Question about Relic Dress ZR77061 Watch for Men
How to change battery in Relic watch ZR77060 tool
How to change battery in Relic watch ZR77060 tool to use to remove back cover
  • 3 Answers
SOURCE: Remove link form Relic Wrist band
For my relic ZR15372, all I did was take a thin, hard object (a thumbtack in my case) and carefully pushed out the connecting bar from the link.
If you look at the inside of the band of your watch, you may notice that on some of the links (the ones nearest the clasp for me) there is a little arrow pointing at the side - if you look at the side of the links, there should be a little hole, big enough to push a thumbtack into. If you apply enough pressure (again, carefully - no need to stab your thumb or any other part of your body), the connector pin should slide out a little on the other side. Then it's just a matter of pulling the pin out - perhaps a pair of tweezers would do the trick.
Hope this works for you!
Posted on Mar 04, 2008
SOURCE: Relic Wet watch
Like many other watches, the Relic Wet's battery can't be changed by the owner. It requires a Jeweler's wrench. Said wrench has prongs that fit into the 6 indentations on the back of the watch. The wrench is than used to unscrew the back plate, exposing the battery. Any reputable jewelry store will have one.
Posted on Aug 08, 2008
SOURCE: Watch Band Adjustment
I think maybe we're all too familiar with the little old watchmaker image, loupe in right eye with tiny tools at hand......The links that have the arrows on them are indeed removable, it just takes more force than you might think. I'm in my office, so I used a pushpin (like for bulletin boards) and yep, it took more force than I thought, but the pin did come out the other side. A little tug with needle nose pliers and out it came. Remove link, repeat as necessary. Good luck
Posted on Jan 10, 2008
escapement
  • 2334 Answers
SOURCE: taking back off relic watch
If this is screwback, then there should be grooves for inserting case opener claws. For this yoy need case opener with interchangeable claws. You can buy it on ebay for approx. £7.00.
If the casebask is snap-on, then there shouldn't be any grooves, just small opening (lip) between the caseback and case. This is exact point where the watchmakers knife blade must be inserted and pryed up.
Do not forget to rate, please.
Posted on Jan 26, 2009
escapement
  • 2334 Answers
SOURCE: Mens Relic watch stopped working after battry change
I suggest that your watch has an oxidized contacts and electricity can not reach the movement.
Do as folloes:
Take out the batttery,
Clean (scrape) all battery related contacts till they are shiny (use hardened steel needle for that),
Use the dust blower to get rid off any tiny dust and dirt particles after cleaning,
Refit the battery back.
Now your watch should work again.
If all written above do not help, then there is a problem with your watch and you will need the help of the watchmaker.
Posted on Feb 10, 2009
Looking for the battery sized for relic watch zr55109
Just take the watch to your local jeweler. They keep all the batteries and have the tools to remove the back. The cost is $8 to $18 and done whilst you wait.
Jul 12, 2018 | Relic Watches
Battery for relic wet or 15478 and how to remove back of watch
Watch back will almost certainly need a dedicated wrench to loosen and unscrew it. Sometimes considerable force is needed and in that case a watch repairer would remove the strap and fit the watch into a bench-mounted holder.
Once the back has been disturbed the water resistance cannot be guaranteed unless it is pressure tested after refitting.
Jan 23, 2017 | Relic Watches
What size battery goes in a Relic wet ZR15373. Help please
If you don't want to remove the back of the watch yourself, take it to a jewellers shop and ask them to help. They will remove the back, replace the battery and they should give you the number of the battery so you know for next time.
Apr 13, 2015 | Relic Watches
How do i take off the back of my watch to change the battery?
mcdevito75 here, Look for a small tab or crease in the back cover that meets the case, use a sharp knife and pry off the cover carefully, look very close for this tab / crease.
Sep 26, 2010 | Relic 0504648FA
How do I take the back off of my Relic watch to replace the battery
Locate a very small tab (or recessed area) on the edge of the back cover. This is the access point for removal. You can find this sometimes by running your fingernail around the back rim, as this tab or indentation can be hard to see.
  • 2Pull out the stem, which releases the back on some watches.
  • 3Get a small flathead screwdriver it needs to be a thin inflexible tip. Use a kitchen knife as a last resort. Wrap the hand you are holding the watch with in a towel or protect your hand in some manner so you don't injure yourself if the screwdriver/knife slips.
  • 4Very carefully slide the blade under the tiny metal protrusion on the back cover (or across the length of the recessed area, depending on which type of cover your watch has). Do not attempt to insert the point of the knife. Use the length of the blade.
  • 5Get under the tab or recessed area and gently but firmly turn the blade upward, popping the cover off.
  • 6When you replace the cover, make sure you line up the stem slot on the cover with the stem of the watch.
  • Aug 20, 2010 | Relic watch
    How to remove back of Relic watch modelZR55046
    I would remove it very carefully. It should be either a pop off or a screw off case back. It is only best to use a proper tool to do this to avoid and damage or scratching of your watch. This all may be very obvious to you. I only use special tools to do this and sometimes under a microscope to do the job right.
    Oct 30, 2009 | Relic 0504648FA
    Do as folloes:
    Feb 09, 2009 | Relic 0504648FA
    Relic Wet watch
    Apr 01, 2008 | Watches
    Relic Watch Band Removal
    If there are holes where the band connects to the watch and you are unable to push the spring bar out. There may be a bar connecting the band to the watch. Those are harder to push out.You might have to use a tool & hammer it with a gavel. Hope this helps
    Mar 04, 2008 | Watches
    Relic Dress ZR77061 Watch for Men Logo
    1,085 people viewed this question
    Top Relic Watches Experts
    Ansel Alberto
    Ansel Alberto
    Jim Parker
    Jim Parker
    Are you a Relic Watch Expert? Answer questions, earn points and help others
