Question about HP Vs17 17" LCD Flat Panel Monitor
Doesnt want to turn on
Screen goes to sleep mode has a message that says vga input
Turn modem off and keep pressing F8 until you get to the screen that says enable vega and click on that and follow the directions from there.
Posted on Jul 24, 2010
Monitor goes to sleep immediately after turning on the computer. How can I fix that?
go to start,then pc settings,then monitor or power options the to power and sleep and change on plug to 4 hours and on battery to 10 minutes
Jun 11, 2015 | Computers & Internet
NO DVI INPUT SIGNAL AND MONITOR GOES TO SLEEP
you can't run 2 different inputs at the same time. VGA takes prescedence.
Apr 06, 2014 | HP L1950 Monitor
Hp g72-227wm has a broken lcd screen i have a hp compaq le1711 vga flat screen hooked to my lap top it was doing fine i log off out of windows and shut down the pc when i turn it back on the flat screen...
Check monitor is set to correct input (VGA, DVI, HDMI) if it goes to sleep instantly.
Otherwise screen resolution is set too high. Boot into safe mode by pressing F8 during boot. Login and lower screen resolution.
Oct 03, 2012 | Computers & Internet
Problem with power off mode on LG monitor
If the power light comes on then goes into sleep mode, it might not be communicating with PC video card. It should pick up the input port automatically, but make sure on monitor is set to correct input like VGA. You can try re-seating video card on PC. Also test with VGA if you are using HD like DVI or HDMI.
Aug 31, 2012 | LG Computers & Internet
How to fix my monitor when its in sleep mode
I assume this is a Desktop computer:
The Monitor receives, graphics or text from the PC (personal computer) and displays it on the screen.of the Monitor.
If you see a message on the screen that says * NO SIGNAL * in most cases the Monitor is good, and the Monitor is either not connected to the PC or there is a problem with the PC Check the connections and the video card.
The problem could also be related a failure of the motherboard, memory or the processor
Let us know..
Nour Sabre
www.aaatvservice.com
May 21, 2012 | HP W2007 LCD Monitor
When I turn the monitor on I get a message "In
Most Dell LCDs have multiple inputs and they will go into "standby" while waiting for a signal from your PC. This happens when your PC goes into "sleep" mode or if you are sure your PC is not in "sleep" mode then usually the LCD is not in the correct input selection. Check the input selection for the appropriate input. As always, make sure the cables are securely connected. Hope this helps.
Jun 15, 2011 | Dell E173FP 17" LCD Monitor
I have a Samsung SensR470 laptop and i have linked up the VGA, audio, and power cables but the monitor is not showing anything. when i turn it on, it just goes into sleep mode or otherwise shows the...
its because you failed to read the Samsung manual on your PC
go there and read, it has HOT key , all laptops have a hot key
Fn key that turns on the external display VGA jack.
on rear of this SAMSUNG.
SLEEP MEANS THE PC IS NOT SENDING THE HORZ AND VERTICAL, SYNC SIGNALS. AT ALL.
THAT MEANS WHAT>?
It means the PC, VGA jack is turned off.
bad cable
bad monitor.
The PC can also be bad VGA chips, or worse,.
your first failing here is not saying why you are using VGA jack
is the Laptop screen dead too> (my other shoe falls off)
dang that be nice to know , no?
or like we do run that VGA to a projector? for say doing power point presentations, (done many before retired)
RTM, the manual is free to read any time of day, 24/7
each PC maker uses there own rules here, its there call
there design and their rules.
my HP its, Fn+F4, (toggle:, internal, external ,both or auto)
but yours is Samsung, ask them. or learn to use google?
Jun 10, 2017 | HP w1907 LCD Monitor
No DVi input, then computer goes to sleep
Hi publicworker,
I had a similar problem whereas my monitor went to sleep mode after a few minutes. I'm running an HP LP 2065 in dual mode with another HP flat screen. However, I did resolve the issue after resetting the output settings.
How to do that:
  • right mouse click on the desktop
  • select graphic options
  • output to
  • extended desktop
Maybe some changings/modification will help you too.
Stefan
Jan 31, 2009 | HP 2025 20.1" Flat Panel LCD Monitor
Goodmans Flat screen monitor GV series - when I turn on the screen a message comes up "entering sleep mode" then it goes in to standby (the computer is still on) - HELP
when u start computer press F8 key untill u get safe mode menu.
then go to enable vga mode .then u can enter in wicxp .theh set display resolution in display properties. 800*600 or 1024*768 .
thats all.
Oct 11, 2008 | Computers & Internet
Whilst using the internet the computer shut down. When i try to turn it on the lights come on but it doesnt load. The screen has a message No Video input.Once or twice it has loaded but then it goes into...
hmm..kimmie..can you illuminate me a bit about your computer model and also operating system? also, can you run it without the internet connection?
Mar 11, 2008 | Computers & Internet
HP Vs17 17" LCD Flat Panel Monitor Logo
78 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
