Question about Weber Q Grill
Why is propane shooting out of the small whole on the regulator when I put a new tank on. Do I need a new regulator?
  • 700 Answers
Shut the valve on the bottle and re-assemble whole system, this usually happend when regulator is not screwed in properly.
another reason can be that it is too hot weather and bottle was in full sun, this increase greatly internal pressure and regulator was just venting it.
if none of the above worked or is true, then yes, replace regulator. UNDER NO CIRCUMSTANCES DIS-ASSEMBLE THE REGULATOR!!!
Posted on Jul 28, 2010
Connected my Coleman propane stove to a tower connected to a 20lb tank. The stove regulator started expelling propane through a small hole at the top of the regulator knob. Is there a way to fix it?
no there are no repair for regulator safety regs do not permit it. what is this tower can you go from propane tank to stove? type in search engine 2 stage regulator for propane tank. There be several returns. I personally would not buy bottom end regulator.
Amazon com Camco 59333 Horizontal Two Stage Propane Regulator with POL...
Aug 09, 2018 | Cars & Trucks
Fireplace propane smell
I would change the reg for a new one .You should only get a small hiss from the breather hole .
Oct 23, 2017 | Heating & Cooling
I purchased a used Masterbuilt veranda gas grill. The gas regulator fits a small propane tank. Is it possible to replace the regulator so it will fit a large sized propane tank?
Yes, it can be converted to accept a 20 Lb LP grill tan. Contact Masterbuilt Customer Service
1.800.489.1581 to obtain the new hose/regulator assembly.
Hope this helped you and Happy Grilling!
Jul 22, 2011 | Masterbuilt SBMPG3 Veranda Steel Grill
Model 720-0164 bbq low propane to burners now no propane to burners,,,new bottle.. how do i trouble shoot to see if it is the regulator
What you have is a classic symptom of a bad regulator. If no gas is going fromt he new tank to the burners, you can bet it is the regulator. No real way to test it once it stops working all together. As it is going bad, the flames on the burners will get smaller as each buner lights.
Mar 12, 2011 | Jenn-Air Grilling
Genesis Silver B Grill: grill won't heat past 350 or so. put a new regulat...
An odd thing with many propane gas grills is how the regulator functions. If the tank is opened too fast the regulator over-adjusts and delivers no gas. Try this: Turn tank off and open all burner controls. This should clear the line of any gas. Close burner controls and open tank very slow. Now lite and temp should go up.
May 17, 2010 | Weber Genesis Silver B Grill
Weber grill three burner. New tank of propane but
The new style2_bing.gif OPD valves have a small brass ring located in the female fitting on the LP tank. Over time this ring can work loose and then it does not allow the male fitting to fully depress the OPD valve thus reducing your gas flow
Using a small flat bladed screw driver tighten the small brass ring This should solve your problem
IF not you might want to remove the cap (white) on your regulator and try slowly adjusting the regulator, make small adjustments and try the BBQ My Weber if I set the front and back burners to MED I get right at 350 degrees in 60 degree outdoor temps. Adjusting the regulator will take some time to get it right but If it is not your tank it is most likely your regulator out of adjustment
Mar 29, 2010 | Weber Genesis Silver B Grill
Propane not reaching appliances i.e. furnace, water heater and cook stove. tanks are full, what could be the cause.
Turn the tanks off outside and take the regulator off the tanks and the main line and bring it inside and thaw it out the regulator is frozen and won't open. Thaw it out and put it back on and it should work if not you may need a new regulator.
Feb 07, 2010 | Coleman Propane Forced Air Heater...
Cannot conect regulator to small 16.4 oz propane tank
It must have some sort of packing spacer you need to remove from the hose to attach the tank. LOL
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 11, 2009 | Coleman Roadtrip Grill LXE 9949-750
Fine for about 2 minutes, then pops and sputters, tried new tank.
The filter in the regulator is most likely clogged or just about. It is located inside the small nipple that goes directly into the bottle. It looks like brass shavings. You MIGHT be able to clean it with carburator cleaner but usually, they need replaced. The slightest bit of moisture getting in will do this.
Mar 28, 2009 | Mr. Heater Model MH12TS - Single Tank-top...
Weber Q Grill Logo
221 people viewed this question
Top Weber Grilling Experts
Paul Carew
Marvin
Marvin
Joseph Hoffmann
Are you a Weber Grilling Expert? Answer questions, earn points and help others
