Question about Sanyo EM-C1800 Microwave Oven
My new Sanyo comb oven stops and displays E 03 What does this mean?
Model em-p672w. What caused it to stop working?
Sanyo EM-P672W Microwave Oven Repair Questions ...
www.fixya.com > Forum > Microwave Ovens > Sanyo
Recent Sanyo EM-P672W Microwave Oven questions, problems & answers. ... Mysanyo super shower microwave wave stopped working it shows on the display to press clock key but ... What would cause my Sanyo Microwave to not heat up?
Sanyo EM-P672W Microwave Oven Sanyo microwave fuse ...
Nov 19, 2015 | Sanyo Microwave Microwave Oven
How do I set the clock on my sanyo microwave
Usually, if there is a Time/Clock button on the panel, pushing it once blanks the display for timer input while pushing it twice makes the colon blink (the two dots) meaning it's expecting the time input. So, for 12:37 you would push Time-Time-1-2-3-7-Time.
Apr 26, 2015 | Sanyo Microwave Ovens
Code e on only two of the right hand zones on siemens induction hob
Hello.
These codes mean that the oven's electronic control hasdetected a condition it needs to check which mean error. When you see a code,follow these steps to solve the problem:
  • Press "Stop/Clear" to clear the display and stop the beeping.
  • Reprogram the oven.
  • If the code still displays, turn off the power to the oven at your breaker box and wait five minutes before turning it back on.
Thanks.
Sep 07, 2011 | Microwave Ovens
New sanyo microwave, steam or smoke coming out when cooking from 1 minute
Steam is OK as it means whatever is in there is boiling furiously, it may need turning off at that point!
Smoke though means it has gone too far. Check the cooking times used and the recommended cooking times on the packet along with the adjustment for the power of your oven.
Jan 13, 2011 | Sanyo Microwave Microwave Oven
Sanyo microwave not heating. Light on at top rigt hand corner
Unfortunately when the microwave stops heating and everything else still works, this means your magnetron shorted out. The magnetron is the part that heats the food and also is the most expensive part. It is almost cheaper to buy a new microwave and taking into account the hassle of replacing the magnetron, I recommend just getting a new microwave. Let me know if you need anything else.
Benjamin
Nov 04, 2010 | Sanyo Microwave Ovens
My Sanyo EM-D975 starts and then stops after 3 seconds with E01 on the display, i pressume this means error 1, can anyone help
I would first suggest that you check the door switches and switch holders. See this file.
If it is equipped with an inverter, that may be the trouble.
You can locate Sanyo owner's manuals, part distributors and authorized servicers here.
Good luck.
Jan 30, 2010 | Sanyo Microwave Microwave Oven
9Fp and microwave cuts off
F-9 means the inverter board has failed. A bad magnatron can also cause this code. Recommend replace the Mag. and inverter board.
Feb 27, 2009 | Kenmore 62622 Microwave Oven
My SANYO EM-D9550 display as stop working
You could have a failed keypad or control panel assembly, You can try the hard reeset the previous tech mentioned or you can try re-seating the ribbon cable on the control board. sometime thet get dirty not allowing them to work.
Nov 21, 2008 | GE Advantium 120 Convection/Microwave Oven
Nothin works on my key pad
Here are lock / unlock schemes for three recent Sanyo models:
- Press and hold Stop/Cancel for 3 seconds
- Press and hold Stop/Reset for 3 seconds or so
- Press Stop/Clear five times
Hopefully one of those will work.
If none of these work for you, contact Sanyo Service Customer Service.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 10, 2008 | Sanyo EM-V5405SW 1200 Watts Microwave Oven
Sanyo EM-C1800 Microwave Oven Logo
20 people viewed this question
Top Sanyo Microwave Ovens Experts
William Miller
William Miller
robert landry
Steve Allison
Steve Allison
Are you a Sanyo Microwave Oven Expert? Answer questions, earn points and help others
