out of normal range.
then what you need to do to fix up the problem is to bale out the water from it then clean up all form of water ant dry you can see from the screen
Please before you can carry out this instruction you will have to put OFF all source of power supply .
thank you and good luck.
Posted on Jun 03, 2010
SOURCE: Sud and F35 error in my kenmore elite h5 steam
I got the f35 and suds code repeatedly and my clothes weren't washed, I ordered from Sears the analog pressure switch that regulates the water coming into the washer and the codes went away, the part is esitmately $125.00 including shipping but you have to order from the Sears parts department.If you print a diagram of the washer it is #38 in the diagram and is easy to replace. You can install it yourself and as a female I did not call service to do it.
Posted on Aug 13, 2010
Code F35
hello
Jun 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
What does F35 flashing mean? I own a Kenmmore elite front loading washer and besides it being broke down most of time it is pretty but doesn't work most of the time. This week it is flashing F35, I bought...
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.#%&#@
May 10, 2010 | Kenmore Elite 45986 Front Load Washer
Sud and f35 error in my kenmore elite h5 steam washer. The washer do not wash the cloth and flash F35.
Jan 17, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite front load washer stops and blinks F35 and locks up
f35 code indicates a pressure switch problem. Try unplugging unit for 2 minutes.Plug back in and test.If F35 reappears,check hose from tub to pressure switch
Nov 04, 2009 | Kenmore Elite 45986 Front Load Washer
The washer stops and flashes f35 and some times
F35
Good luck
Oct 05, 2009 | Kenmore Elite 45986 Front Load Washer
F35 flashing
Jun 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool washer flashes f35
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!
Jan 17, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
679 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
