Question about Apple iPod nano
Apple ipot 2gb
I forget my i pot combination lock can u help me unlock it please
  • juniordavis Apr 21, 2008
    it did not work
    just i turn on my ipot it ask me for the lock code. i wonder if u can give me a code to unlock it
    President:
  • 2,712 Answers
Hello juniordavis,
If you have an iPod nano, iPod (5G), or subsequently released iPod model, you can unlock the iPod by doing the following:
Connect your iPod to the primary computer you use it with (the first one iPod synced with), and open iTunes. When you disconnect iPod from the computer, it will no longer be locked.
If you can't unlock iPod using either the code or connecting it to the computer you use to manage its songs. . . you can restore your iPod to factory settings using iPod Updater. Please note that this will erase all data on your iPod. Afterwards, you can add your music and data back to your iPod.
If you want to change the primary computer that your iPod is associated with, do this:
1. Restore your iPod. Warning: The restore process cannot be undone. All of your songs and files will be deleted. Always make a backup of your important data.
2. Connect your iPod to the computer that you want to be the primary computer.
3. Open iTunes and synchronize.If that doesn't work work, plug in your ipod to your primary computer and enable hidden folders to bring up a new folder: iPod_Control. Inside this folder is another named Device, and inside this is a file named "_locked". Opening up this file in Notepad, you will find a bunch of symbols, presumably an encrypted password. Simply delete the file, and the iPod should be unlocked. The fix for this problem depends on what type of iPod you have. However, the following set of steps should work for any model.
1) First rename the _locked file to _unlocked. Disconnect the iPod and reset it.
2) If that did not solve the problem, delete all the text inside the aforementioned file. Save it, and then disconnect the iPod and reset it.
3) If that still did not work, delete the file and then disconnect the iPod and reset it.
Keep in mind that this is not an Apple-sanctioned guide, so use caution when trying this, and if you are not sure of what you are doing, backup any files before you alter or delete them. Hope this helps!
P.S. Before you assign a rating, please make sure that the issue is resolved. If it isn't, please post back as to what you did, and/or any other questions you may have, and I will try to assist you as best I can.
If you find that the solution I provided you led you to, or resulted in a resolution, please close the ticket with a FixYa! or Helpful rating, which would be much appreciated :)
Please do not assign an ‘Inappropriate’ or ‘Thanks for trying’ rating after the first response itself, as sometimes a bit of to and fro dialogue may be necessary before we can get to the root of the problem and find a fix.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on Apr 21, 2008
  • 2 more comments
  • Swilin Sampson
    Swilin Sampson Apr 21, 2008
    Connect the iPod to the primary computer even if it is asking for the code. You should be able to view the files on the computer. To view hidden files, go to START > RIGHT CLICK > EXPLORE > TOOLS (top left corner of screen) > FOLDER OPTIONS > VIEW TAB > HIDDEN FILES AND FOLDERS. Now mark "Show hidden files and folders" as checked. Click OK. You should be able to see the hidden folders now.
    Good Luck!
    IrishDruid
  • Swilin Sampson
    Swilin Sampson Apr 25, 2008
    Just checking to see if your issue has been resolved…If it
    has, please close this problem ticket with a Helpful or FixYa! rating. I would
    be very grateful for your gesture of appreciation.
    Should you have any further questions, please feel free to
    post them here.
    Cheers!
    IrishDruid
  • Swilin Sampson
    Swilin Sampson Apr 26, 2008
    If your issue has been resolved, please take a moment to close this
    problem ticket with a FixYa! rating. I would be very grateful for your
    post them here.
    Cheers!
    IrishDruid
  • Swilin Sampson
    Swilin Sampson Apr 29, 2008
    Just wanted to inquire if your issue is resolved, or if there is anything else
    I can assist you with...
    Cheers!
    IrishDruid
    Sergeant:
  • 221 Answers
How to unlock your ipod. You will lose all of your data.
If you can't unlock iPod using either [the code or connecting it to the computer you use to manage its songs]. . . you can restore your iPod to factory settings using iPod Updater. Please note that this will erase all data on your iPod. Afterwards, you can add your music and data back to your iPod. If you want to change the primary computer that your iPod is associated with, do this: 1. Restore your iPod. Warning: The restore process cannot be undone. All of your songs and files will be deleted. Always make a backup of your important data.
2. Connect your iPod to the computer that you want to be the primary computer. 3. Open iTunes and synchronize.
  • 3,037 Answers
Go into iPod_Control folder on your iPod, then go to device, there should be a file called lock (Or similar). Open it with notepad and it will show you the combination
Please let me know if you need and further assistance
Thank you for using Fixya and Good Luck
  • Benjamin Patri
    Benjamin Patri Apr 21, 2008
    you can try plugging it into computer and that may unlock it
    you can also try a restore which you will lose all info and need to put it back on
    How to restore iPod
    1. Ensure that you
      have an active Internet connection as new versions of iTunes and iPod
      Software may need to be downloaded to your computer.
    2. Download and install the latest version of iTunes if you do not already have it installed.
    3. Open iTunes, and then connect your iPod to your computer using the USB or FireWire cable that came with your iPod.
    4. After a few moments, your iPod will appear in the Source panel in iTunes.
    5. Select your iPod in the Source panel and you will see information about your iPod appear in the Summary tab of the main iTunes windows.
    6. Click
      the Restore button. You will be prompted with one or more restore
      options that may prompt iTunes to automatically download the latest
      iPod Software. The 4 possible restore options are:
      • Restore Option 1: Restore - Restores with same iPod Software version already on iPod.
      • Restore Option 2: Use Same Version - Restores with same iPod Software version already on iPod even though a newer version is available.
      • Restore Option 3: Use Newest Version - Restores with the latest iPod Software available.
      • Restore Option 4: Restore and Update - Restores with the latest iPod Software available.
    7. If you are using a Mac, a message will appear prompting you to enter an administrator’s name and password.
    8. A
      progress bar will appear on the computer screen indicating that the
      first stage of the restore process has started. When this stage is
      completed, iTunes will present one of two messages on screen with
      instructions specific to the iPod model you are restoring.
      • Restore Instruction 1: Disconnect iPod and connect it to iPod Power Adapter (typically applies to older iPod models).
      • Restore Instruction 2: Leave iPod connected to computer to complete restore (typically applies newer iPod models).
    9. During
      the stage 2 of the restore process, the iPod will show an Apple logo as
      well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage. Note: The progress bar may be difficult to see since the backlight on the iPod display may be off.
    10. After
      stage 2 of the restore process is complete and the iPod is connected to
      the computer, the iTunes Setup Assistant window will appear asking you
      to name your iPod and choose your syncing preferences similar to when
      you connected your iPod for the first time.
  • Benjamin Patri
    Benjamin Patri Apr 24, 2008
    Please don't forget to rate this solution as that is one of the biggest aspects of all this website works
    otherwise please let me know if you have further questions
    Thank you
Ok well my ipod nano 2gb silver got locked by my friend and forgot my volume limit code
According to Apple, if you have forgotten the code, you can unlock the IPod by doing the following:
Connect your IPod to the primary computer you use it with (the first one IPod synced with), and open iTunes.
If you can't unlock IPod using either [the code or connecting it to the computer you use to manage its songs]. . . you can restore your iPod to factory settings using iPod Updater. Please note that this will erase all data on your iPod.
If you want to change the primary computer that your IPod is associated with, do this:
1. Restore your iPod. WARNING: The restore process cannot be undone.
Apple also notes that company "representatives cannot unlock an iPod if you forget your combination. If you can't unlock your iPod and you don't have access to the primary computer, your only option is to restore the IPod, which will erase all music and data."
Please rate me
Sep 10, 2010 | Apple iPod nano
I can't remember the code i was just wonder i have a 2gb ipod apple and my son locked my ipod and iforgot the code so what do i do
IPod synced with), and open iTunes. When you disconnect iPod from the
to your iPod.
with, do this:
computer.
Good Luck...I hope this helps,
Please rate me...Thanks
May 09, 2010 | Apple iPod nano
My apple Ipod (white 30GB) is locked and I need assistance in getting it unlocked please help
Ipod Lock
You can unlock iPod in one of two ways: 1...Enter the combination on iPod using the same controls you used to set the combination. If you do not enter the correct combination, the digits onscreen flash red. When you enter the combination correctly, iPod will unlock and return you to the last viewed screen. 2...Connect iPod to the primary computer you use it with (the first one iPod synced with), and open iTunes. When you disconnect iPod from the computer, it will no longer be locked. If you can’t unlock iPod using either of these methods, you can restore your iPod to factory settings. Please note that this will erase all data on your iPod. Afterwards, you can add your music and data back to iPod. If you want to change the primary computer that your iPod is associated with, do this: 1. Restore your iPod. Warning: The restore process cannot be undone. All of your songs and files will be deleted. Always make a backup of your important data. 2. Connect your iPod to the computer that you want to be the primary computer. 3. Open iTunes and synchronize.
Important: Apple representatives cannot unlock an iPod if you forget your combination. If you can’t unlock your iPod and you don’t have access to the primary computer, your only option is to restore the iPod, which will erase all music and data.
Good Luck, I hope this helps Please rate me, Thanks
Dec 30, 2009 | Apple iPod MP3 Player
I for got my pasword to my i pod touch an its locked how do i unlock it?
Ipod Lock
Nov 19, 2009 | Apple Audio Players & Recorders
I can`t get the padlock symbol of my ipod nano 4g driving me nuts please help
Ipod Lock
Good Luck,
I hope this helps
Nov 11, 2009 | Apple Audio Players & Recorders
My five year old has a apple ipod nano and now it's lock how do I unlock it
Ipod Lock
Good Luck,
I hope this helps
Nov 11, 2009 | Apple iPod MA446LL/A MP3 Player
4 gb nano locked and i forgot the combination
Ipod Lock
Good Luck,
I hope this helps
Nov 10, 2009 | Apple iPod nano
How to unlock a 2gb ipod by apple
that is not a problem. If you have forgotten you ipod password to unlock just follow these steps. According to Apple, if you have forgotten the code, you can unlock the IPod by doing the following: Connect your IPod to the primary computer you use it with (the first one IPod synced with), and open iTunes. When you disconnect iPod from the computer, it will no longer be locked. If you can't unlock IPod using either [the code or connecting it to the computer you use to manage its songs]. . . you can restore your iPod to factory settings using iPod Updater. Please note that this will erase all data on your iPod. Afterwards, you can add your music and data back to your iPod. If you want to change the primary computer that your IPod is associated with, do this: 1. Restore your iPod. WARNING: The restore process cannot be undone. All of your songs and files will be deleted. Always make a backup of your important data. 2. Connect your iPod to the computer that you want to be the primary computer. 3. Open iTunes and synchronize. Apple also notes that company "representatives cannot unlock an iPod if you forget your combination. If you can't unlock your iPod and you don't have access to the primary computer, your only option is to restore the IPod, which will erase all music and data." If you need further assistance please feel free to follow up with a comment and i will be here to assist you. If this assisted you please feel free to rate the solution. thanks and have a great day.
Oct 05, 2009 | Apple iPod nano
Apple ipod 30G
my ipot hhas been locked. while turn it on. just, a massege apears www.apple.com/support/ipot
could you kindly help me to unlock it send me the code
Best regards
S,A
Aug 25, 2008 | Apple iPod 4th Generation MP3 Player
Probelm with my Apple Ipot
I get a similar error and one thing you can try is opening the ipod (taking off the silver cover) and closing it back up.
This is only temporary and I'm not sure what's causing the actual error to come up, but it could be the hard drive failing.
Nov 04, 2007 | Apple Audio Players & Recorders
Apple iPod nano Logo
26 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
