Question about Kenmore 24032\24036 Top Load Washer
The machine goes through all of the cycles except the spin cycle.what could the problem be?
  • Kenmore Master
  • 8,220 Answers
Could be the lid switch is malfunctioning. FYI: The lid must be closed for spin on older washer. It must be closed for wash and spin on newer ones. The lid has a striker in it that pushes against the lid switch arm. This switch allows for spin IF the lid is closed. The switch may have failed. Mechanically the striker may be broken or the actuator arm may be broken. The end that the harness plugs into has 3 holes. As you can see above the lid switch has 3 wires. 2 live wires and one green ground. You can jump the washer out using a horseshoe shaped wire or equivilent. Newer models have the ground wire on one end. Not good! Look for that before attempting to jump it out. At any rate their are 3 wires. One of them is always green and always mounted to the frame. The other 2 are live. You can jump them to magically make that puppy spin and pump. Not recommended to leave it that way. For testing purposes only. the machine goes through all of the cycles except - 492ff1e.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jul 16, 2010
  • Dan Webster
    Dan Webster Jul 16, 2010
    Must see tip on direct drive washers with 4 videos that show how to replace lid switch, coupler, pump, and drive coupling brought to you by Red: My FixYa Direct drive washer tip
  • Dan Webster
Intermittent no spin
What is the complete model number of your unit?
Dec 10, 2012 | Washing Machines
Spin cycle stopped on 10 yr old Amana washer
its the brushes on your motor or your pump is blocked or defective
Jun 23, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Sometimes won't start spinning cycle
In most cases, this is caused by a faulty lid switch.
Oct 25, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Series 70 kenmore elite washing machine
If it goes through the complete cycle o.k. except for the slow spin then the motor itself needs to be checked.
Mar 20, 2008 | Kenmore 24622 Top Load Washer
Hoover 2305 washine machine wont spin
Your problem could be caused the interlock but it could also be that the machine is failing to drain in the time alllowed and therefore the machine will not spin, before buying a lock check the sump hose and pump area for blockages.
Dec 29, 2007 | Washing Machines
Everything is working except the spin cycle
Sounds like the spin coil/brake solenoid is burnt out or broken. This is a coil situated on the motor plate under the machine with a lever attatched to it. When the machine goes into spin cycle, this solenoid pulls the brake away from the outer drum to allow the drum and agitator to spin together. The shaft that goes into this coil should move in and out freely. If tight, replace spin coil/brake solenoid.
Oct 31, 2007 | GE WSKS2060WWH Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
135 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
