Question about Samsung Touch of Color LN52A650 52 in. LCD HDTV
Ln52a650 line across screen about 1/8 wide a little less on right side also if dvd is played has line and the Wii
  • Samsung Master
  • 610 Answers
You may have a defective panel, main board or t/con board. If unit is less than a year old, it is still covered under samsungs' warranty. You can call 1-800-samsung to find out if your unit is still covered.
Posted on Jul 16, 2010
I have a dark line on the right side of the screen
If there is a dark line with two sources such as a dvd player, and a game system, or a cable box, then the tv will need to be repaired. If not from two sources then the issue is with the only source causing the black line.
May 05, 2010 | RCA Scenium D40W20 40" Rear Projection...
Lines across my tv where the picture is reversed
You have bad capacitors in the vertical deflection. And you will have to resolder the vertical IC as well. Replace the caps in the area of the vertical IC. Find a TV tech or hobbiest to do this!
Apr 14, 2010 | iLO IWT3206 TV
I have the sony portable dvd player and the screen has went blank and it says ''line in'' and won't play any disk?
on the side there is a switch that says line in line out it enables you to connect the player to a tv or projector or to do the opposite and play say a wii or x box with out a tv right now it is trying to accept a gaming system. switch it to line out and you should be good
Aug 09, 2009 | Sony DVP-FX820 DVD Player
Faded section of screen
Is it an LCD or plasma monitor? If it's an LCD, it's possible that one of the fluorescent backlight tubes is bad. In some early ones, this is bonded to the LCD panel so it's not replaceable. Maybe it's under warranty?
Jul 18, 2009 | Panasonic TH-42PX500U 42 in. Plasma...
Screen display is flipped
I simply turned my television off while emailing fixya and reading the user's manual. The television was turned off for about ten minutes. I think what happened was that the dvd skipped while ejecting and caused the screen to flip....who knows, I'm just happy it works properly again because I love to watch movies.
Thanks anyway,
Brett
May 17, 2009 | Toshiba LCDTV/DVD Player 19HLV87
Panasonic DMR-EZ47V Fuzzy horizontal line in VHS mode
Dirty heads or the recording was from a different brand VCR and the Panasonic cant get the right tracking. Try manual tracking just a little in either direction to you get the right one.
May 18, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
WT-46809 Inputs show lines across screen
1. THE SYMPTOM IS BRIGHTER IMAGE ON THE SIDES AND DARKER IN THE MIDDLE. THE PROBLEM CAN BE WITH RED BLUE AND/OR GREEN. CHECK FOR PROPER CONNECTIONS TO THE "DAG COATING AND CONNECTIONS TO PIN 9 ON THE SOCKET OF THE AFFECTED CRT. MAKE SURE THESE GROUND POINTS ARE COMMON WITH CHASSIS GROUND.
Apr 25, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Washed out colours and thin red lines across the screen
your problem is in red video circuit. please get it done with skilled tech.
Oct 05, 2007 | Panasonic CT-32SL15 32" TV
Multiple vertical colored lines on DVD player screen
check this out http://www.techlore.com/forum/thread/12629/
Sep 26, 2006 | Audiovox D2010 Portable DVD Player with...
Samsung Touch of Color LN52A650 52 in. LCD HDTV Logo
188 people viewed this question
Jerry Greenberg
Jerry Greenberg
