Question about Mitsubishi WT-46809 46" Rear Projection Television
Big scratch on outer layer of glass
There is a big scratch on the outer layer glass (there seems to be the glass then a protective glass over it) it is very big and annoying i've tried every glass, scratch cleaner out there please help
  • 121 Answers
I tried the advertised Eyeglass fixer "Liquid Lense" treatment with good success
Posted on Apr 21, 2008
    Habit-Forming:
    New Friend:
  • 107 Answers
Oh i ve got an answer her in Scratched Glass Repair Professionals we are in this industry leader for over the last 10 years by
developing methods to fix and restore
scratched and stained glass to a brand new condition. We have serviced hundreds of clients and thousands of windows
and continue to do so.
Posted on Oct 13, 2016
Minolta di200f
Mam/sir
does this line appear if you put the original on the big glass and make a copy? If not then when you use the document feeder you do not use the big glass, you use the small glass check the small glass for dirt etc. and clean it. DO you print to this machine are prints OK? then narrows the field down. IF the line appears using the big glass check the image unit or the fuser the hot part can open the right door open the hot part Wait to let it cool down check that neither fuser roller has a scratch or line on it. for the image unit try to print and stop the machine by open the right door to try to catch the paper before it goes thru the hot part does you line appear if so image unit is bad .
Apr 18, 2012 | Minolta - DI200F Printer
Screen damage from Panasonic Viera TV
Hi
There is a solution. If you brought this to my shop I would replace the film (depending upon availability). Absolute worst case is replacing the screen (costly). Of course this is my shop, you'll need to take it to a reputable repair person. Sorry
Mar 29, 2010 | Panasonic Viera TH-50PX80U Plasma TV
Where can I get a replacement plactic screen cover
This set has 3 screens---the outer one is really only for glare--clear plexigalss--no longer available from Sony.
Sony 4-070-602-01
SCREEN, FRESNEL Sony 4-064-343-11
SCREEN, LENTICULAR Sony 4-058-894-11
SCREEN, PROTECTION (CONTRAST)Outer one is (Contrast) the other two inner ones are showing as available and about 180 each.
You would have to either have someone dismantle or do it yourself---most of these sets you have to remove all three screens from the rear of the set---then remove the outer contrast one if it is scratched or cracked--
If you get it out and measure it: It is possible you may be able to find a company who can cut you a plexi-glass piece to replace it with--lots of work to do this and you have to use extreme care when you remove the two inner screens--easy to damage them---Usually the inner two are taped along all the edges to keep dust etc from getting between them and the front one is a short distance forward of them.
The front protective screen is really only there for glare and to protect the inner screens from damage---I have seen people who had a cracked outer one just dismantle and remove that one---put the others back and use the set that way---have to be careful as the inner screens are easy to scratch or damage with the outer one removed.
Also---I have seen several where someone removed the outer one and got a piece of plexi glass big enough to put on the outside of the front of the set---secured all around the edges with velcro--does not look as good as the original but prevents glare and protects the inner screens.
If this told you something you did not know or helped you rate this solution as I do this here for free.
SD TECH
Jan 03, 2010 | Sony KP-53V80 53" Rear Projection...
Pictures come out very scratched after scanning, how do I clean it out?
i think there will some sractes on the scanner glass those scartchs are very minute and you will not be able to see it that is why you get pictures scratched and and you can also try this clean the scanner glass with wet cloth dont rub it hard clean it very softley and use it again if the problem is still their change the glass and once you changed it dont allow the scanner glass to get damged again with scatches protect it very well keep it away from dust particals when you dont use it cover the entire scanner with a big cloth to prvent dust and also put a white paper over the glass when you are not using it and you can also put a transpernt plastic cover over the glass to prevent straches when you are doing scanning foolow this and avoid such problems in the future thats all....
Oct 20, 2009 | HP OfficeJet V40 All-In-One InkJet Printer
Can i cut another screen to fit my tv?
depends on what type of screen you have and if you want to cut the protective layer or the actuall screen which on some tvs is 2 layers of thin glass with liquid in between. in that case no but if you just want the outer case then yes just cut it out of plexiglass or another thin transperent material.
Sep 16, 2009 | Toshiba 50H82 50" Rear Projection...
Garmin 2720 touchscreen won't work, must use remote control.
I'll start with a comment I made on another post:
The touch screen is made up of several layers. A thin plastic layer, a micro thin metal layer, microdots for insulators, another ultra thin metal layer, and a final plastic layer. All of these layers amount to the thickness of a sheet of paper. This whole stack is bonded to a thin sheet of glass and placed over the actual TFT display.
It's amazing that you can see through all these layers and only lose 20% of the light. What's not so amazing is that those thin metal layers are prone to damage. I've seen several with no apparent damage that didn't work, and several with visible scratches that worked fine.
I usually start by installing (or reinstalling) v7.2 firmware and then attempt to recalibrate the screen, sometimes that works. Next I would try re-seating the 4 conductor touch screen pigtail in it's ZIF socket nestled between the big white wires on the display assembly. The last resort is to buy a broken 2600 or 2700 series Garmin and salvage the touch screen. Actually the real last resort is to have Garmin fix it for a flat $250. Good luck.
Jan 18, 2009 | Garmin StreetPilot 2720 GPS Receiver
Scratch
hello, if there is a scratch on your reflective outer glass panel screen, it can be replaced if you are handy with tools or diy i happen to have the screen removal manual for this tv model th42pz700u you dont have to dissasemble the tv just the outer front housing remove the back panel and theres some screws that hold the front casing on those come of and the front refelctive glass can be removed without any trouble or dissasembly of the internals just the front casing
you may need to find a selling as is plasma tv with a broken internal screen usually they are this way that outer screen dosent break easily so unless you want to pay 489 for this reflective glass part i would try and find a 'for parts or repair 42 inch pany' they will fit if they are the same size make sure the outer screen is not broken or scratched. hope this help
Nov 29, 2008 | Panasonic TH-42PZ700U 42 in. Plasma...
SCRATCHED TV SCREEN
try contacting www.tvscreenprotectors.com
They deal with damaged tv screens
Apr 11, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
Nintendo ds lite touch screen protective outer layer(plastic)
you must send it in to Nintendo, for a new touch screen or take it to your nearest GameStop video store.
Dec 18, 2007 | Nintendo DS Lite Console
Mitsubishi WT-46809 46" Rear Projection Television Logo
123 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
