Question about Samsung SyncMaster 172N 17" LCD Monitor
Samsung syncmaster 920BW - the screen goes white - no adjustment controls work - any idea what is the problem? Thanks.
  • 11,361 Answers
Look to see if the T-CON board on the LCD panel is getting the 5vdc feeding it, it may have blown fuse on the T-CON board due to short circuits.
http://s807.photobucket.com/albums/yy352/budm/LCD%20panel/
Posted on Jul 18, 2010
Greetings, It looks like have ghosts on the screen. I get watch well, but the quake goes on. Please, help me! Thanks! See you!
iam also having the same problem the monitor fully white remove panel there is spring in the leftside of the monitor adjust it
Oct 08, 2010 | Samsung SyncMaster 540N 15" LCD Monitor
Samsung LCD monitor (SyncMaster 710v) displaying white stripe.
hi,
your lcd micron tube in the panel had already worn out.
got to replace the panel
Jan 21, 2010 | Samsung SyncMaster 172N 17" LCD Monitor
Same problem- SyncMaster goes on/off, bad TV image, needs reset
try to update the monitor driver tehn check the same with the cables from cpu detached if no signal comes for long then the monitor is fine also try to check the monitor on bios screen
Sep 15, 2009 | Samsung SyncMaster 910MP 19" LCD Monitor
Samsung SyncMaster 720N ...
OK, I've figured it out! There's something wrong with the control chip, so if you don't have it under warranty, here's what you can do:
1. Turn off the monitor
2. Unscrew the face of the monitor
3. Remove the bottom part of the face from the backside, so you can see the chip
(the control chip is located on the face of the monitor, under the buttons)
4. You will see a small white connector about 5mm wide, UNPLUGG it
5. Put the small cable that you've unconnected under the front, so you can close the monitor back
6. Close the monitor and plug it back in
That's it. You won't be able to change your settings (they autoadjust anyway), but you won't have to throw the monitor away!
Peace.
Aug 01, 2009 | Samsung SyncMaster 720N Monitor
Samsung syncmaster 913c
press the blue fn button and look for a screen on the buttons F1 through F12
Jun 17, 2009 | Samsung SyncMaster 940N Flat panel Monitor
Samsung SyncMAster 920bw lcd monitor always white even not connected to pc
Is the power light on? Has this LCD worked for you before? Have you tried adjusting brightness/ contrast ?
Dec 07, 2008 | Computers & Internet
Picture not filling monitor screen
what is your sceen resolution set at on your laptop. try adjusting them and see if that works.
mj
Nov 01, 2008 | Samsung Syncmaster 730B 17" Flat Panel LCD...
New flat screen monitor humming noise
This could well be your refresh rate. Move your mouse pointer over any blank area of the screen and right click. Highlight and click on properties.Click on the settings tab, then on advanced then on to the monitor tab. You should see a setting for refresh rate eg. 75 Hertz. Change the refresh rate and the noise should disappear.
Jun 30, 2007 | Samsung 920BW (Black) Monitor
Samsung syncmaster 204b
Yes. There is no vertical deflection. The circuit that controls vertical deflection is bad. This is an easy fix for a TV tech. Take it to the TV repair shop.
Dec 14, 2006 | Samsung SyncMaster 204B 20.1" LCD Monitor
Samsung SyncMaster 172N 17" LCD Monitor Logo
319 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
