Question about GE Profile JTP56 Electric Double Oven
Replace the oven door hinge - GE Profile JTP56 Electric Double Oven
    Problem Solver:
  • 13 Answers
Here's a link with the info on how to replace a hinge on a similar model--schematics for both are virtually identical--this link contains some images that should help along the way:
http://www.managemylife.com/mmh/questions/164631-how-do-i-change-the-oven-hinge-on-my-ge-jb960bb2bb
Posted on Jul 16, 2010
How to remove oven door
hi deirde.
try this or go to the link at the bottom.
To replace oven door(s):
  1. Grasp door at each side.
  2. Align slots in the door with the hinge arms on the range.
  3. Slide the door down onto the hinge arms until the door is completely seated on the hinges.
  4. Push down on the top corners of the door to completely seat door on hinges.
How to remove and replace the oven door - KitchenAid Product Help
producthelp.kitchenaid.com/...Ovens.../Oven.../How_to_remove_and_replace_the_oven...
How to remove oven door Google Search
Nov 03, 2017 | Ovens
How to remove door hinge technica oven t948 please
This should be fairly easy. It does depend what model of hinge you have. On the bottom of the hinge there is an arm with a saddle lock pin - this pulls up to give space to lift the fitting off the oven frame - lift these on both hinges. On the face of the hinge where it sits on the door there should be a round screw - with the door fully open using a flat blade screwdriver turn this 45 degrees clockwise - this locks the top bar that goes to the frame of the oven.
Hold the door and with a bit of wiggling the whole door should lift off. The hinges are now easily removed by disassembling the door. Replace both hinges with new and reverse the process to replace. You do not need to remove or disassemble any part of the actual oven.
May 30, 2014 | Ovens
FB 510 Cuisinair built in oven - how to replace door hinges and where can new hinges be obtained
Assume you have lifted the door off the oven. You may have to dismantle the door to replace the hinges. Take a hinge to an electrical appliance parts supplier to get new ones or ask stockist of this brand.
Jan 03, 2011 | Zanussi Ovens
Door to oven does not close completely - how do I access the door hinge to check or replace it?
Open oven door. Flip metal holder down at hinge to lock hinge. Lift door with hinge attached up slightly and off oven. Reverse to re-install door, making sure notch at bottom of hinge is hooked in frame of oven properly.
Jan 02, 2011 | GE JTP45 Electric Double Oven
GE Oven door lock 'engaged' while door was open and door will not close - how do I release the lock?
If your oven door has gotten bent or warped (maybe you rested something heavy on it...), you need to remove the door, disassemble it, and straighten it. You can lift most oven doors off of their hinges by opening the door several inches to its first "stop," and lifting the entire door straight up. If the hinges have become worn, damaged, or bent, you probably need to replace them. We recommend replacing both hinges at the same time, to prevent uneven wear of the undamaged hinge.
Dec 06, 2010 | GE JTP27 Electric Double Oven
Oven door not closing properly
If it is a drop down door with hinges on the bootom of the oven door, then it is likely to be weak door hinge springs, the usual solution is to replace both hinges.
If it is a swing open door, then the problem is related to a worn or broken door catch, or worn striker pin.
Apr 13, 2010 | Ovens
Removing the door from a thermador oven CT130
Usually you will find a hole in each hinge to hold the hinge open when removing the door.
It is impossible to fight the door hinge springs and remove or install the door.
One opens the door and puts a nail through the hole to keep the hinge open for each hinge.
Feb 20, 2010 | Thermador Ovens
KEBS208DSS6 doors wont close compleat
Place a hammer handle between the door and the frame at the hinge location.
Carefully apply pressure on the door to push the door closed.
This will often re-set range door hinges.
Mar 08, 2009 | KitchenAid KEBC208 Electric Double Oven
Belling oven door not closing fully
Hi. Yes, you will need to replace hinges, and possibly the hinge guides located inside the cookere.
Oct 17, 2008 | Belling XOU252 Electric Single Oven
Main oven door will not close properly. Is there any adjustment for it.
This comment applies to most electric ovens that have drop down doors with hinges at the bottom.
The hinges are not adjustable, and in every case the problem is caused by one or both hinge springs being weak.
The only solution, is to replace both oven door hinges together.
May 06, 2008 | Neff U1421 Double circotherm Electric Oven
GE Profile JTP56 Electric Double Oven Logo
348 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
