Question about Nikon Coolpix L1 Digital Camera
When i turn on the camera but its take few time to take ashot
  • 4 Answers
That doesent mean any thing
Posted on Jul 16, 2010
Fixing security signal ligting on dashboard
I'm taking ashot in the dark here, but I'm guessing you didn't unhook the battery before replacing the pump. If not, take the negative battery cable off, wait a couple seconds and re-attach it. You just need to reset the security system. Lights should go away. Hope this helps.
Jul 14, 2014 | 2004 Chevrolet TrailBlazer
Pentax Optio S10 - Turning on problem
What kind of shape is your battery in?...old, been charged many times, needs charged, dirty contacts on the battery or inside the camera?
Sep 17, 2009 | Pentax Optio S10 Digital Camera
Turn camera on, lens goes in and out a few times then tells you to turn off then on again and can't shoot picture
can of cpomkp-ressed air or compressor access is needed to blow around the lens area.
Smack the camera firmly into the palm of your hand a few times, more air , more slaps. keep checking if it is again free by turning on again, eventually this will free the dirt from the mechanism and it will function again. This trick was passed onto me by a sony tech and they chatge $180 to do just that
Aug 11, 2009 | Sony Cyber-shot DSC-W80 Digital Camera
How to fix a popped off lens
Try turning the camera on and off a few times. If it did not go in while turning it off gentely push the lense in. You might have to try this a few times. If the lense retracts, but not all the way in, push the lense a litte harder in. When the lense is 100% retracted, turn the camera back on, the lense should pop off. Your lense is probaly dirty. Need to clean it and keep it clean always.
Good luck
Jun 08, 2009 | Kodak Easyshare M753 Digital Camera
Sony cyber shot dsc-n2
There could be two things causing this problem.
1- some dirt somehow got on the outside of side of the lense. So the lense could not fully retract or open out. As a result you can take any picture. If the lense comes out even a little bit, try to pull it out NOT too hard a few times. If it does not retract, turn the camera off and push the lense in (up and down) NOT too hard foe a few times. If the camera opened up 100% or retracted 100%, your camera should be back to normal.
2- If you dropped the camera, some mechanical part of the lense is broken or dislocated or the cable may have come loose. In this case you need to take out the lense from the camera and inpect it for broken pieces or loose cable. clean the outside of the lense and push the lense in and out a few times. Put the lense back on and your camera would be back to normal.
Good luck!!!!!!
May 14, 2009 | Sony Cyber-shot DSC-N2 Digital Camera
In camera or video mode it says turn the power off and on again
The problem is
1- some dirt somehow got on the outside of the lense. After it was retracted fully in, it prevents the camera from opening again. When you turn it on, if it opens a little bit, try to pull it out NOT too hard and let go a few times. If it opened, clear the outside of the lense. Your camera should be back to normal.
If the lense does not retract, but goes up and down when you turn it on or off, Clean the sides of the lense and while turning the camera off push the lense in NOT too hard for a few times. If it retrected 100% or most of the way inn, push the in a little harder untill it is 100% retracted in. Now your camera should be back to normal. 2- If you droped the camera, you probably damaged or dislocated a mechanical part of the lense. You may have to take out the lense by unscrewing it and inspect it for damaged parts or disconnected cable. Make sure clean the lense and test it by moving it in and out a few times, before puting it back on the camera.
Good luck!!!!!!!
Apr 14, 2009 | Sony Cyber-shot DSC-N2 Digital Camera
My samsung L730 lense is stuck
i have the same problem with these camera. to get it fixed just take out the battery wait for a few sec and put the battery back on, then switch the camera on. for the lens just gently move/force the lens to open, then turn off the camera wait for a few seconds then turn on the camera back on see what happens. and if still persist keep doing it till gets back to normal.
this sometimes happens to my camera from time to time i think it just its wear and tear.
one more problem with this camera is that it'll go blurr, just do the basic turn off or take out the battery wait a few sec and then turn it back on.
hope this will help u.
Nov 08, 2008 | Samsung Digimax L730 Digital Camera
Lens coming out and going back in when turned on
Lightly hit your camera in you palm a few times. I has the same problem with my DSC-W55 and it works now!
Oct 12, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Nikon Coolpix L1 Digital Camera Logo
22 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
