Question about Poulan/Weed Eater No. Te475 952711797 17" Le Gas Trimmer/Edger
Dont know how the fuel lines run on polan pro 131
Lines were missing i have new fuel lines but dont know which port on carb is intake and which is return
I have that same gas trimmer and i had to replace the fuel lines for it becuase it was leaking very badly.
ok so first use the new fuel line put that on through the fuel tank connect that with the gas and oil filter inside the tank if their is non in the tank then you will need to buy a new oil and gas filter. then take the fuel line you put in the tank connect that with the primmer connect it only to the top connection of the primmer now that another fuel line connect the bottom of the primmer and connect it with the fuel line to the back of the carburetor. now take another fuel line connect the to the fuel tank and put it direcly to the front of the carburetor. oh one more thing make shore the fuel lines arnt to long and not to short. becuase it can get hard to put the trimmer back together.
Posted on Aug 21, 2010
  • 15,935 Answers
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Aug 13, 2010
4 Suggested Answers
  • 52 Answers
SOURCE: String trimmer, fuel lines disintegrated, I need routing.
The Walbro has two connections on it for the fuel line. My Walbro has one connection on the side of the idle screw and main fuel adjusting screw. This connection hooks up to the suction side of the primer bulb. Usually the shorter stem. (You actually **** fuel through the carb instead of pushing it through.) On the other side of the carb is the other hook up. It draws fuel from the tank. This line will connect to the side of the tank that has the filter. The other side of the tank is your return and it hooks to the other connection on the primer bulb. Usually the longer stem.
Posted on Apr 19, 2010
rycgl
  • 1545 Answers
SOURCE: have a poulan pro ppb350 31ccweed eater runs short
This is an ongoing issue for users, and rightfully so. Small diameter line out of fuel tank (has filter in-tank on end) connects to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then pushes any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Years ago on 2-stroke trimmers, primers were not even used,...you choked the carb with a slide lever and gravity let fuel enter the carb from above...a few pulls, a "pop"...slide it off of choke and away you went.
If the purge/primer bulb is on top of the carb...small line from carb body to small hole in tank with filter. Larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where the line is held in place with a nylon nipple connector that keeps the line from pulling out of the fuel tank.
Posted on Sep 11, 2010
SOURCE: Polan P1500 trimmer ideles great until i press throttle and stall
Yep...I too just bought the p1500 from Amazon (got a full refund and was told to dispose of trimmer) and have the exact same problem, it starts, I even let it warm up for a while, then press the throttle lever and it bogs and wants to die. Well we know that is why it was so cheap. I liked it because it was small and ligh weight. I was told to take it to the nearest dealer (with receipt) to have it fixed for free...but the dealer laughed and asked, who said that they would do it free! So Now I will screw with it and see what I can do. If I get it working properly, I will let you know what I did....If you don't hear from me again, that means I tossed it in the garbage and bought a real one.
Posted on May 27, 2011
Only runs with choke on
Hi, Jeff and the usual suspects are:
1. Fuel cap or fuel tank is not venting properly.
2. Fuel filter clogged.
3. Fuel line pinched or kinked.
4. Float needle and seat sticking.
5. Float level too low.
6. Carburetor bowl vent line clogged/blocked/pinched.
7. Idle adjusting ***** set too low.
8. Air/fuel mixture ***** set too lean.
9. Idle port, transfer ports, slow air jet clogged.
10. Slow fuel jet clogged.
For more information about your issue and valuable "Free" downloads that you will need please Click on the links below. Good luck and have a nice day.
What could be wrong if bike will only run on choke
Only Runs When Choke is On
Bike only runs with choke on Intake Jetting Fuel Injection
Oakys Garage Carb clean Pilot Jet clogged Won run without Choke Carbs 101
Apr 05, 2016 | Red Motorcycles
Trouble shoot polan pro chainsaw
Use a cheap spark checker to check for spark. To check for fuel issue, squirt some carb cleaner down carb and see if it hits. If it does, you know you have spark and the problem is in the fuel supply.
Jun 16, 2014 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I need the fuel line routing diagram for a Craftsman Model No. 358.791510 Weedwacker 32cc/1.9 cu.in. 2-cycle
hello sir,routing fuel line for craftsman,homelite,ryobi,hedge and line trimmers,fuel tank under engine, looking at machine from rear, shall fuel line on left with filter attached goes to bottom port of carb, fuel line from right side coming out of tank with inside tip attached goes to bottom port of primmer bulb,top line on primmer bulb goes to top port of carb, fuel tank under engine,fuel line routing,looking at machine from left side, left fuel line coming out of tank(drain back only) goes to right side small port of primmer bulb, left side larger fuel line from primmer bulb to top port of carb, fuel line coming out of tank (larger line) on the right side with filter attached goes to bottom port of carb, when replacing fuel line it is very important to use the same ID and OD line the homelite takes a special line that is black in color and a bigger size,the bigger line is ID .08-OD140 small line ID3/32 X 3/16.when the lines dissolve small pieces will get in the carb clogging small passages and screen,it is advisable that you clean out carb,and use a new filter.hope this helps,any comments welcome,thank you. if the filter has broken off of the line half way that is where you will run out of fuel, ``
Jan 18, 2012 | Garden
Fuel line routing for craftsman chainsaw 358.350370
hello sir,routing fuel line for craftsman,homelite,ryobi,hedge and line trimmers,fuel tank under engine, looking at machine from rear, shall fuel line on left with filter attached goes to bottom port of carb, fuel line from right side coming out of tank with inside tip attached goes to bottom port of primmer bulb,top line on primmer bulb goes to top port of carb, fuel tank under engine,fuel line routing,looking at machine from left side, left fuel line coming out of tank(drain back only) goes to right side small port of primmer bulb, left side larger fuel line from primmer bulb to top port of carb, fuel line coming out of tank (larger line) on the right side with filter attached goes to bottom port of carb, when replacing fuel line it is very important to use the same ID and OD line the homelite takes a special line that is black in color and a bigger size,the bigger line is ID .08-OD140 small line ID3/32 X 3/16.when the lines dissolve small pieces will get in the carb clogging small passages and screen,it is advisable that you clean out carb,and use a new filter.hope this helps,any comments welcome,thank you. if the filter has broken off of the line half way that is where you will run out of fuel, hh
Jan 11, 2012 | Garden
My polan saw will start but boggs when given gas if you pump the throttle it will run at full throttle buy once it idles down it stalls
This is fuel starvation, replace the fuel filter in the tank, check the fuel hose up to the carb for signs of leaks, or cracks, if the carb has no anti tamper screws, screw the L screw out 1/4 turn to richen the mixture, if the carb has anti tamper screws you will need to get the special tool to adjust them.
Sep 15, 2011 | Poulan Pro Chain Saw 46cc 20"
Have a 1980 suzuki gs550l w/o tank, got a new tank but dont know which lines go together theres four lines on the carb
there is a small port on top of the second carb on the right, that goes to the small port on the fuel petcock mounted to the tank. The main fuel supply (larger port on tank) goes to the bottom fuel supply rail with the only carb port on that rail. The upper two ports between #1 & #2 carb and between #3 & #4 carbs are vents and those hoses get plumbed down under the air cleaner, careful not to pinch the vent hoses or the bowls will not fill up with gas. This is the same for an automatic petcock or a manual one.
Aug 15, 2010 | 1980 Suzuki Gs 550 L
Have polan md 1950 14'' changed fuel primer pump and lines plus gas line. now it only runs for short time and stops. only runs as long as I keep pumping primer
Sounds like the diagphram pump in the carb might be stuck, been dried out or has a hole in it. Im not to certian what carb is on it but some have a line that runs from the carb to the crank case might check for that.
Nov 29, 2009 | Garden
McCulloch Chainsaw carb not getting fuel
This is the same problem I have with a Mac 3200. I have: (1) A line from the primer bulb to the front port on the carburator. (2) line from fuel tank, with attached fuel filter, to the other primer bulb port. (3) Line from port on back of carb. to ????. I thought it must be a pulse line, but not certain, and don't know where to run it to. Please let me know when you find out.
Aug 13, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Cant figure out where fuel lines go on mccullogh chain saw
Fuel lines: one comes from the tank...has a filter in side the tank...runs up to the intake of the carb... you can tell by hooking up the lines to the carb, and put one into a gas supply... press the prime bulb... if it pulls gas, thats the one to hook into the tank...if not it 's the other... there should only be two lines a fuel supply and a return pressure line. Clean the air filter while you've got it apart....
k
Jul 01, 2009 | McCulloch 26cc Gas Blower Mcb3208
Chainsaw runs, but dies when given gas.
adjust the gas and air on the two little screws on the carborator
Dec 26, 2008 | Poulan Pro Chain Saw 46cc 20"
Poulan/Weed Eater No. Te475 952711797 17" Le Gas Trimmer/Edger Logo
207 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
