Question about Lexmark JetPrinter X1185 All-In-One InkJet
Copier won't copy - Lexmark JetPrinter X1185 All-In-One InkJet
    Guru:
  • 366 Answers
Possible reasons as below :
1. Possible broken charging wires (corona wires) (chargeing wire)
2. No charge on the drum will not pull developer
3. Broken (transfer wire) will not pull image off drum resulting in blank copy
Hope it helps.
Posted on Jul 16, 2010
The copies has a ck or ch message and won't copy.
please check that all the door switches have been made and the front cover closes properly. Also ensure that your toner box unit is properly inserted.
Jan 07, 2013 | Sharp DM 2010 Laser Printer
Won't scan, light doesn't come on
Make sure the printer can copy (without computer). If you can make copies, the problem may be the computer or the USB cable. If the printer does not copy also. The problem is in the scanner or in the flat cable.
Apr 10, 2012 | Canon Office Equipment & Supplies
The light does not turn on when making a copy.
it's clear. that is expose lamp the end.
you have to replace a new
good luck
Dec 11, 2011 | Canon PC-921 Black and White Copier
My office jet G85 won't print. No error messages appear,it has a new color cartridge,it copies, but won't print from my computer.
If it copies ok, then the issue is either the way it is cabled to computer or the print driver software settings on pc.... How is it connected via USB? Check port and correct driver is in windows/control panel/printers. Reinstall.
Nov 30, 2011 | HP OfficeJet G85 All-In-One InkJet Printer
It just won't make a copy. New
do you mean that copy comes out blank?
If yes, this is problem with laser shutter on laser unit.
Call service!
If the copy isn't blank, please give more details about problem...
Sep 14, 2011 | Canon imageCLASS MF6530 Copier
Photo copier won't copy
I would suggest you to try making a copy and check if you can see thelight of the bulb, if not its a hardware issue, you need to get it replaced
Jul 11, 2011 | Office Equipment & Supplies
WHAT IS THE FUSER ASSEMBLY? hOW CAN i REMOVE PAPER JAM?
This is near the exit area right before copy exits into the tray or sorter It appiles heat and pressure to the copy as it goes between the upper and lower fuser rollers so that the toner melts into your copies and won"t rub off keeping the image from smearing Often the copies will be warm--this is normal.
Apr 21, 2010 | Canon ImageClass D660 Copier
Copier won,t print or copy in color.
someone had putt a restiction on the copier for those options but for to help you you need to tell me for which bran and model is about
Sep 01, 2008 | Office Equipment & Supplies
My brother mfc 210c won,t scan or copy
I just called Brothers product support and found out that these machines WILL NOT scan or copy or do anything until the ink cartridges have been replaced. So there is no other solution.
Nov 26, 2007 | Brother MFC-5840CN All-In-One InkJet...
Lexmark JetPrinter X1185 All-In-One InkJet Logo
29 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
