Question about Garden
I am having trouble getting the "pick up" tube for soap/cleaner to draw from a bucket
Remove the hose and the fitting and clean with a toothpick or paperclip. The soap has a tendency to dry up in the fitting and prevent soap from being sucked into the tube. Be very careful when removing the fitting. On some units there is a small spring and ball bearing that are needed (Troybilt 2200)
Posted on Jul 16, 2010
Will not siphon
This model pressure washer will only siphon from the soap dispenser when you have the low-pressure nozzle attached and then will only sort of dribble out the suds. Good for sudsing, but no good for cleaning. You'll have to suds 1st then change to a highwe pressure spray nozzle to perform the actual cleaning. If it won't siphon with the low pressure nozzle either, then check for a blockage (old, dried soap) in the suction line tubing. Hope this helps!!
Oct 19, 2014 | Dewalt Pressure Washer. 3000 PSI 2.5 GPM...
How do you use additive hose with pressure washer
In order to get the system to pick up whatever solution you have the pickup tube in, you have to use the black, soap tip on the spray wand. If you use any of the high pressure tips, usually red, yellow, white or green, there will be too much pressure in the line for the siphon system to work properly. There is no way to control how fast the system picks up the cleaning solution, so if it's using your solution too fast, dilute it with water in a five-gallon bucket so it doesn't go through your product so fast. After you use the soap tip to soak down whatever you're cleaning, switch to the appropriate pressure tip and rinse everything down.
Jul 04, 2012 | Campbell Hausfeld Garden
Clear rubber hose is off machine-what does it do? I've lost the owner's manual and cannot remember how to use the electric washer. Does that short clear rubber hose with a fine filter on one end...
The clear hose with a filter on the end is a cleaning solution pick-up tube. It attaches to the washer near where the pressure hose attaches to the machine. There is ususally a barbed hose fitting for it to slip over. If you are using the black, low pressure, soap tip the hose will allow the machine to pick up cleaning solution either from a bucket or straight from the bottle, mix it in the water and spray it out on whatever you are cleaning. It will not work if you have one of the high pressure tips on the wand. They are usually red, yellow, white or green.
Jul 06, 2011 | Karcher 1550PSI Pressure Washer
It will not **** in cleaner soap
Your heading is for chain saws but going by your problem I'll assume you are having problems with your pressure washer. The most likely reason your washer won't draw the soap into the water stream is you are using one of the high pressure tips, usually red, white or yellow. The only way the soap system will work is if you use the low pressure, soap tip which is black. Another thing to check is the soap line and pickup filter to make sure they are clear and allow the solution to be picked up.
Apr 14, 2011 | Garden
My k'archer electric pressure cleaner doesn't draw the detergent when flipping to mix, what am i doing wrong?
intake nozzel might be pluged at pump pull tube and clean with paper clip you cant **** soap in pressure mode hole in tubing
Jan 18, 2011 | Karcher Garden
Sears 2600 psi power washer
there should be a low presure tip for dispensing wash cleaner or if you have an adjustable wand turn it to low presure setting also make sure the suction tube is open some have a adjustable filter...good luck
Jul 25, 2010 | Briggs & Stratton 2200 PSI Gas Pressure...
How do you use the tube for the detergent
Put the tube into a bucket with detergent that is recommended for your machine then put the wand into low pressure mode and if it has a valve where the hose connects turn the valve to the on position and pull trigger and watch to see if soap starts being drawn out of the soap bottle if it starts pulling the soap up continue to allow it to flow till you get your part soaked with soap, then let it set for 10 minutes then hit it with high pressure hose to wash off, when it is clean then put it on low pressure and pull hose out of bucket with soap and then allow the soap to be pulled out of tube and until there is no longer any soap coming out then store the hose for use later. some machines have a control valve at the end of the wand by turning the tip or pushing tip in or pulling it out some models requires you to use quick disconnect fan tips to lower pressure to use soap.
Jun 15, 2010 | Karcher G3025OH Pressure Washer
Very little pressure
INFO:
Sound like its drawing air through the soap pick up tube.
RECOMENDATION:
Pench off soap pick up tube.
Hope this tip helps.
r/
David
Mar 10, 2010 | Psi Blue Max 2200 High Pressure Gas Power...
Karcher G 2600 ph
Dear johnny_river,
In general there are many causes why soap is not sucked. In a domestic and various other machines the soap is only sucked in low pressure. So one thing you can try is remove the nozzle or the complete lance from your gun. This will give a low pressure. If you attach a pipe directly to the machine soap inlet, and soap is not sucked, than the soap valve is "stuck closed" with soap. It is important that one must work with fresh water after using soap. This to flash the system from any soap left. So in a few words attach a pipe directly to the nipple at the machine and use low pressure. Important , you do not have to use soap to test....use fresh water. If this works( which it should)...than service the flow control tap or change it altogether.
Regards,
fulltech.
Apr 09, 2009 | Karcher 2500 PSI Pressure Washer
Garden Logo
283 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
