It is quite possible that you do
It seems every one on here doesn't realize that they need to have the salt water test kit that reads #;s not color
If you were to close to minimum then you will need more salt
What you need to do is get the strips and test
you need to be as close to 3000ppm as possible
lower than 2800ppm and you will not be generating enough chlorine
any higher than 3500ppm and you could get cloudy,taste bad, and trigger an alarm for high salt
Bottom line is you can not guess at the salt content!
