Question about Toshiba Televison & Video
My toshiba vcr gives audio but no video, it was damaged,apparently by lightning, to the point where it wouldnt power on,after changing an I.C. on the power block its now powering on, but the video wont come on, just audio,and everything else works. the head was properly cleaned, so what could be the porblem ? the vcr model # is M-447L.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 242 Answers
Check the capacitors.
Posted on Jul 16, 2010
How do I set up my secura cam SW214-SCC
Step1: At the end of your SecurityCam cable you will find three colored plugs: Yellow(Video RCA), white(Audio RCA),Black/Orange(DC Power) or identify
OR
Identify the cables at the end of the SecurityCam cable as color for video ,audio and power may vary.
Step2: Plug Video RCA plug(1) into the "Video In" input(3)(Usually located at the back of your TV or VCR)
Step3: Plug the audio RCA plug(2) into the "Audio In" input(4)(Usually located at the back of your TV or VCR)
Step4: Connect DC power plug(5) at the end of your Security Cam into the end of the power adaptor(6)
Step5: Plug the power adaptor(7) into the main power point in your wall
Step:6 If you have AV/TV with RCA sockets you will need to switch the TV to the AV change to view the camera.
Pictures is attached. Please have a look at it.
Jul 17, 2016 | Office Equipment & Supplies
Toshiba TV/VHS/DVD
press the tv on the remote. if you want to use the vcr. press vcr on the remote.
Apr 04, 2008 | Televison & Video
Toshiba 40FT1U TV won't turn on. Lightning pulse
Fault to the main power supply regulator section. Either it will be on a separate board, or on the part of its main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Can't determine the condition of the power supply board, by just examining the fuse; you know. Contact any service technician.
Aug 10, 2015 | Toshiba Televison & Video
Toshiba vcr operates for a few seconds then shuts down
When a VCR encounters a problem with the drive mechanism the unit will shut itself off to prevent further damage. You should take the top cover off and look around at the mechanical section for damage. If you can't see anything, leaving the top off, insert a video and watch what happens to it. This will give you a clue to the problem.
Dec 26, 2013 | Quasar VHQ400 VHS VCR
Toshiba 37AV500U damaged thru HDMI input.
The lightning stroke has been effected to the main digital board to your TV. It will be best to replace the main digital board as card basis, rather than trying to repair it. Before replacing the board, a through checkup should be done. Contact any expereienced service technician for help, as this work is a very skilled one. No body can predict about the damages to a lightning stroke, as there will be trillions of voltage present for every stroke, and even a slightest voltage can damage so many components in a TV like equipment, as it is designed to work for 110 or 220VAC.
Jul 07, 2012 | Toshiba 37AV500U 37 in. LCD TV
I have a Toshiba W727. I have all new recording tapes. Recently when I playback the tape, the picture bounces, even though the actual picture on the TV did not bounce. I have used a tape to clean the...
Open up the front of the VHS tape and look at the tape inside. It should be nice and smooth. If it is not the video machine has damaged the tape and it will bounce and make a mess of the video heads again. If the tape is crinkled at the bottom side the pinch roller on the VCR is worn and needs replacing. If there is no damage to the tape. Then all you need do is give the video heads and any part that touches the tape a good clean. To do this you unplug from the mains the power lead. Remove the top cover of the VCR and with some Servisol Video 40 Spray clean the heads etc. You can use a cotton bud to get into corners. Leave to dry for about 10 minutes. And re-asemble to try a tape.
You can find the Servisol on-line.
PS if you have never seen inside a VCR before, after you have taken the top off plug the power lead back in, you don't need any other connections and play a tape and watch where the tape touches. Take the tape out and pull the plug! Then clean!
Cleaning like this is much better than a tape.
Sep 12, 2011 | Toshiba Televison & Video
Coax connection pulled out
ok this is a common thing i repair alot of these at the shop. most teechnician can resolder these back on or replace. just depends of if the curcit boarcd was damaged when it was broke. about 20 percent of the time it damages the tuner. However i can give you another option. use another input/ you can take a vcr and useing the rca cables yellow, for video and red and white for audio and fplug your cable to vcr then vcr to tv. You will have to use your vcr to change channels until you can get it repaired. essiental using your vcr as your tv's tuner
Oct 13, 2010 | GE D52GW12 52" Rear Projection HDTV-Ready...
Denon receiver just struck by lightning.
Any time a unit is hit by lightning, it is usually a total loss. While the initial problem may be fixable, other components have been stressed and are likely to fail. Most shops won't work on these units because of the likelyhood of continual failures. Warranties won't be given or the repairs. In your specific case, the switching IC has been damaged and needs to be replaced as well as the surround processing section. This is best handled as an insurance claim for replacement.
Dan
Apr 06, 2010 | Denon AVR-1905 Receiver
VCR transmits audio but no video to TV following lightning strike
pls check your SONY vcr back side pin cofogratin .
video in / out
audio in / out
3 MORE VIDEO OUT PIN [GY /BU / RV ] green /blue /red
if yes then use this three pin .but check your tv set back side same three pin is there .
if not
cont. me :e-mail :shaiparikh@yahoo.co.in .
pls send me your tv model no /vcr model no
Oct 08, 2009 | Sony Televison & Video
No video/audio on tv when powered up and running
drew a diagram of the back of each component & wires/cables and emailed it to my grandson,
The video wires in the VCR were placed out instead of in. That solved the problem Thanks.
Feb 14, 2009 | Sony DVP-S360D DVD Player
Televison & Video Logo
43 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
