Question about Toshiba Satellite A100-S8111TD Notebook
The LCD of my toshiba laptop has vertical lines
Hi, my problem is the LCD of my toshiba laptop has many vertical lines of different colors. what could be the possible solution to fix it?
Thanks.
  • 3 Answers
Your screen is in need of replacement.
Posted on Jul 16, 2010
Why are there vertical colored lines all over screen?
Thin vertical lines cover screen on Samsung LCD - AVS Forum ' Home ...
www.avsforum.com/...lcd-flat-panel.../1127410-thin-vertical-lines-cover...
Mar 7, 2009 - 30 posts - ‎25 authors
I have read there could be ribbon cable connection issues so I plan to .... I have a VizioVW22LHD TV,I hooked it up using a HDMI cable to my Toshiba satellite laptop. ... If you have thin multi-colored vertical lines on your tv panel, that do ... my TV on the thin vertical lines come all over the screen and the TV ... my VIZIO E470i-A0 LED has vertical colored lines on ...
Nov 18, 2013
Vizio SV370XVT lines throughout entire display. Not ...
Aug 3, 2012
Thin vertical line on LCD tv
Dec 29, 2007
More results from www.avsforum.com
Vizio P50HDTV Display Problems - Colored Vertical Lines .
Dec 30, 2015 | Vizio Televison & Video
My compaq presario m2000 lcd screen have vertical lines in different colors, how can i remove this vertical lines?
Take out battery from laptop and disconnect power cable. Keep the power button pressed for 30 seconds and then plug the power cable. This will remove static charge from laptop and should resolve the display issue,
Nov 20, 2011 | Compaq Presario M2000 Notebook
A green vertical lines on my screen
What is happening to your laptop is the power line connecting a row of pixels is failing so only partial colors are showing up causing the vertical line(s). Usually screen replacement is the only answer to fix it. You can usually find replacement LCD on Ebay.
Jan 06, 2011 | Toshiba Satellite Pro L300 Notebook
Vertical lines on lcd display, just a few at first but getting worse
What is happening to your laptop is the power line connecting a row of pixels is failing so only partial colors are showing up causing the vertical lines. Usually screen replacement is the only answer to fix it. You can usually find replacement LCD on Ebay.
Dec 29, 2010 | Toshiba Satellite P105-S6104 Notebook
Monitor has a vertical line through it
What is happening to your laptop is the power line connecting a row of pixels is failing so only partial colors are showing up causing the vertical line. Usually screen replacement is the only answer to fix it. You can usually find replacement LCD on Ebay.
Dec 29, 2010 | Toshiba Satellite P105-S6024 Notebook
Getting colored vertical lines on the right 1/3 of my 52" Toshiba LCD why? can it be fixed?
looks like the lcd panel is damaged contact the toshiba service on your area
May 04, 2010 | Toshiba REGZA 52RV530U LCD TV
HI, Thick white vertical line on screen
your lcd screen damaged.u need to replace it with new.
Dec 08, 2009 | HP Pavilion zd8000 Notebook
Vertical lines on screen different colors
The problem is the LCD panel or the logic PCB (printed circuit board). you can find the logic pcb attatched via flat ribbon cables or small plugs. Good luck. The part number should be on the printed circuit board. I hope this helps.
Nov 16, 2009 | Toshiba 42HL196 42 in. LCD HDTV
Everything can be fixed.
Try hooking up your laptop to an external monitor. If you get lines then the problem is the video card.
If not, it's the lcd, usually it is anyways.
Just replace the lcd and your problem is gone.
Best of luck!
Feb 25, 2009 | Toshiba Satellite P105-S6207 Laptop
Vertical lines in my laptop screen
what i recommend you to test is to press behind your monitor and see that the line goes off or not.If it does..that mean you have a loose connection,it can be fix.Incase no then you have problem with your LCD.Normally if its LCD problem then you fix this problem,all you have to do is change the LCD.
goodluck,takecare.
May 04, 2008 | Toshiba Satellite P30 P35 Series Notebook
Toshiba Satellite A100-S8111TD Notebook Logo
213 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
