Question about Garmin Nuvi 660 GPS Receiver
Issues with new Garmin
We received a Garmin Nivi 660 yesterday from Amazon.com. We turned it on and tested it out and it seemed to work fine. This morning I noticed there was not much battery power left so I decided to plug it in using the AC adapter and left it plugged in for 8 hours. The battery power showed the same as before. Then I decided to try plugging it in using my car adapter and as soon as I did that the screen went blank like it powered down.. Thinking there was something wrong with the power source I took it inside and plugged it in using the adapter. It did the same thing......so I tried my computer..........shut down as soon as connected to the USB. If I power it up without any of the charging devices attached it seems to come up fine. As soon as I connect anything to it, it shuts off. I've tried resetting it and it does the same thing. I am wondering if I have a defective unit or if there is something I am doing incorrectly??
Thanks!
  • 3 Answers
Try pushing the reset button and charging again. If that doesn't work I think you've got a defective unit. Contact the seller and sendit back for a trade.
Posted on May 02, 2008
I need an antenna for a garmin 660
Here is a link to amazon were you can get a new antenna for around 15 the Garmin does sell stock antennas but they are 30 with a 1-2 order processing time so this would be quicker.
May 04, 2011 | Garmin Nuvi 660 GPS Receiver
My 765 turns off too!
New software upgrade is out by garmin, also look for other blogs same problems said they sent their Garmin to supplier and got it solved, look in ww.amazon.com with 113reviews look in 1star rating. or http://www.amazon.com/Nuvi-765T-died-tonight/forum/FxFTK8E026BG45/Tx3LG8KEDC3FWNU/1/ref=cm_cd_ef_rt_tft_tp?%5Fencoding=UTF8&asin=B001ELJER4. you get your answer sorted.
Jul 11, 2009 | Garmin Nuvi 660 GPS Receiver
Garmin nuvi does turn on when connected to power in car
Hi
I had the same problem. My Nuvi 350 did not power up for a couple of days. I suspected moisture to be the culprit. So I took my wife's hair dryer and blew hot air(in the intermediate setting) into the SD card slot in the GPS for a couple of minutes. Take care not to overheat the GPS or Screen.
Pronto my GPS powered up without any issues.
Hope this helps
Oct 24, 2008 | Garmin Nuvi 660 GPS Receiver
No Sound
You might have just turned the volume all the way down. Page 4 of your manual tells you how to adjust your volume.
Apr 22, 2008 | Garmin Nuvi 660 GPS Receiver
Data card for nuvi 660
No, you do not require an additional SD card for your unit in order for it to operate. Also, you can purchase ANY SD card and it will work with additional maps and POIs. They are upselling you.
It doesn't sound like you're buying from a reputable Garmin dealer. Make sure they're a Garmin dealer in case you have any problems.
Apr 10, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin 10 second Bluetooth disconnect
I have the same problem with a Blackberry 8100 (Pearl). Worked fine before the upgrade. The only solution seems to be disabling the Blutooth on the Garmin and then reenabling it when the BB Pearl is in range.
Mar 26, 2008 | Garmin Nuvi 660 GPS Receiver
Stop transfering voice from Sony Ericson P910i and Garmin Nuvi 660
Can you update the firmware on your unit
my k800i sony phone had a problem synchronising and would freeze, then one day the nuvi 660 updated the firmware by itself and has been fine since, only problem being the volume, a bit low when trying to contest with large diesel engine, onboard speaker keen to distort over 80% volume
Feb 08, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 660 frozen screen
Don't know why it happens, but mine did the same thing. There's a reset button on the back, underneath where you lift up the antenna. Unplug the unit from the power source, push the reset button, reconnect to a power source and it should work fine; mine did. Good luck. Got this info from my Garmin owner's manual.
Jan 18, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin nuvi 650
No need to format and please do not try to change anything from the GARMIN files.
MP3 only can be read. Use SD to read or you can drop into the proper file when you plug to your computer. The file name GARMIN include many files. One of them is for MP3 , you will see example of music inside. Please do not play with other GARMIN FILES or you will had some problems with your unit.
Please refer to your manual 650, for the proper way to listen or insert MP3.
---> http://www8.garmin.com/manuals/nuvi650_OwnersManual.pdf
best regards
Dec 26, 2007 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 660 GPS Receiver Logo
101 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
