Attention eagle338 need more info on the crt boards for D61W20 RCA.
  • martysguns Jul 16, 2010
    Thank you so much for all your help.
  • 4,889 Answers
Hi I have already replied your other post.
Posted on Jul 16, 2010
Testimonial: "Thanks for your help."
  • 1 more comment
    On tv repair world they have Red Green and Blue crt bords listed. Should I get all three or just the Red and Green since the screen is showing Blue?
  • eagle338
    eagle338 Jul 16, 2010
    Just the blue CRT should do the trick. I believe that is the one that is shorted.
  • eagle338
    You are welcome! Thanks for using Fixya!
Rca D61W20 52 in power supply
If the deflection power board was changed with a known good one . then the HV splitter block would be suspect then followed by a bad CRT next. I would try removing one CRT drive board at a time by letting it hang free wires attached then trying to power up the set if it doesnt power up then try one of the other crt drive boards after reattaching the one you previously unhooked. If the set powers up if any certain CRT board is removed you will know the problem is that CRT. If it doesnt power up then its most likely the HV splitter. You can get replacement CRTs, boards and HV splitters that have warranties from www.tvrepairworld.com
Jan 22, 2012 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have an RCA D61W20 and it will not go on at all... Do I just have to change out power supply? How complicated is it? Can I get new power supply locally?
If the light blinks three times slowly it usually the deflection board. You can get a replacement deflection board from www.tvrepairworld.com which has installation instructions.
Nov 10, 2010 | RCA D61W20 61" Rear Projection Television
The tv i have is a RCA D61W20 and it will not come on . the power light goes on and off three times and nothing
Problem with main deflection board,bad electrolytic capacitors/Hi voltage circuit has bad connections,common to those RCA tv's.
Mar 22, 2010 | RCA D61W20 61" Rear Projection Television
D61W20 RCA, Red Screen and then shuts down
sounds like the Red CRT (tube) has shorted. You can test by removing the RED crt circuit from the end of the RED tube and making sure it isnt touching anything try powering up the set. If it comes on and doesnt shut down the red tube is the problem and will need to be replaced . expensive part to replace the Red XRT will be over 300 and at least 2-3 hundred to have it installed unless you know someone who can replace it for you.
Apr 06, 2008 | RCA D61W20 61" Rear Projection Television
Blown tube?
tube replaement in these units are extremely labor intensive. shadow may mean a bad focus pack or it could mean a bad tube or bad crt board. but i would suggest geting a tech to look at it
Mar 12, 2008 | RCA D61W20 61" Rear Projection Television
D61w20 with sound and no picture
being able to see menu or osd as it called means that your crt are working.. you have high voltage.. and that you can hear the channels means at least part of the tv is functioning...just the video signal is not reaching the crt's somewhere the signal is blocked. try using a different input.. run it through a vcr. or dvd player and switching input through your remote.. let me know what happen.
Dec 08, 2007 | RCA D61W20 61" Rear Projection Television
Tv D61W20
so basically your power supply is out?
Nov 27, 2007 | RCA D61W20 61" Rear Projection Television
Televison & Video Logo
63 people viewed this question
Top Televison & Video Experts
Electro Med Services...
