Question about Hayward 3/4hp Super Pump Inground Pool Pump 115/230 Volt # Sp2605x7
Super pump when running polaris 360 it leaks between pump and motor, my last 2 pumps did the same thing, this pump is 4 1/2 yrs. old, does not leak when waterfall is on, does it need a new
  • 3 Answers
Need a new shaft seal. $9 value.
Posted on Aug 09, 2010
My polaris booster pump just gets hot and wont run
the motor is bad overheating need a new booster pump
Sep 08, 2014 | Polaris Pb460 Polaris Booster Pump...
My pool is losing water when a Polaris 380 is running off a booser pump
plug both sides of Polaris hoses one at wall and one at Polaris if stops leak in Polaris line
Jun 08, 2012 | Polaris 380 In Ground Pool Cleaner
My polaris booster pump noise
bad motor due to bad seals leaking on motor better to replace whole pump next time
Jun 03, 2012 | Polaris Pb4 - 60 Booster Pump
Have a hayward 1.5hp motor. plastic impeller broke off and is not spinning, how do i replace.
YOU WILL NEED A NEW IMPELLER SPX3010C SUPER HAS 4 BOLTS OR A SPX261OC SUPER 2 HAS 6 BOLTS. JUST TAKE THESE BOLTS OUT AND THE IMPELLER SCREWS OFF TO THE LEFT, CLEAN UP THE TREADS. USE A NEW 201 SHAFT SEAL. AND ON THE MOTOR PICTURED THE SHAFT CAN BE HELD AT THE BACK OF THE MOTOR TO SCREW ON THE NEW IMPELLER.. PUT IT ALL BACK TOGETHER ,PRIME THE PUMP WITH ABOUT 4 GALLONS OF WATER. RUN IT AND WATCH FOR LEAKS .. NO LEAKS ? YOU GOOD TO GO ! ..
JAY THE POOL PUMP MOTOR REPAIR GUY IN LONGWOOD FL .. GIVE ME A VOTE IF'N I WAS OF HELP 2 YA
Jul 06, 2011 | AO Smith Pool Pump Motor Hayward Swimming...
I have a polaris pump. It starts and runs good cold. After about 30 minutes of use it stops for maybe 10 minutes and starts for about 10 -30 seconds. I usually stop it for about 1 hour or more and then...
THE LITTLE CAP ON THE TOP OF THE MOTOR IS THE RUN CAPACITOR, TAKE IT OFF AND HAVE IT TESTED. BE CAREFUL THESE CAN HOLD VOLTAGE AND GIVE A NASTY SHOCK ! SEARCH YOUR AREA FOR YOUR LOCAL POOL PUMP MOTOR REPAIR GUY WITH FREE TESTING..JAY
May 31, 2011 | Polaris Pb4 - 60 Booster Pump
I replaced the motor on my super 2 pump with a new shaft seal. Put it all back together including electrical and now it's leaking from the bottom. I retightened the screws to make sure they weren't loose...
Most likely leaking from either the shaft seal, or the valute seal (big seal plate o-ring). When you replaced the motor you should have also replaced the shaft seal. If not go back and do that whether it's leaking or not. If you get your head down and look at the bottom of the pump while it's running you should be able to see the water coming from the joint between the seal plate, and the seal plate housing, or just behind that from the bottom of the motor probably from the vent holes in the motor housing. If it's coming from the motor then the shaft seal is leaking, and the water is traveling along the shaft and out the bottom of the motor. This will eventually get into the motor and seize up the bearings. If it's coming from the valute seal, then you need to either replace or re-seat the seal. As a general rule you should always replace the shaft seal, and diffuser and seal plate o-rings when you replace the motor or split the seal. I'm not as familiar with the 2 speed hayward super 2, but the standard super 2's have a small ribbon seal, often called a rubber band. They are infamous for going bad especially after pulling the pump apart.
Sep 18, 2010 | Hayward 1 Hp 2 Speed Super Pump Inground...
I have a Polaris PB4-60 Booster Pump with a leaking seal. I have removed the Volute and removed the 4 bolts that hold the bracket to the motor. How do I remove the impeller? At the store they told me it...
You need to lock the other end of the motor shaft and then spin off the impeller. If you would like a quote on the replacement seal, contact us at www.arrowpools.net
Jul 11, 2009 | Polaris Pb460 Polaris Booster Pump...
Hayward 3/4hp Super Pump Inground Pool Pump 115/230 Volt # Sp2605x7 Logo
88 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
