Question about SanDisk Sansa e250 MP3 Player
My sons PSP has been used 4 times and know it does not turn on?
    Problem Solver:
  • 7 Answers
Does the green light still come on?
Posted on Jun 06, 2008
Cant save game data to my sons psp
Hi mr_bagpuss,
The memory card of your PSP needs to be checked. Since you can't save data andgame on it, it's showing that the memory is not properly connected, intact orworst case defective. You can still diagnose the problem by doing these steps:
1. Turn off the PSP.
2. Now take the memory stick out then check if pins are clean.
3. If it continues not to work after checking the pin, try to check the memorycard using your PC. You can simply open the card via card reader.
4. If your PC cannot detect the memory card, it means that the memory card isnow defective. Now it's time for you to buy a new memory card.
Hope it helps.
Thank you for using FixYa.
Feb 03, 2011 | Sony PlayStation Portable (PSP) Console
My son is stuck on the 2nd level of Ben 10 and he cant get through the door that opens when you stand on the access plate. how do we do it
I think I can help. When you get to the electronic barrier,use SPIDERMONKEY to get on top of a pillar. Then turn into BIGCHILL to leap across the pillars.
!!!WARNING!!! Get a friend to help you beat the boss: MeCh dRaGoN!!!
(scale of five)
MECH DRAGON
toughness:4
strength:5
range:5
melee:4
speed:2
I think your best bet is SWAMPFIRE!!
Let me know if this helps..
Feb 05, 2010 | AFA Ben 10: Protector of Earth for PSP
My son sony psp the green light comes on but has nothin on screen then turns itsself off again does this after it was updated
hi your psp is bricked u need to flash it will need a pandoras battery and magic memory go here
http://www.psp-hacks.com/forums/f133/installing-and-using-despertar-del-cementerio-t202045/ you will need a modded psp tho or check the site 4 another way if u can get hold of a modded psp good luck
Jul 26, 2009 | Sony PlayStation Portable (PSP) Console
Psp will not run games or turn on
its because the psp version where change that's why the psp stops working on games only psp version's with m33 can play download games and other might depend on your umd games...so i suggest that you downgrade your psp to the original version of the psp that you have so your son can play the games that he want. hope it helped.. send me a message for more concerns...ty
Apr 09, 2009 | Sony PlayStation Portable (PSP) Slim...
Im very upset!!
Go to System Settings under Settings in the Home Menu. Click Restore Default Settings. The password should then be 0000 or 9999
Good Luck
Dec 29, 2008 | Sony PlayStation Portable (PSP) Console
Psp will not turn on unless the cord is plugged in
ok your son's psp has malfunctioned and instead of trying to charge the batteries it drained them. i would recomend for u to get ur son a new psp and buy a another battery for your daughter.
there is a newer battery being sold that you put AA batteries inside
to make it work. check out your local best buy and wal*mart
Dec 23, 2008 | Sony PlayStation Portable (PSP) Slim...
Not reading umd
your son probably dropped his PSP at the time and the UMD drive broke or if your son says he didnt drop it you can get a cutip and softly clean your UMD reader the little bubble sorta in your PSP be carful while doing that
Jul 15, 2008 | Sony PlayStation Portable (PSP) Console
Son interrupted a firm ware update now PSP won't turn on
my investigations suggest that your son has "bricked" the PSP. Basically the memory that stores the firmware is corrupt and apparently only a main board replacement will fix the issue.
A google search found THIS. I have no affiliation with them and have never used them though.. might be worth a call at least??
Jul 02, 2008 | Sony PlayStation Portable (PSP) Console
Sony psp problem
Remove the battery for 15 minutes, connect the AC Adapter and install the battery again.
It that doesn't work, remove the battery again, wait 15 minutes, install it and plug the AC Adapter.
It's a weird problem but in my PSP i get around that way.
Feb 07, 2008 | Sony PlayStation Portable (PSP) Console
PSP won't turn on
You can try a hard reset. Do this hold the power switch in the upward position for over 10 seconds. This will cause the machine to reboot. Leave it alone for a few minutes then try switching it back on. You may have to flick the switch on twice to start her up again. If it still has a hard time try changing the battery for the one in your sons machine. MAKE SURE that all apps etc are closed on the PSP first and do the hard reset BEFORE you remove the battery on BOTH machines. Ensure PSP is OFF before removing battery. It is possible the battery has been overcharged or just given up. If the console operates with the other battery you know you need get a fresh one. Consider getting a high power one for extended life. Let us know how you get on. May have more info for you.
Jul 03, 2007 | Sony PlayStation Portable (PSP) Console
SanDisk Sansa e250 MP3 Player Logo
14 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
SmartAviator
SmartAviator
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
