Question about Lenovo 3000 N100 Notebook PC
No audio device message. Also Code 43 when I tried to install driver. Infrared Seriel Cable using IrDA protocol showing as problem device. Previous to this problem, sound worked fine.
  • 4,281 Answers
It conflicts with your sound device.
For that uninstall both driver from device manager.
Right click on my computer then click on property then hardware->device manager.
Then you can see all driver list uninstall sound and infrared driver then reinstall both then it will work fine.
If you haven't sound driver then download it from computer menufecturer web sites.
Let me know if you need further assistance.
Thanks for using FixYa.
Posted on Jul 16, 2010
  • rudyare Jul 16, 2010
    The conflict is between the infrared seriel cable and what else? There is no audio device to uninstall.
  • So you need to install audio driver for your computer.
    Download audio driver from computer's menufecturer web sites.
    Then install then it will work fine.
What is code 43
Code 43 Error Message
The Code 43 error is one of several Device Manager error codes. The Code 43 error will almost always display in the following way:
"Windows has stopped this device because it has reported problems. (Code 43)"
Details on Device Manager error codes like Code 43 are available in the Device Status area in the device's properties: How To View a Device's Status in Device Manager.
Cause of the Code 43 Error
A Code 43 error is generated when Device Manager stops a hardware device because the hardware reported to Windows that it's having some kind of unspecified problem.
This extremely generic message could mean there's a true hardware issue or it could simply mean that there's a driver problem that Windows isn't seeing as such but that the hardware is being affected by.
Error Code 43 Troubleshooting
Restart your computer if you haven't done so already.
There is always the chance that the error Code 43 you're seeing on a device was caused by some temporary problem with the hardware. If so, a restart of your computer might fix the Code 43 error.
Note: Some users have also reported that powering off their computer completely (not just a reset) and then turning it back on has corrected their Code 43 issue, especially if it exists on a USB device. In the case of a laptop, turn it off and remove the battery, wait a few minutes, and then put the battery back in and start the computer.
Did you install a device or make a change in Device Manager just before the Code 43 error appeared? If so, it's very possible that the change you made caused the Code 43 error.
Undo the change if you can, restart your PC, and then check again for the Code 43 error.
Depending on the changes you made, some solutions might include:
Jan 23, 2013 | Lenovo Computers & Internet
Free download acer travelmate 4050 serios cl51 drivers
The only drivers available for this laptop are for Windows XP.
You can download these drivers directlyu from Acer:
http://us.acer.com/ac/en/US/content/drivers
From this page, choose "Notebook" then choose "TravelMate" then "TravelMate 4050"
You will see that Windows XP is the only operating system selected, and Windows Vista and Windows 7 are not selectable.
The two choices for Windows XP are XP Home Edition( 32 bit) and XP Professional Edition( 32 bit)
The drivers listed here are for:
Intel Chipset
Realtek Audio
ENE Cardbus
SMSC FIR( (Fast InfraRed) A high-speed IrDA protocol with data rates up to 4 Mpbs.)
RealTek LAN
Agere Modem
Feb 27, 2011 | Computers & Internet
How to install games to motorola c650
hi there,
You can download ganes to you phone through different methods like: Over-the-Air (OTA), Infrared (IR), Bluetooth and Cable
1. For uploading through OTA: make sure your wap is well configured and working (each operator has different settings). Enter the .jad url of the game (URL of jad can be found below), then the phone will automatically download the .jad file. After the .jad file is downloaded you will be prompted to confirm the downloading of the .jar file. If you press yes then you can download the file and install the game. Volia! In general you should make sure that the .jar file will fit on your phone. Some devices like Nokia Series 40 (MIDP1) limit the .jar size to 64k, others will limit it to under 100k. Also most devices have a low limitation on the size of all games (midlets) installed, so you should always check the available memory and in some cases remove any old unused games. We have taken the limitation of each device into consideration and there's nothing to worry about here.
2. For uploading through Infrared: First you should get an IRDA peripheral and connect it to your PC. It's usually a USB device. Connect it and install the software.
Now there are two cases:
a. either your phone supports IRDA directly and in such case it's sufficient to upload the .jar file to your phone by right clicking on the file and use 'Send to' menu. Note that you should configure IRDA properly to connect to the phone. We are using the following configuration for SigmaTel USB-IRDA: "Infrared Transiver Type": SigmaTel 4000, "Min. Turn-Around Time": 1.0ms, "Speed Enable": 115200.
b. or your phone doesn't support IRDA directly but has IR. In such case you should use your manufactorer software like Nokia PC Suite.
3. For uploading through Bluetooth: Usually this is faster and easier than Infrared. Install your Bluetooth usb device. Right click on the .jar file and select the menu 'bluetooth device' inside 'send to'. You can also pair your device with your computer to make things faster. Once the .jar file is on your phone then you can install it
4. For uploading through cable: some phones don't have neither Infrared nor bluetooth support. You can use the manufactorer cable and connect it your PC (either USB cable or com cable). In such case you should also use a dedicated software for uploading files to your device
Please use the below mentioned link to find games.
http://www.zgroup-mobile.com/demos/Motorola_C650/index.html
thanks,
S.
Nov 20, 2009 | Motorola Mobility C650
Problem with stand by
If you are using an infared or wireless mouse and/or keyboard this is the problem. You can't go to standby when those devices are actively connected.
Oct 05, 2009 | Computers & Internet
Lock code
for your info, nokia default password is 12345. if the code doesnt work, try the method below.
there was a lot of chance if you use LogoManager Pro Suite, this can easily reveal your unlock code.
just install LogoManager Pro Suite and connect you phone by cable (recommended).
bluetooth and IrDa (infrared) doesnt work for me.
LogoManager Pro Suite (demo, but can be used)
http://www.logomanager.co.uk/php/products.php?id=54
if you dont care about to lose your settings, just flash it or format it.
to flash this, please make sure nokia pc suite for your e63 is installed with driver, then
connect the phone to your pc by cable, open the nokia pc suite and backup your stuff.
after that, update/upgrade your phone software (this process using internet connectivity)
when the process finnished, restart your phone (turn it off and turn it on again).
i guarantee that you will get a fresh one with unlock code 12345.
*there was no use if you find the mastercode by using IMEI OR calculating your IMEI by using IMEI calculator
May 11, 2009 | Nokia E63 Cell Phone
How to send files to pc from my 6102 cingular phone
Better try with a USB cable, connect your handset to the PC through USB cable and then try to send pics to your handset. Dont forget to install your driver software for the handset to connect to your PC.
Dec 31, 2008 | Nokia 6102 Cellular Phone
Laptop s infrared device, serial cable using IrDA Protocol problem
Sound has nothing to do with infrared devices.
The yellow exclamation mark that you see under the device manager is due to drivers of the infrared device not found or is not installed properly.
There might also be a possibility that the device is not getting recognized by the computer due to corrupted drivers so the drivers of the particular needs to be installed again with the CD.
Jun 04, 2008 | Gateway Solo 5300 Notebook
Computers & Internet Logo
43 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
