Question about Creative Labs Sound Blaster Live! 5.1 Sound Card
I have f&d 5.1 speaker model no-A-60A.HOW I use to built in fm in this speaker?
Trying to hook up speakers to Pyle Pro PD1000 stereo receiver w/built-in DVD/CD player. I believe that I have speaker wires hooked up correctly but when I play CD no sound. I can actually hearing sounds...
I went thru user manual..there is no special way of wiring speakers..
pls check carefully the speaker connections again and the "speaker selector" too..
what about "MUTE" button ? it should be "OFF" ...
and try to test it on FM radio first ..
just in case ,if you need the soft USER MANUAL pls visit the URL below..
1000 Watt AM-FM Receiver w/ Built-in DVD/MP3/USB
http://www.pyleaudio.com/sku/PD1000A/1000-Watt-AM-FM-Receiver-w-Built-in-DVDMP3USB
Jul 10, 2011 | Audio Players & Recorders
Wiring help for realistic 5 band equalizer cat.no.12-1963 don't know year or model of unit it has no wiring label on it. has 3 gray wires, 3white wires,3 green wires, one black wire,one brown wire....
the 5 thinner cables goes to positive lead of each speaker from the radio (input to amp) the red one to battery.You will not use the negative led for the speakers from the radio. The remaining coarse ones goes to the speakers (each pair same color to a speaker) and the red one feed radio positive led. Black is ground.
Jul 03, 2011 | Car Audio & Video
I have a Sony Amplifier [model TA-AX380] and other components of CD player [model DCP-C40], AM/FM Tuner [model ST-JX380], FM Stereo/FM-AM Receiver [model STR-AV570X], and Stereo Cassette Deck [model...
http://www.servicemanuals.net/ServiceManual/SONY/TAAX380/148547/detail.aspx
http://www.hifiengine.com/manuals/sony/str-av570x.shtml
Hi above are links for manuals, these may help..
When one wires up anything it is all usually color to color output to input... usually RED & WHITE stereo audio.
Now we would start with our Tuner this the CD player, & Cassette deck, will wire into the Amp's INPUTs , red - red & white - white, these go into the Stereo INPUTs on the AMP... 1, 2 & 3 and be selected via the input selector on the AMP.
Now after all these in's and out's are wired we need to wire our speakers, this too is simple, locate the outputs on the Amp, and wire accordingly, Plus to Plus and Negative to Negative... each speaker has two wires a Plus, + & a Negative -
All will/should be clearly marked and it will be easy to do. You will need patch leads, one set each for each unit, these will be a pair of cables, usually Red & White with RCA jacks on each end, as related these go color to color from the RCA OUTPUTs Sockets, of the signal suppliers, ie: Tuner, FM stereo & Cassette deck... these ALL will wire into the Main Amplifiers INPUTS, usually at rear of unit, and clearly marked, after this is all done, then as related again now connect the Speakers, again the OUTPUT on the Amp will be clearly marked, as output and + & -, + & - (two sets), one for each channel.
Now each INPUT is selected ON the AMP, and it's output will then be directed to the speakers attached to the Amp..... Just wire and test one at a time, and i am sure you will prevail.
Hope this helps.
Jun 20, 2011 | Sony Audio Players & Recorders
I have 8 gauge power wire with 60a fuse (reccomended) but when i turn the power on, the light on the amp turns on, and then fades while blinking, which means it goes into safe mode. Could the 60a fuse...
Hi, the safe mode indicates the speaker impedance is too low. It doesn't reflect the power to the amp. Check the resistance of the speaker and wires with an ohmmeter and verify it is 2 ohms or greater. Can you tell me what speaker you have?
May 08, 2011 | Alpine MRP-M500 Car Audio Amplifier
Cidco caller id model SA-60A-20 how do we change the language on it
I was able to reset my GTE Cidco SA-60A-20 caller ID unit with the following procedure:
1. Remove the battery.
2. Wait several minutes after the display fades away.
3. While holding down the "Delete" key, reinsert the battery.
4. Release the "Delete" key.
5. The unit will come up showing a boot process and end with a screen allowing you to choose the English or Spanish language.
Sep 21, 2010 | Cell Phones
Hi my name is james im having trouble with my audio coming out the speakers what should i do
1. Do you have power to the unit. I assume yes.
2. Ensure the fader and balance is set to neutral to ensure you have output going to all the speakers.
3. Ensure the speakers are connected.
4. Ensure the speakers are not out of phase, if they are they will cancel each other out, and sound muted
5. Always test new model head units with a cd. not fm radio. Using fm radio on some head units will mute the sound if the station is not coming in clear enough.
6. Set your volume up a little, like on 15 or 20 (using the digital 40 level radios) (halfway in plain language)
7. Ensure the mute isnt on
8. If running through and amplifer, ensure the power, ground, remote, gain and phase are all correct.
9. Ensure rca input is going into the correct place on the amp
10. Ensure speaker output is actually connected to speakers.
hope this helps
Aug 08, 2010 | Pioneer AVIC-D3 Car DVD Player
CD DISC IS NOT SPINNING
Check the cd drawer sometimes the position switch is not detecting the drawer completely closed.
It could be an obstructing object stuck behind the drawer door who prevent the drawer to close completely.
Spider Guy
Jan 11, 2010 | Audio Players & Recorders
I need a diagram of the underhood fuse block for my 2002 ford explorer. I don't have an owners manual.
Fuse/Relay Location*Fuse Amp Rating* Description
1 60A** PJB 2 30A** BSM 3 20A** Not used (Spare)
4 30A** Rear defrost 5 40A** ABS (pump)
6 60A** Delayed accessory circuit breaker
7 20A** Power point #2 8 — Not used 9 20A** Power point #1
10 30A** ABS module (valves) 11 40A** PTEC
12 50A** Ignition relay/Starter relay
13 40A** Trailer tow battery, Trailer tow turn signals
14 10A* Foglamps 15 15A* Memory (KAPWR)
16 15A* Headlamp switch 17 20A* 4x4 (v-batt 2)
18 20A* 4x4 (v-batt 1) 19 20A** High beam relay
20 30A** Electric brake 21 30A** Front wiper motor
22 20A** Autolamp; Low beam 23 30A** Ignition switch
24 20A* Rear Fog Lamps 25 – Not used
26 15A* Fuel pump 27 20A* Trailer tow lamps
28 20A* Horn relay 29 60A** PJB 30 20A** Rear wiper motor
31 — Not used 32 — Not used 33 30A** Auxiliary blower motor 34 30A** Power seats, Adjustable pedals
35 20A** Rear power point 36 40A** Blower motor
37 15A* A/C clutch relay/Transmission
Nov 15, 2009 | 2002 Ford Explorer
Tremendous Rumble when using my new turntable
its more like your turntable needs to be isolated from surrounding interference? try putting foam or dense rubber under the feet and make sure its not anywhere near a speaker as this wil cause immense rumble problems? it may be your carridge on this new deck is way more sensitive than your previos set up and therefore needs isolation for the best results?
Apr 21, 2009 | Sony PS-LX250H Turntable
FM Radio
The RDS (Radio Data System) FM radio is built-in and offers instant and easy access to FM radio channels in your phone. A handsfree or portable speaker set must be attached to the phone, as the wire works as an antenna for the radio. You can then choose to listen to the radio via the handsfree or the portable speakers, or through the speakers in the phone.
Jul 11, 2008 | Sony Ericsson K608i Cellular Phone
Creative Labs Sound Blaster Live! 5.1 Sound Card Logo
312 people viewed this question
Top Creative Labs Computers & Internet Experts
micky dee
Shawn DuRee
kevinmacleod
Level 1 Expert
Are you a Creative Labs Computer and Internet Expert? Answer questions, earn points and help others
