Question about Wolf Range CHR-2-1829-FT45 Gas Kitchen Range
Have a wolf range and the spark generator which lights the burners will not stop clicking even when i turn the stove off. if I turn on the middle back burner it will stop clicking. how do i stop this?
  • Wolf Range Master
  • 8,220 Answers
Remove the knobs and skirts and a few screws. Remove the panel and locate the spark switch that is bad by removing one wire at a time till the ticking stops. have a wolf range and the spark generator which - dfc80e7.jpg
Posted on Jul 16, 2010
Whenever i light the gas top wolf range, the ignighters on other burners keep firing
The electrode (spark plug) for that burner is not telling the spark module the burner is lit and go ahead and turn off the spark. That electrode and the wiring on it need to be replaced,from that burner back to the spark module.
I hope this helps you to repair the problem with you stove,
Gene
Aug 11, 2011 | Wolf Range fs-0-27-ft36 Gas Kitchen Range
I have a Wolf gourmet 30" stove. it's about 10
Interesting, I'm looking for a solution to a similar issue. Our new (7 month old) 30'' Wolf Range has this issue. When both front burners are light, the back burner's electronic starter begins to click, but only when you put a pan on the front left burner. I believe the iron/steel in the pan is causing a magnetic field thats starting the rear burner to go off.. just don't know.. will report back after the repair person comes.
Jan 22, 2011 | Wolf Range 18 in. SPR-100 Gas Cooktop
Stove top burner ignitors will not turn off
This tip I wrote to help people with the problem of the spark not shutting off...the clicking non-stop is a common problem.
Gas Range2_bing.gif Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
Apr 30, 2010 | KitchenAid KGST307 Gas Kitchen Range
If I turn the gas burner on above medium, it clicks and never stops clicking until I turn it down or off.
you may be turning it up unlil it lights. Try taking off one of the knobs and turn it over and look inside Many stoves have two little ajusting screws insind with instructions andthe adjustment resets the knob
positioning on the valve stem. try that.
Apr 21, 2010 | Wolf Range CHR-10-229-FT11 Kitchen Range
For the GE XL44 model, where would i find the pilot light? the stove is not working
There is not pilot light on the stove top since the burner is activated by a spark generate by high voltage to a small ceramic disk with a wire protruding from it by the burner.
You have the have AC Power to the stove and you should hear a clicking when you slightly turn on the burner. Once the burner is on fire then turn the burner control to the desired temperature. If the burner will not light after 4 seconds of clicking sounds turn the burner control off and make sure the round gas diffuser on top of the burner is correctly seated on the burner. It should lock in place and is removable for daily cleaning of the stove. Now try the burner control again in the light position for no more than four seconds to see if it lights.
Do you smell gas? Do you hear clicking when slightly turning the burner knob? If yes to both the stove is working and the top of the burner is not seated correctly. If no on either or both you may have a stove, electrical or gas problem.
Jul 11, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Electric igniters dont shut off
Remember to turn the control knob past the "LITE" setting once the burner fires.
If that is not the issue you have one or more defective spark switches.
Each valve has its own switch wired in series with the others.
Mar 12, 2009 | Wolf Manufacturing Gas Kitchen Range
Igniter "clicking" on its own...
new spark module. Most stoves use a common part.
Jul 25, 2008 | Tappan 24 in. Freestanding Gas Range...
Wolf range cooktop
I just installed a Wolf gas cooktop and had the same problem in that all 4 burners would light just fine but the electronic igniters would not stop clicking on all four. What I found was that the electrical outlet that my gas cooktop was plugged into had the polarity reversed. I tested the outlet with a polarity testing module (you can get one at Home Depot and it checks polarity, grounding, GFI and is handy to have around, small and inexpensive). I plugged it in and the lights told me that the polarity was reversed. I reversed the wires in the outlet (exchanged the white and black wires) put the cover back on, plugged in the cook top and now it works like a champ! no more constant clicking. By the way, we had a cooktop before this one with electronic ignition and never had a problem, apparently it didn't care about the polarity.
Nov 10, 2007 | Wolf Range 18 in. SPR-100 Gas Cooktop
Wolf Range CHR-2-1829-FT45 Gas Kitchen Range Logo
629 people viewed this question
Top Wolf Range Kitchen Ranges Experts
Ismael Rodriguez...
John Rodgers
John Rodgers
Dan Webster
Dan Webster
Are you a Wolf Range Kitchen Range Expert? Answer questions, earn points and help others
