Question about Samsung Televison & Video
23'' LCD TV
I have a Samsung LN-S2341W, it turns on but there is no image only the background light. I press the menu or volume buttons and nothing comes out on screen. No volume as well. Can someone please help me. Or tell me what part to change
  • 11,361 Answers
You need to do some voltages checking first to narrow down the problem, right now the backlight is working as you have said, but it sounds like the T-CON board may have failed or the 12vdc feeding it is not working, the same 12vd is more likely to be for the sound amplifier also.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Posted on Jul 16, 2010
Samsung LN-S2341W Picture Is Black and White
color circuit is out, try banging the set on the frame with the palm of your hand to see if color comes on or fluctuates, if so you have a loose component which is only fixable by you if you are really knowledgeable about the inside of a TV
Apr 28, 2017 | Samsung LN-S2341W 23 in. HDTV-Ready LCD...
I need to re tune my samsung tv but have no remote any ideas?
you can always use the button on your Tv itself.
ie menu = Menu
Channel up/down = take you up and down
volume = goes left and right.
follow these steps
Menu,
channel down button to CHANNEL
press the volume button along
channel down button to AUTO STORE
press the volume button to Start the scan.
right now you have your telly tuned in. What you could do it get an old sky remote off a friend/ neighbour. or buy from argos etc ( a lot cheaper then getting a replacement samsung one)
press the following buttons on the sky remote to program it to work with your samsung tv.
TV,
RED + SELECT
TV.
0060
try the volume if this works press SELECT to save this code if it doesnt press Tv then try the volume again. repeat this step until the volume works your telly. once it doest dont forget to press the SELECT button to save.
Now you will be able to change your volume use the number keys. if you also press the HELP button on the sky remote this will also change your AV / SOURCE I hope this post helps you out. When it does please leave a thumbs up for me Please
Cheers Little Dish Fitter
Sep 21, 2009 | Samsung LN-S3251D 32 in. LCD HDTV
Samsung hdtv wont turn on
try to turn on pusshing the power on button, if it works then your remote is bad. if it doesn't then you have a power supply problem . fuse, .....But know that some times, you don't have power in your outlet, your power cable is bad. check all that
Sep 12, 2009 | Samsung LN-S2341W 23 in. HDTV-Ready LCD...
32 Inch Brand new Samsung 32" LCD showing subtitles / no volume??
I had a similar problem, checked all of the TV's control settings only to find out that my cable box had an independent "mute" function that automatically turned on the closed captions when activated. Once I found that and turned it off, all was fine.
Mar 18, 2009 | Samsung LN-R237W 23 in. LCD Television
Menu Trouble
perhaps the volume down button on the TV is stuck. It could be either physically stuck, or the electronic logic could be messed up. Just to rule out a problem with the remote, take the batteries out of it and then adjust the volume at the TV and see what happens.
Sep 07, 2008 | Samsung LN-S4051D 40 in. LCD Television
Samsung LCD Flat Screen TV LN-S2651D - Volume Problem
I lived with it for about six weeks, then took the back off the TV. Just now it seems to be fixed, but I don't know if it will last.
I disconnected the wire leading to the channel up/down, volume up/down and source board, turned on the tv, turned it back off, reconnected the cable, and everything seems fine now.
Aug 24, 2008 | Samsung LN-S2651D 26 in. LCD Television
Samsung 37
It sounds like your TV is set at Shop Mode. To veify that turn on your TV and press the info button on your remote, some info will be displayed, If Shop Mode appear please follow the next steps...
In order to change that mode turn on your tv, press the volume key (either one) on your front or side panel (Depends of the model you have) the volume bar will appear, once this happend press the menu key on the front or side panel and hold it for like 7 seconds, "Dynamic" symbol will appear at your screen this means that you are not longer at Shop mode. You can double check by pressing info button at your remote
Regards
Jan 14, 2008 | Samsung LN-T4665F 46 in. LCD Television
Black end "stripes" on non-HD images on LN-2341W
Arte you using a cable provider? if so you should be able to adjust it to a wide screen or stretch, most cable providers are supposed to apply the settings when installing the box, so that the screen will auto fit your set, otherwise you will get image retention
Apr 02, 2007 | Samsung LN-S2341W 23 in. HDTV-Ready LCD...
Remote control
There could be a cable that is not completely seated inside the set, there may be a software upgrade also that will fix it.
Oct 24, 2006 | Samsung LN-R328W 32 in. HD-Ready LCD...
Televison & Video Logo
93 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
