Question about Samsung CLP-600N Laser Printer
Samsung 600N transfer belt
Hiya,
Here's a good one - I received the "replace transfer belt" message and I did youst that (bought a new one). Then I installed and I still get the same message.
Any comments?
Stephen
laser-optic@pacbell.net
  • lasertrak May 01, 2008
    Sorry, not the problem. I took it to an authorized shop. They inserted
    their original Samsung cartridges and it worked. Apparently, there is
    nothing wrong with the [new] transfer belt. The unit just doesn't like
    the chips on my toner refill kit. I'll try removing the new chips and
    replacing with the original and post a note here.
    It seems Samsung trys very hard to rape you on every little part that
    wears out in a few months and if you resist, they lock you up and try
    again. Oooo, I'm still sore; better wait 'til this weekend to give it a
    try.
I fought the "replace transfer belt" message for quite awhile. Then I finally realized I was trying to close the toner cartridge door BEFORE I closed the lid above it. (The printer was close to a wall so I couldn't see the "open and close in this sequence" signs on the cartridge door.) Once I closed them in the proper order, I stopped seeing that message. Janet
Posted on May 01, 2008
My printer can`t print and shows me to 'Check the transfer belt'
Your printer monitors the life of your transfer belt. When the transfer belt reaches the end of its
life, the printer displays
80 Belt Exhausted. This message indicates it is time for you to
replace the transfer belt. For best print quality, make sure you replace the transfer belt when
80 Belt Life Warning.
Press
Go to clear the message. The Supplies message appears on the second line of the
display to remind you that supplies need attention. You can open the Supplies Menu to see
80 Belt Exhausted
or 80 Belt Life Warning messages.
The printer continues to display the
Supplies message until you replace the transfer belt. To
replace the transfer belt, use the following steps or the instruction sheet supplied with the
transfer belt.
Nov 26, 2012 | Samsung CLP-610 Series
I want to transfer data from a floppy disc to a cd
Your computer must have a floppy disk drive in order to read data. You have to buy one or borrow computer (from your friend maybe).
Oct 18, 2011 | Samsung CLP-600N Laser Printer
We are receiving a replace transfer belt notice on our Samsung CLP610ND. Is there a way to reset without replacing?
no it cannot be reset without replacing. the transfer belt has done its life thats why the message is appearing on the screen to replace it. the printer can still be used. the transfer belt is a bit expensive a s well.
Jan 04, 2011 | Office Equipment & Supplies
Samsung CLP-600N displays message - engine fuser low heat error. Machine is out of warranty.
Disassemble fuser and inspect thermistor, thermostat and heat lamp. Replace broken part.
Aug 10, 2010 | Samsung CLP-600N Laser Printer
SAMSUNG CLP600 COLOUR QUALITY
I've had the same problem with color problems, especially with cyan (blue). I have found that many of the toner cartridges I receive are defective. When I receive a new one, I try it out for a few pages. If the color isn't perfect I return the cartridge and get a replacement. After 1-2 tries, I get one that puts down good color. (A really bad solution I know, but it does get the job done.)
Apr 01, 2009 | Samsung CLP-600N Laser Printer
Invalid transfer belt error on Samaung CLP 600N
This error can arise when the door on the right-hand side of the printer, the part you open in order to replace the toner cartridges, is not correctly closed. Close the top right-hand section first and then close the door on the right-hand side firmly (slamming it if necessary) and then check that all edges look correctly aligned. That should solve the problem. Incorrect shutting of these parts has always been the cause of this error on our Samsung CLP-600N laser printers and we have several of them.
Mar 23, 2009 | Samsung CLP-600N Laser Printer
Transfer Belt vs Transfer Roller
Dear Friends:
I have a same problem after replacing both transfer belt and drum for Samsung CLP-510.
Can you help me?
An
Aug 20, 2008 | Samsung CLP-550 Laser Printer
Samsung CLP600 - wants me to install a transfer belt
"install transfer belt" message" appeared right after black toner was relpaced with a non samsung toner(new chip too)--installation of new transfer belt did not solve problem--- i went back and reinstalled the original samsung chip into the toner cartridge---the "install transfer belt" message is gone and the printer works but has a "low toner" message----i guess i learned my lesson the hard way---anyone in the market for a new transfer belt???........wj
Mar 31, 2008 | Samsung CLP-600N Laser Printer
Samsung CLP-600N Laser Printer Logo
291 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
