Question about RCA RT2600 System
RCA RT2600 sound problems
Hi. After about 6 years without a problem I suddenly cannot get any sound from my RT2600 receiver. None of my components will produce sound (DVD, SAT, SIRIUS RADIO, Wii, iPOD, etc.) Nothing. All the wires inside and out are still connected properly. Also, it is set to the correct digital input category (ie. analog) AND mute is not activated.
Any suggestions?
  • 2 more comments
  • DMac1969 Apr 21, 2008
    I shall try that, thanks. No, my speakers do not hum, just dead silence. Also, forgot to mention that my headphones worked in the phones jack.
    OK, left it for an hour or so; plugged it back in and nothing. Still no sound.
    I've already opened it up and everything looks/feels tight and no evidence (by sight or smell) of burning. Is there a fuse involved with the speaker/sound processor?
    Left it off over night, still didn't work. Here are some pictures to help (maybe). Still can't see any connection problems or evidence of a burned board.
  • 3,037 Answers
You should first try unplugging it for 30 minutes and that should reset it and has fixed the problem on other ones before.
Also, do the speakers hum at all or is it dead silence?
Thank you for further comments to my question.
Have a Good Day.
Posted on Apr 20, 2008
  • 2 more comments
  • Benjamin Patri
    Benjamin Patri Apr 21, 2008
    sounds like the same problem as one other guy then since the jack still works too, please let me know how it goes
  • Benjamin Patri
    well then it sounds like there might be a broken connection to the speaker output from where the jack and the speaker output split off to the output. You will need to open the system and check for loose connections and see if anything smells burnt.
    If you don't feel comfortable doing this, then DON'T.
    Have someone who has worked with electronics work on it.
  • Benjamin Patri
    If you follow the connection from the output to the board, you will be able to find the problem whether it be a fuse or what, Have you been playing this at a louder setting.
    Could you post a picture of the wiring at all for me and maybe I can spot something?
  • Benjamin Patri
    I believe there are two fuses, you should try replacing them and see if that helps at all. Are you positive there isn't a loose connection? I don't see anything wrong from here, possibly try a gentle shake and see if anything moves that shouldn't and then try it again too.
No sound from speaker when on
You have a blown fuse....
looking at it from the back there are the four fuses [] [] [:] [] the third one over. If not that one and none of the four sub fuses are blown then it's your connection somewhere
Jan 21, 2011 | RCA RT2600 System
Rca rt2600 no sound, if you switch on the power the display comes up and within a seconds it shows OVERLOAD in the display and it automatically turn off. all speakers had disconnected too. please help me...
One of the audio output amplifier ics are toast the faulty one will need to be desoldered from the board and replaced, they run at about $10 each normaly. The faulty one will generaly be quite burnt.
Aug 18, 2009 | RCA RT2600 System
I have a new Phillips 42" LCD and it only has a digital audio OUT on it, how do i hook it up to the RCA RT2600 with the digital audio...for some reason it is not wanting to give me any sound?!?!?!?!?
Be sure you have selected digital audio and enabled the digital audio out on the phillips tv audio setup menu, then be sure that the RCA rt2600 input mode is set correct
Mar 19, 2009 | RCA RT2600 System
Multiple Video Sources hooked to RT2600, but only DVD shows
I own the RCA RT2600 Home Theater System. I have never set it up, it has never been used. I have someone who wants to buy just the receiver and nothing else. I am wondering what you paid for just the receiver? I don't want to break up the system but I need money right now. I am open to suggestions as to what to do and how much to sell them for.
Thank-you
connally35@aol.com
Jan 17, 2009 | RCA RT2600 System
I've found an RCA RT-2600 HT for $10. Receiver showed "overload", now won't power. It's also missing a rear speaker. Is the receiver fixable? If not, what receivers are compatible w/the subwoofer? ...
There may be a fuse inside the cover. I replaced the 2 front and 2 rears with pioneer S-HF21-lR 2 way,100 watters. they are bookshelf size speakers, but trust me they rock. you wont be disappointed. im pwering them with a sony receiver. no problem. if its a typical rca sub, its non powered and will work with about any receiver. Steve
Dec 20, 2008 | RCA RT2600 System
Rca rt2600 when i press power botton i hear a click sound and doesn't turn on
you're having a startup problem, u should take to an expert.
Aug 18, 2008 | RCA RT2600 System
RCA RT2600 Speakers stopped working.
I bout mine used an it has absolutely no problems you probably got one that they knew wasnt really working in the first place.
Jan 25, 2008 | RCA RT2600 System
Rca rt2600 OVERLOAD PROBLEM
Your receiver has blown out you need to buy a NEW Receiver and sub-woofer (the sub isnt compatable with better receivers)
Jan 06, 2008 | RCA RT2600 System
DVD problems
u having a problem with your tv . take it to a professional.
Nov 06, 2007 | RCA RT2600 System
RCA RT2600 System Logo
297 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
