Question about X-10 Ez Ez Up Instant Shelter Canopy 10' X 10' W Awning
The top layer is peeling away from the roll out vinyl awning on my caravan. The awning is still attached to the van, but this thin layer is just coming away and breaking off as I drive from the wind passing over the awning. Is there anything I can paint onto the surface to re-seal it and prevent any more peeling off thanks, Barry
Tension on dometic 9100 motorized awning?
The motor is supposed to hold tension against the spring at the opposite end. If the awning is loose, the spring may need to be replaced. If it still rolls out/up fine, it's the spring. Also, if it's the vinyl fabric it can stretch over time and not be quite as tight.
Mar 25, 2015 | Dometic Heating & Cooling
Ebay com official site
So sorry to hear that. Just purchase things like that from the local big box store, Lowes, Home Depot, local flooring for carpet . That way you can see what your getting an there is some guarantee.
Jul 22, 2017 | Sport & Outdoor - Others
How do i set a necchi bu mira to sew vinyl
Vinyl will stick to the presser foot so either pit talcum powder on the vinyl or have a toilet roll on your lap and sew the toilet roll on the vinyl then peel it off
Oct 04, 2013 | Necchi 3102 Mechanical Sewing Machine
After doing my brisa gel nails I noticed the product separating from the tips. What did I do wrong?
If you have any trouble with your Brisa gel nails, there are several instances that may cause problems such as peeling and lifting. If the gel is allowed to touch the skin, cuticles, or sidewalls, peeling may occur. Peeling is also not uncommon if too thin a layer of gel has been applied. It is important to apply several thin layers to build up the strength and create an apex. Also, Brisa Bond must be cured under the UV light for 10 seconds or peeling may occur. Lifting may occur if you have not done a thorough preparation of the nails before applying the product.
Be sure to keep the gel in the pot away from the UV light. If uncapped pots are exposed to the light for long periods of time, the gel will turn hard and be unusable.
Brisa gel is hypoallergenic, but that doesn't mean that you won't be allergic to it. Being hypoallergenic simply means that a person is less likely to be sensitive to the product, because it doesn't contain some of the chemicals that other gel systems do.
Good Luck!
Mar 14, 2012 | Health & Beauty
The initial "C-A-R-E-S" letters that are on the
Read the single instruction slip, peel off the vinyl printed layer and throw it away!
A New Player
Dec 27, 2010 | Hasbro Scrabble Flash Game
Hey, I was just wondering if there was anyway to fix damage done on the top of my board. On the top just right of my toe, their is a gash where the surface is pulled up but still connected. I called a...
Chips in any well used snowboard are inevitable, but you can prolong the life of the board by taking care if this right away. The best thing to do is to fix any spot that is peeling with epoxy. If the part that is peeling is large, it might be best to use a razor blade/xacto knife and cut it off around where it stops peeling. Make sure the area where the board is peeling is clean and completely dry. Then mix up some two-part epoxy; the 15 or 30 minute cure type which you can buy at any general store should be fine. Spread the epoxy evenly across the area where the peeling top layer meets the second layer beneath. If you left the part of the top layer that is peeling, spread epoxy in any crevices made by the two layers. Allow this to dry naturally (do NOT apply heat, as this could cause bubbling and make things worse). Once the epoxy dries, you can either let it be, or lightly file or sand any rough spots of epoxy. You then shouldn't have to worry about the peeling anymore.
Nov 29, 2010 | Burton Fix Snowboard
Where is the filter?
To find the filter you need to do the following steps. Find your lint trap. Lint traps in washing machines can be in the agitator (the large plastic piece in the center of the tub), at the top of the washer on the rim of the tub, or attached to the washing machine's drainage hose. Pull out the agitator tube to check for the lint trap. Peel any loose lint from the filter. Scrub away lint that doesn't peel off easily with a heavy-duty paper towel or a wet sponge. Feel your way around the top rim of the washing machine's basin. If you locate a trap, pull it straight out of the machine. Peel away loose lint and follow up with a wet sponge or heavy-duty paper towel. Check your machine's drainage hose for an attached lint trap. Remove the trap and peel the top layer of lint off. Rinse the trap in low-pressure, warm water. Reattach to the drainage hose. Check for and remove any lint or debris that may have dropped into the washing machine basin during the cleaning.
Let us know if you want any further clarification.
Thanks for contacting fixya.com
Dec 06, 2009 | Hotpoint Aquarius WF210 Front Load Washer
How do I replace the back window?
Remove the black vinyl trim from the edge of the glass. Remove broken glass & urethane adhesive from the metal pinchweld leaving a thin layer (approx 1/16") of urethane for new new urethane to adhere to. Vacuum broken glass. Prime nicks to the metal to protect from rusting (also insuring a good surface to bond to). Attach vinyl reveal molding to glass (unless it's a "T" shaped push in type - it would install after the glass is set). Clean and prime the replacement glass. Apply new urethane adhesive. Set glass in place.Slide the metal joint cover in place on the molding (at bottom in the center). Clean outer surface of glass. Allow for safe drive away as noted by urethane manufacturer.
Sep 25, 2009 | 1995 Oldsmobile Cutlass Ciera
Connection to difusser too short.
We used to buy a roll of 25ft, or so, at the dealer I worked for in the past, for just such an installation, of the vinyl that is connected between upper & lower units. Attach it to top as other piece is with band clamp, let it drop down through the hole, peel tape off, stick to lower and trim it off. Worked great. Dealer you bought unit from may have some. Other set-ups I've run into lately are ducting made out of 4 pieces cut to proper length 1" insulation & taped together at corners, and before that was just heavy cardboard, bent in proper shape like opening, then, vinyl taped to inside of cardboard. It all worked, but personally I'd prefer the vinyl, at proper length.
Aug 19, 2009 | Coleman Mach III Air Conditioner
Awning fixed to existing brick retaining wall
If I were you, I'd use the threaded rod imbedded about 100mm in the wall. Make sure you have at least 5 threads showing after you tighten down the nut on the threaded rod. That will help you decide on the length of the rod. Make sure you use epoxy to hold the threaded rod in place and everything will be fine. However, if a big enough wind comes by, the awning may come loose from your house. Have you thought about a retractable awning? It will roll up next to your house. You only have to unroll it and connect the legs in prepositioned holders. During a storm, you probably won't be outside anyways, better to have the awning rolled up for safety.
Oct 28, 2008 | Measuring Tools & Sensors
X-10 Ez Ez Up Instant Shelter Canopy  10' X 10' W Awning Logo
91 people viewed this question
Top X-10 Scuba Diving & Snorkeling Experts
David Bugden
David Bugden
Bill Boyd
ray gallant
Are you a X-10 Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
