How do i program my emerson TV to recieve a signal from an antenna
  • 201 Answers
Check the back of your tv to see if you have 1 or 2 coax connectors (screw on connectors). If you have 1 no worries it can do antenna or cable on the same. Go into the menu settings look for "autoprogram" it may be under a submenu possibly labeled "channel" or "setup". It will ask if you want antenna or cable. select antenna, the tv will scan for any channels, locking in the ones it sees and ignores the channel numbers it can't see.
If you have 2 connections select the one that says either "antenna" or "VHF/UHF". Just follow the same autoprogram as above. The TV is only as good as the signal it gets, if the signal is weak it may not see it and skip it. Good luck
Posted on Jul 16, 2010
Connected antenna but no reception. cant get tv to auto program channels. like there was no reciever. do not have original remote. spent $70 for antenna
Channel scanning probably was selected using the original remote. All remotes do not have equal capabilities.
Sep 19, 2016 | Televison & Video
We cant afford cable or satelite. How do we set up digital channels on an emerson smart tv with no antenna
You have to get the digital signal from somewhere. You have discounted the two most used;
Cable
Satellite
This leaves you with two options;
External antennae
Or in your case, the best bet as you have smart television;
Internet based television. However to get that you need a fast broadband service. My broadband supplies my television signal, so I have a 125mbps connection. With that you can access all the recorded programs that YouTube offers, plus films and shows from Netflix and other programme producers like Crackle. Basically, in Smart mode your television becomes a huge computer monitor. You might wish to get yourself a wireless keyboard as trying to use the remote for accessing content is very tedious.
I would get the external antennae as well as they are inexpensive and will give you local stations and additional programming.
Dec 16, 2015 | Emerson Televison & Video
Tv wont work with antenna
There should be an antenna to receive local transmission signals.
Apr 01, 2013 | Emerson CR202EM9 TV
Emerson hdtv does not pick up any antenna signal
With digital OTA TV signals, a lot of things could cause you to fail to pick up a signal on any channel. First, do you have an indoor or outdoor antenna and how far are you from the transmitters for you local stations? Digital signals are either enough to for the tuner to interpret or you get no signal. Next check that the antenna is pointing at your stations' transmitters. Use antennaweb.org or tvfool.com to check the direction for your location. Antennaweb assumes an external antenna and provides a very conservative list of stations.
Check for buildings, hills or tall trees that might block the signal to your location.
If your antenna is providing a signal to several TVs, try a direct connection (taking out the splitter). You may need an amplified splitter to minimize the signal loss. Note: amplifiers (whether at the splitter or part of the antenna) can fail and become signal filters (blockers) instead. The direct connection tests this as well.
If another TV does pick up the signal from the antenna (at this point), then the tuner may have failed. It may also just be a weaker tuner compared to the other TV. Surges (for example, lightning strikes) can cause a tuner failure. In that case, you need a new tuner. (a stand-alone tuner like the converter boxes might work) or try a site like shopjimmy.com, searspartsdirect.com or partstore.com. SearsPartsDirect lists the tuner here: http://www.searspartsdirect.com/partsdirect/part-number/Emerson-Parts/Television-Parts/UTUNATSSP006/0057/528/Model-LC320EM9/0352/0333600?keySuffixId=NA&pathTaken=partSearch&pathRender=modelComponent&documentCompId=50034435&diagramPageId=00001&productTypeId=x&searchModelNumber=LC320EM9&subCompDesc=Lcd%20tv&brandDesc=EMERSON&modelDesc=LCD-TELEVISION&blt=11&shdMod= .
This TV was made by Funai so you may see other TVs that use the same part.
I hope this helps.
(I have two TVs with different quality tuners. With one, when the antenna shifts slightly out of place, I can lose the ability to tune in the channels from the closest transmitters. The other TV does not lose the signal until the antenna rotates more than 90 degrees from its usual position.)
May 27, 2012 | Emerson LC320EM9 32 in. LCD HDTV
Will not pick up signal for cable channels
ok the first thing I would check is your settings. Most TV's have an antenna and a cable setting when you program the channels. If that does not work you might have a problem with your signal board. You can get parts for that tv at www.interliquidparts.com
Feb 24, 2012 | Emerson LC195EMX 19 in. TV
I have a Sony KDL-V32XBR1. The turner seems to be having issues. If I scan for channels I only find a few but my other flat panel receives a full range of channel.
U are using a antenna to do a recieving for a Free AIR DTV incomming braoadcasting tv signal channels siganal?Yes.U are using two different tv antennas signals wright?The Sony one just require a stronger and a better antenna signal,not all flat LCD or Plama tvs recieve the same strenghth signals.Some tvs design require a strong or a very strong signals strenght to get all the tv Free AIR DTV braoadcasting tv channels.Buy a better tv antenna design like a Digital amtenna will solved this problems for the Sony tv.
Sep 11, 2011 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
I have a Hitachi 50 in plasma. I am using an indoor antenna for local programing only. My tv guide says no listings. I finally had it up and running for a few days but now it is gone again
Buy a better design antena like a digital antena design for a better and stronger to recieving Free DTV broadcasting tv recieving signal.Rescan for free DTV broadcasting signal again,will get it for good this time.Tries websites like Amazon.com,Ebay.com they have many types of digital antena tv design to buy.
May 09, 2011 | Televison & Video
My EmersonEwf2006 was connected and programmed to a cable box. Trying to use this same tv now with an indoor antenna for local channels. Lost my guide book therefore I have no directions. can't get it...
Here is a link to a site where you can download the manual at no charge: http://tv.manualsonline.com/manuals/mfg/emerson/ewf2006.html. You will need a digital TV converter for that set. The US is now all digital for over-the-air (OTA) TV signals. If you have a digital TV converter, and have followed the instructions in the manual installing your indoor antenna and get no stations, you need a better antenna.
Jan 06, 2011 | Televison & Video
Trying to hook up converter box to Westinghouse flat screen the converter is magnavox sdtv. I get autoscan but no channels are found. I do not have an antennae. Do I need one? Help!
If ur tv a LCD tv it is a digital tv.U do not require a Digital converter box to get the new DTV free air signal broadcasting tv channels stations.But u do require a good digital antenna for it to recieve a long an strong signals to recieve a DTV free air broadcasting tv channels stations.
Dec 07, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
My ILO 26HD LCD tv want get but one channel
You may have to enter the "Menu" of the TV and run the set-up for the cable/antenna connection. This will scan channels and program them to the TV, then you can access them.
Failing that you may have a bad tuner, unplug the TV for a few minutes then replug it and try again.
Hope this helps!
Cheers,
Jan 23, 2010 | Televison & Video
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
