Question about Goldstar R1404 Air Conditioner
The A/C runs for about 1 - 2 mins. and then the circuit breaker kicks in. There seems to be a short. Could this be the problem or is it something else?
    Scholar:
  • 121 Answers
It is more likely to be dirty. If the unit had a short it probably wouldn't start or it would trip instantly. You need to pull the internal unit from the housing, take it outside and wash it down with a spray hose. Let it dry in the sun completely before reinstalling. NOTE: Remove any electronic control panels prior to cleaning. IF you get these wet, they may not work properly after drying. If that doesn't fix it, it could be low on freon. You can get them serviced but it would probably be less expensive to just replace the unit, unless you have a friend that has the equipment to repair widow unit.
Posted on Jul 16, 2010
Circuit breaker keeps kicking off. nothing is plugged in and it still kicks off. i have changed the 15amp breaker and it does the same thing
It sounds like you have a power wire going to ground, which it should not. Please have a qualified person help you with this.
Mar 15, 2017 | Heating & Cooling
Sanyo repairs built-in transformer
Most refrigerators draw up to 12 amps on a lock-rotor.. meaning it reached temperature, and turned "off" there needs to be 5 or 10 mins, before the compressor can restart due to hi-pressure inside the condenser . usually you will hear the fan(s) come on, it makes a "click" sound trying to start- that's called a Lock rotor. when People seem to have problems asking about how many Amps. it's because they trip their house breaker. I will assume and respond under that pretext - 1) 15 amps minimum on a dedicated line, means only that item. 2) house breakers weaken over time and will trip - here's how you can tell the difference If your breaker trips the instant you plug in your refrigerator.. 90% probable problem with refrigerator, a short somewhere is causing the breaker to open the circuit . if you plug in, and Refrigs runs for any length of time, and then the breaker trips. The refrigerator is combing it's consumption of Amps, contributing them with something else so together they exceed the rated voltage or you need a new breaker.
Nov 29, 2013 | Refrigerators
BREAKER TRIP AFTER 8 MINS .WORKED ONLY ON PERMANENT PRESS FOR A YR NORMAL ..WOULD TRIP BREAKER ON LOW AND HEAVY SETTING AFTER 5 MINS CYCLE.
This problem might be in your house electrical system rather than the dryer but it will take some troubleshooting to figure it out.
1. First make sure that you are connected to a 30 amp circuit breaker. If not then that is the problem!
2. Use a clamp on amp meter to see what the dryer is drawing from your electrical panel before it trips. If it is below the rating of the 30 amp circuit breaker when it trips, then your circuit breaker is defective.
3. If the dryer is drawing more than 30 amps it is in your machine and you will need to troubshoot that. Since you stated the times - is it always the same and does not vary? Then you have to figure out what you dryer is doing at the 8 minute mark and each machine is a little different. Soem machines go into a tumble air only mode for the first few minutes before kicking on the heating elecment. If yours is that was then it is the heating element, thermostat or something to do with the heating circuit.
Jun 20, 2011 | Dryers
My refrigator/freezer is kicking off the circuit breaker each time I plug it in
Two obvious possibilites. One, it may not be the only unit on that circuit. If you have a 15 or 20 amp breaker, and have more than one unit like this, you are pulling too many amps for the breaker.That happens frequently. The other possibility is a dead short somewhere in the unit. Try plugging it in to a different outlet that you know has nothing else on that circuit. If it comes on and runs, You need to run a didicated circuit for this freezer only. A dead short in the machine will kick any outlet that it is plugged into. You will have to isolate each circuit in the freezer to find which one is grounded out.
Sep 15, 2010 | True T-23DT Bottom Freezer Refrigerator
Dyer starts but after 1 to 3 mins the circut breaker kicks off
If it is the correct size breaker for the dryer, the circuit breaker may be weak and in need of replacement.
Mar 29, 2009 | GE DBSR453EBWW Electric Dryer
Dryer won't run right
The motor in your unit has to be replaced. The centrifical sw can't seem to keep the motor going. The shaft may spin freely, but once power is present the shaft locks up therefore your over amping the motor and it then trips the breaker. Since you already had the unit apart you will do fine replacing the motor. Good luck
dmparenti
Dec 29, 2008 | Maytag PYE2300AY Electric Dryer
Estate dryer kicks off circuit
you can check where the cord is connected to the drier did you use the cord off your old drier see if the cord is tight at the back of the drier and the center terminal of the cord should be on the center of the terminal block and why did you buy a new drier hold my rating till were done please
Jan 30, 2008 | Estate TEDX640JQ Electric Dryer
Kicks off circuit breaker
make sure your breaker is high in amps, at less 50 amp breaker
Ruud heat pump outside unit trips circuit breaker
Check your wiring between the contactor and compressor for a short to ground, or check the compressor windings for short to ground.
With the Tstat off, the contactor should be open so the only way for the compressor to be trying to do anything is if the 110 volts from the unbroken side are traveling through the compressor to ground. Since 110v is not enough to run it, the overload is kicking it out, cooling off, and repeating the cycle. When you kick on the Tstat, the contactor is supplying voltage directly to ground without going through the resistence of the compressor windings and kicking the breaker.
Post back and let me know what you find.
Nov 20, 2007 | Ruud Central System Air Conditioner
Goldstar R1404 Air Conditioner Logo
Top Goldstar Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Dan Webster
Dan Webster
Are you a Goldstar Heating and Cooling Expert? Answer questions, earn points and help others
