Remote control will not turn TV on
Remote control will not turn TV. Batteries are good....problem is intermitent over the last few weeks....but seems stuck now;.
  • 11,361 Answers
Try this:
Testing remote control:
The remote control puts out IR (InfraRed) signal that human eyes cannot see, to find out if the remote is sending out the signal or not you just point the remote at the digital camera’s Lens (Digital Camera can detect IR), you should see flashing light on the camera’s screen when any one of the remote button is pushed. If you do see the flashing on the camera, then the problem is in the TV IR receiver or the main logic board; more troubleshooting with scope will be needed to look at the signals.
Parts: www.shopjimmy.com
www.remotes.com
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Posted on Jul 16, 2010
Hey guys my youview remote has stopped working, the talktalk button keeps flashing blue though
Test if your remote works by viewing it through a digital camera. (A phone camera works well.) View the front of the remote on the camera's digital display while holding down any of the buttons on the remote. If your remote is working you will see an RF light coming from the front of your remote. (You can only see this through the digital camera. The human eye cannot see the RF signal on its own.) If you don't see the RF try changing the batteries with known good batteries and try again. If you see the RF but your remote doesn't seem too work it needs to be reprogrammed.
Here are the steps for programming the remote to work with my Samsung TV and other brands.
1.) Turn the TV on.
2.) On the remote control hold down TV Power+01 at the same time. If the TV turns off the controller is programmed. If not, try TV Power+02, +03, +04, +05, +06, +07, +08, +09. Different TV BRAND??? ...TRY the codes listed for other TV brands located on the last page of this link.
http://remotes.com/remotes/documents/Samsung/AK59-00104K.pdf
Dec 18, 2014 | Televison & Video
I have a Westinghouse 77870 remote control with a light problem
read your intruc. manual and proceed according. download from www.fitness.manualsonline.com or www. retrevo.com
However you retight the spring contacts with pliers for better contacts batteries. 2) Open the re.control and clean the keypads for dirty, oxide with special spray contacts. 3) If the problem persist go to the repair shop TV for fix it.
God bless you
Jul 06, 2012 | Westinghouse 77870 Remote Control
Volume turns up by itself
This might be a remote control issue, so try this: remove the batteries from your remote, then press all of its buttons and install new batteries. If the problem persists after that, your TV may require repairs. Service can be obtained, if needed, by carrying your TV in to the place of purchase.
Nov 27, 2011 | Insignia Televison & Video
I have a Mitsubishi 73"
i would suspect your control buttons on your front panel on the set have become shorted. specifically the volume buttom down. This is freezing you control functions. like someone is holding the volume down button all the time. or intermitantly. this cuircit board is on front of the set. I have seen this problem a few times at the shop. The common repair is to replace that button assembly cuircit board. I believe the last time it cost the customer around 85 dollars, but like all things depends on the part and the technician that puts it in.
Apr 21, 2011 | Mitsubishi WD-73827 73" HDTV DLP TV
New batteries only last 1 week.
You need a new remote sent to you. This is the only fix for this issue. Thanks for using fix ya.
Mar 06, 2010 | DISH Network IR Remote Control
My remote seems to eat batteries. I will put new
you need to clean your remote with alcohol.open the remote and clean it with white alcohol,that should do it if not buy a new remote.you can probably get one at partstore.com..good luck.
Mar 01, 2010 | Panasonic EUR501455 Remote Control
Universal remote-rcr3273
Pop the batteries out and use brand new batteries then try the code again. Sometimes its good to let the remote sit for a few hours with no batteries after locking up the codes.
Apr 30, 2008 | Televison & Video
Crazy menu, comes on periodically without using remote
believe it or noT: try replacing all of the switches on the control panel (((power button switch,menu button switch, etc...)))
Oct 27, 2006 | RCA HD52W56 52" Rear Projection HDTV
Toshiba tz50v51 popping sound
Possible problems: * The TV set may be unplugged. * A fuse or circuit breaker may be blown or switched off. * The remote control unit (RCU) may be disabled. Solutions: * Make sure the TV/VCR are plugged in and the wall switch is on. * Check the fuse or circuit breaker. Test the outlet with a lamp. * Replace the RCU's batteries: if this fails exchange the unit.
Jan 18, 2006 | Toshiba TZ50V51 50" Rear Projection...
Televison & Video Logo
140 people viewed this question
Top Televison & Video Experts
