Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
2001 john deere 445 will not charge any common problems? How do you test the voltage regulator?
    Scholar:
  • 121 Answers
Voltage regulators will keep the voltage at around 13.5 to 14 volts with the vehicle running. This is what keeps your battery charged while driving the vehicle. If is lower than battery voltage (usually around 12.3 to 12.8) then it is probably bad.
Posted on Jul 16, 2010
New battery on F525 John Deere mower won't stay charged-battery connections are good-is voltage regulator bad?
Either the alternator is not charging properly or the diodes in it are defective and discharging the battery when the ignition is off.
Sep 06, 2017 | John Deere Garden
Where is the voltage regulator and stater locater on a 2001 445 john deere lawn tractor
stater under fly wheel regulater on frame mount near motor
Aug 27, 2014 | Garden
Battery not charging
Most likely a faulty voltage regulator located on the inside firewall. Look for the cooling fins on its exterior. It can be tested or replaced. Secondly, inspect the wiring that comes from under the flywheel making sure its not broken or cooked. Lastly, the flywheel may need to be removed and the magneto replaced.
Feb 20, 2014 | John Deere Garden
Replacing voltage regulator
Not sure what you mean when you say Replacing voltage regulator. Would need to know the model number of the engine however as a general rule a voltage regulator is fairly easy on most of the John Deere mowers. As with any electronics when you buy they are not returnable. Depending on the engine you have a voltage regulator can be costly and may not fix your problem.
Sep 29, 2013 | John Deere Garden
John Deere 445. I would like someone who knows about this tractor answer the question as to why after replacing the camshaft why the motor backfires through the carb. If you read through all of my...
Of the 100+ camshaft replacements that I personly have done on the 425/445 and John Deere Gators I have come across 3 that backfired when completing the replacement.2 were do to bent valves coming in contact with the piston after gear failed and 1 was from a sheared flywheel key.The only other time I had this same injected engine backfire was on a John Deere gator 620i that had a faulty computer and fired @ 90 derees off.Do a compresion check and that will help out alot.
Aug 06, 2010 | John Deere Garden
How can I tell the year of my John Deere 445 lawn tractor. Product # M00445C096237 ?
1993: 010001
1994: 020001
1995: 030001
1996: 040001
1997: 050001
1998: 060001
1999: 070001
2000: 080001
2001: 090001
http://www.tractordata.com/lawn-tractors/000/0/4/45-john-deere-445.html
Mar 10, 2010 | Garden
The charging system on the mower will not charge the battery up
The first thing to check on this machine is your voltage regulator try bypassing the voltage regulator to see if the alternator starts charging, it would be better to check your charging system with a voltmeter so that you know what the exact input and output in the electrical system.
Sep 22, 2009 | Garden
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
652 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
