When TV is turned on the picture will go blue,within a few minutes. There is a very faint image of the program being broadcast.
  • gherman7374 Jul 16, 2010
    I have a SONY rear projection TV. Model # KP-46wt500. When the TV is first turned on the picture is good. A few minutes later the picture will go blue. If you turn the TV off and then on again, the picture is back but fades to blue again but more quickly. When the blue screen appears there is still a very faint image of the program being broadcast.
  • 10,594 Answers
Model and brand info will help me to diagnose your tv problem.
Thanks.
Posted on Jul 16, 2010
  • 5 more comments
    SONY rear projection model KP-46WT500
  • Shahid Electronics
    Shahid Electronics Jul 16, 2010
    Symptom shows its problem of blue picture tube, you will notice few thin retrace lines across the screen when KP-46WT500 tv picture turns to blue.
    Blue picture tube need to be replaced as this tv has 3 picture tubes, red, green, blue to project color picture on front screen.
    Picture tube replacement in rear projection tv is job of an experienced tv repairman because tv needs convergence adjustment after picture tube replacement.
    Let me know if you have additional question.
    Thanks.
    OK, no problem.
    I'm Sony tv tech and know this problem.
    I took the rear panel off the TV and watched the lights as they faded, the blue was still on, the green one went really dim. I would think the green one should be replaced.
    No, thats not the case, blue picture got internal problem, we call it heater-cathode shorted that cause blue picture tube to start electron emission on full speed (means more bright) and becomes out of control.
    Technical name of this problem is HK Touch of CRT.
    TV repairman/ technician would understand that technical term.
    Solution is to replace blue picture tube that would cost you much, like $350 if blue picture is available somewhere.
    OK ! Now I understand Thank you very much Gerald
    No problem.
    Thanks.
  • 4,889 Answers
I suppose this is a DLP projection tv? If it is anything else then let me know and I will tell you what the possibilities are.
  • 1 more comment
  • eagle338
    eagle338 Jul 16, 2010
    This is definitely a problem related to bad caps most likely on the blue CRT board. Since the board is not expensive I suggest that you replace the entire board. Costs about 25-50$+ labor
    I really dont think it is DLP the model number is KP-46WT500
  • eagle338
    Yes I know. It is a CRT projection tv. Thats why I mentioned CRT board. DLP tvs dont have CRT boards!
Only able to receive small pictures on certain channels broadcasting some older programs.adverts and most programs are ok,but selected few are not?
Most television advertising and broadcasts today are in 16:9 aspect ratio. This is why they seem alright. However, older TV shows will still show up in their native 4:3 ratio since they were recorded that way. You may be able to force them to 16:9 ratio, but although they will now be full screen, their images will be distorted in the horizontal plane. Most TVs are designed to auto-adjust to the 4:3 resolution to prevent this distortion.
Jan 25, 2015 | Humax Televison & Video
Can the lamp be replaced for a Polaroid TLX03210B
You likely have a LCD set there which may likely use a back light inside to light the image, get the room as dark as you can and with a flashlight illuminate the screen from a angle, with set on if you can see the faint image on the screen of the program you have a Backlight issue'
1. Voltage not there or not being switched on for backlight.
2. Actual back light bad.
If the image can be seen with a flashlight one of the above is the issue and your "picture will appear very faintly" also suggests this.
Dec 18, 2012 | Polaroid Televison & Video
My 47LG50 is just over 2 years old, about 30 days ago I started to lose the video/picture At first it happeded every once in a while, now it is every 5-8 minutes. I can turn it off and turn back on and it...
This problems it could be those 2 long LCD inverter boards are dead,so it is not giving ur tv LCD screen panel the backlight to produce a picture or the tv Tuner signal board itself is the problems it dead.That the board,that take in the incomming broadcasting signal wire ur case the HDMI or Component cables.Take out the incomming broadcasting signal to the tv,turn on the tv,now tv have no picture,it should have a loud white static picture noises for good more 5-8 mins,than problems it not the tv Tuner signal board.Than it is those 2 long LCD inverter boards are dead.Tries websites like Shopjimmy.com,Ebay.com to buy refurbishes 2 long inverter boards or the tv Tuner signal board for the replacement.
Mar 25, 2011 | LG 47LG50 47 in. LCD HDTV
I have a Sony Bravia KDL-22BX300. When I turn it on, within the first few minutes I get this loud blast of static-y noise & the picture goes all snowy. It'll last approximately 10 seconds, then the...
This problems it is the tv Tuner signal board itself it is dying,just not dead yet.This problems the tv Tuner signal board is slowly dying,when it is completely dead.Ur tv will have only LED power light indication.No broadcasting tv signal at all.The tv Tuner signal board,that the board,where the incomming broadcasting signal cable plug into it.U can wait until it completely dead or like to change it now.Tries websites like Shopjimmy.com,Ebay.com to buy a tv Tuner signal board for the replacement.
Jan 18, 2011 | Sony BRAVIA KDL-40S2010 40 in. LCD...
New Blue CRT installed now TV won't stay on
sounds like the HV lead isnt sealed properly either at the CRT or the Splitter I would have him come back and recheck his connections
Jun 13, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Picture and screen
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Jan 02, 2008 | Sony KP-51HW40 51" Rear Projection...
TV quits after a few minutes-get a blue screen, no picture and no audio
My best recommendation is to pull the back off it and blow the dust out. Dust is electrostatically attraced to the components inside and acts like a blanket. This causes overheating. Remember to leave your tv unplugged for at least an hour before taking the back off as the CRT (picture tube) will store a charge which can kill you.
Bill
Dec 30, 2007 | RCA T19408 19 in. TV/VCR Combo
Sony KP-51HW40 51 in. Rear Projection turns blue
Hello......
First reduse the G2 voltage for the blue c.r.t,and watch if the unit works for longer period (offcource blue colour will be not present).After reducing G2 voltage to blue c.r.t still behaves the same than c.r.t is faulty and you have to replace.
Pls count the red led blinking when it goes off,incase it goes to std by mode.
Gopali
Dec 14, 2007 | Sony KP-51HW40 51" Rear Projection...
Intermintent picture
Check the horizontal output transistor this could be damage and causing the problem.another thing is pilot light that cause the screen to light up.since this is a projection t.v.it does not garry a tube.
Jan 19, 2007 | Mitsubishi VS-50501 50" Rear Projection...
Tv has sound but no image
When you say no image this could mean anything from, snow picture, blank screen, blue screen. Also, dry joints on the PCB can cause such a problem. More especially on the picture tube board.
Oct 26, 2006 | Zenith DVB312 DVD Player
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
Electro Med Services...
