Question about Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed
My lawn tractor with hydrostatic drive will not go in revese,
The tractor goes well in forward gears but will not move in reverse. What can I do about it?
  • 15,935 Answers
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Aug 13, 2010
Model 917.203900 22 HP lawn tractor. Shifts consistently into forward but frequently won't shift into reverse. What's wrong?
  1. Craftsman Hydrostatic Transmission Fluid Change - YouTube
    ? 40:15
    www.youtube.com/watch?v=vd1EqFtTYgk
    May 10, 2012 - Uploaded by Smokeasammie
    I change the gear oil and hydrostatic transmission fluid on my Craftsman Lawn Tractor. Fluid per Peerless ...
Jul 20, 2015 | Craftsman Garden
Craftsman 917273482 will not shift into gear, and I can't push it because it won't disengage
If there is too much play in the drive belt due to belt stretch or linkage wear, the belt will be too loose to drive the tranny but still cause the tranny input shaft to rotate preventing it from being put into gear.
Do the gears grind when trying to put into gear? With engine off you should still be able to push the machine if you put it in neutral. Unless, of course it is a hydrostatic transmission, in which case there should be a lever to push/pull which will put the hydrostat in neutral. This is all assuming that it is a hydro and while running the machine won't move when putting the drive lever into forward or reverse.
Mar 24, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Mower won't move in forward or reverse, it just makes a loud wining noise. I've had this happen before but I usually can get it moving.
If this is a hydrostatic drive. Check oil level in transmission. If you have been running it low on oil, it may be too late for the hydrostatic drive unit. If it has a drain plug, drain it and change the oil.
Jul 18, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Lt1000 hydrostatic drive stuck - will not engauge or disengauge
Does the tractor try to move or **** in any direction, if so you may want to check to see if the disk that controls the brakes is stuck, I've seen this many times.
May 15, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Lawn mower was working fine now it will go into
  • check the belt - it could have broken or come off the pulley
  • tension spring may have broken or come off
  • after that - it could be any linkage from the shifter lever to the lever on the transmission
  • worse case your hydrostatic transmission failed, which is unlikely
if you need any parts or further information, please call John at 860.233.5439 x222
www.ButlerPower.com
Apr 17, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Wont move forward or reverse-- transmission??
Does it have gears or a hydrostatic (automatic) transmission?
If it's a gear model, sounds like a loose drive belt.
If it's hydrostatic, it could be a belt problem or a problem inside the transmission. If it's a tranmission problem, this is not good. Many of the transmissions on riding lawn mowers are not serviceable - they are just replaced.
Oct 10, 2009 | Garden
NEW WHEELS AND BRAKE ADJUSTMENT MOWER WILL NOT MOVE IN ANY GEAR
Is it a hydrostatic drive and did you pull the pin that is located by the hitch. The pin should be pushed in in order to engage hydrostatic drive.
Apr 13, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
John Deere LT190 Lawn Tractor transmission problem
is it hydrostatic drive? if so you probably need to change filter and fluid
Oct 01, 2008 | Garden
Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed Logo
182 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
