Question about Ford Tractor 8n Front Emblem
My 1950 ford 8 n is slinging oil out the oil breather cap on the side of the block.It just started and its just flying out leaving a big trail of oil.Of course i shut it off.
    Problem Solver:
  • 7 Answers
Sounds like the needle in your carburetor stuck open (from bits of rust and/or other foreign matter in the tank) and it may have drained your gas tank into your crankcase. This is a typical for n-series Ford tractors that have a gravity fed fuel supply. With the needle and seat open, the fuel will flow freely into the carburetor, and if the rubber air intake hose is tight and doesn't allow the fuel to leak out of the carburetor onto the ground, the fuel continues to rise in the carburetor until it enters the intake manifold and then into the engine. The result is a crankcase filled with a mixture of oil and gasoline. When the engine is started, a spewing of the thinned mixture out of the oil filler cap results. This has happened to me when I have failed to shut off for the gas line after running the engine. This shutoff usually located where the gas line comes out of the tank.
If this is the case, don't run the engine until you have drained your crankcase of the oil/gas mixture, clean out the filter canister and refill with good oil and new filter.
An inline gas filter usually solves this problem although I never again trust a needle to not stick open.
Posted on Oct 06, 2011
    Problem Solver:
  • 10 Answers
Sounds like your rings are either stuck or broke. Check the compression, it's probably low or non existant on at least one cylinder. In either case it sounds like a tear down.
Posted on Jul 25, 2010
I got my bonneville home it has a 265 V8 in it the oil pump went out but it didnt sling a rod it froze if i replace the oil pump will it run again . Oil came up inside the breather when she died .
If you seized the engine because of lack of oil, it won't be reliable even if you get it to turn over and start, which is probably not happening.
Feb 01, 2015 | Pontiac Bonneville Cars & Trucks
Tip
Removing a two piece rear main seal
When removing a two piece rear main seal without a sneaky pete, it can be very overwhelming here's how... First unbolt the transmission and slide it back just so that the input shaft is not in the way of taking of a clutch and/ or fly wheel. Then drain all engine oil and remove filter. Next remove the oil pan ( but be careful that none of the old pan gasket gets in the bearing caps, or crankshaft). Then next remove the oil pump( watch the gasket on this also so it doesn't fall down inside the pump pickup tube). Then your going to want to loosen the main baring cap bolts starting from the back of the block then going to the front( not to much just enough to get the pressure of the upper main seal and the crankshaft, but you will need to take the cap bolts on the very back one at the back of the block all the way out thus the bottom rear seal is in it). Remove the bottom rear seal by pulling it out (sometimes using a flat head screwdriver), and then put the new one in by dipping it in fresh oil and simply pushing it in the groove big tab side forward. Next take a screw and a small drill or screwdriver and lightly screw it into one side of the rubber on the seal in sort of a upwards diagnal pattern ( be very careful not to scar the crankshaft). Then grab the screw with the pair of pliers and lightly tap on them with a (small) hammer or the end of a screwdriver. next take the new seal dip it in fresh oil and slide it back in, in a clockwise pattern. Next put the bolts back in the baring cap with the new seal in it , and just snug them down. Then starting with the (R) front bearing cap bolt start tightening them back down to the engines given torque specs in a zig zag pattern tighten every other one all the way back to the back of the block, then back to the front. Put your new seal on the oil pump then bolt this back up to the torque specs listed for that vehicle. Next put on the rear pan gasket (if it's a four piece gasket) then put the front pan gasket on the pan. Next by using small amounts of high temp silicone put a dab on every corner it touches another gasket piece and bolt it back up ( torque specs vary depending on vehicle usually between 12 and 18 foot lbs.) Then bolt the fly wheel and/ or clutch back up. Slide your transmission in the aligned whole and bolt it back up. put on the oil filter and fill it with oil. Start the vehicle and check for leeks, if there's leeks tighten the pan generously and check again. Thank You and I hope this has helped.
on Feb 27, 2010 | Dodge D150 Cars & Trucks
Rear end locked up FOUND a cotter pin in the drain oil Ford 8 n stanard transmission tractor 1950-1960
dismantle it.
inspect all parts. for damage or excessive were.
same with all machines.
inspect and measure parts as the FSM states
FSM is the factory service manual. good luck for 1950
join a tractor form ,we do not have one here.
Jun 18, 2014 | Cars & Trucks
I have a 1975 winnebago from dodge Someone messed with the spark plug wires I need the fireing order and how the wires go on the cap Dodge winnebago 1975 v8
You could have 3 different engines in that rig.
The firing order is 1-8-4-3-6-5-7-2 for most Dodge 8 cyl engines.
And the odd cylinders are on the driver side.
The small block engines ( 318 ) have the distributor in the back, and the big block engines ( 360 440 ) are in the front.
The rotor on the big blocks turn counterclockwise. The dist cap is usaully stamped with cyl 1 as a starting point.
Jul 22, 2013 | Cars & Trucks
Model MDB5601AWW leaking around the side plastic box on left wall inlet that has water hose. What needs done?
-Here sample solution.
-The plastic box or cap you're talking about is the " Breather Cap"
-Check the drain tube from the breather cap to the sink. It must be clean and no block.
-Make sure the breather cap stays in up right. (Straight Up)
-Check the breather cap's Cap . Any big chuck of food waste stuck inside or not. If so the clean it.
-Check the whole breather cap. Any crack...? If so the replace new one.
Good luck ,enjoy and wash every day
Mai
Oct 25, 2017 | Maytag MDB5601AWW Energy Star Built-in...
2001 Iveco 75e15 Cargo engine stalls
Check for oil in the coolent and coolent in the oil, both of these are usually caused by head gasket failare but not always. If these seem ok change the fuel filters, remember there are 3 on these trucks, check the air filter isnt blocked if your not sure leave it out as there expensive and you dont want to throw money away if its not needed yet. Once your sure you have fixed the truck re-fit or replace the air filter. Check the fuel tank for contaminated fuel and if possable check fuel pick up in tank isnt blocked, also try with fuel tank cap removed as the breather may be blocked.
Mar 26, 2012 | Cars & Trucks
How to install distributor wire the order I misted the order
Depending on what engine you have, hear are the firing orders:
Small block 302 or big block 460: 1-5-4-2-6-3-7-8
Small block 351: 1-3-7-2-6-5-4-8
Looking at the engine from the front, cylinder number 1 is at the front on your left. That side is numbered 1-2-3-4. Number 5 cylinder is at the front on your right and the numbering is 5-6-7-8. The distributor spins counterclockwise. Number 1 is usually marked on the cap. If not, no.1 on the cap is about 1 o'clock as you're looking at it from the front. Good luck!
Nov 13, 2010 | 1993 Ford F350
HOW DO YOU CHANGE THE OIL ON A HONDA CRF 150
right under the lever where you switch gears there is a big 24mm nut thats where you drain it,and on the other side of engine by the kick start lever is the cap/dip stick to add new oil, remember use motorcycle oil not car/auto oil,car oil breaks down to fast in the high heat little engines,happy trails,yz-maniac......
Jun 10, 2010 | 2003 Honda CRF 150 F
Where do i put oil in my 1978 Chevy C10 pickup
If there's no oil cap directly on one of the valve covers (it may have a breather hose attached which connects to the breather element in the breather pan), then some models require adding oil through the dipstick. If this is the case, there should be a cap type dipstick instead of the standard "hook". There are 6 different motors (8 including variations) for your truck so no manual has the exact location of the oil cap. Best of luck and hope I answered your question.
Greg
Nov 04, 2009 | 1978 Chevrolet C1500
Whats the firing order for a 5.0 Ford explorer 1994, 1-3-7-2-6-5-4-8, but which is which on the block? And also, how are they numbered on the distributor?
i can answer 1. on the block firing order is odd #'s left side,starting at front- 1,3,5,7, even #'s on right side- 2,4,6,8, reinstall wires one at a time from old cap to new cap
Oct 30, 2009 | 1994 Ford Explorer Limited
Ford Tractor 8n Front Emblem Logo
230 people viewed this question
Top Ford Garden Experts
Dennis Key
Dennis Key
fordexpert
donald boissonneault
Are you a Ford Garden Expert? Answer questions, earn points and help others
