Question about Frigidaire FGR211AS Gas Dryer
Only getting limited heat for a Frigidaire FGR211AS1 gas dryer.
We have a Frigidaire FGR211AS1 gas dryer. 2 years ago we had the holding and boosting and secondary heating coils replaced. It worked great until now. As of 2 days ago the dryer will only heat up a little bit. I checked the fuse and the radiant sensor and they have continuity. The glow coil gets red when the dryer is on. It just doesn't get enough heat. It gets some heat -- just not enough (like it used to). The exhaust is clear -- I don't know what else it could be. Any suggestions out there?
  • 10,319 Answers
These dryer's have a moister sensor installed into them. The will work great when the exhaust vents are clogged up with lint and keep the heat in check. Since you claim you already checked and seen the venting tubes are clear the moister sensor is not working so the the heat will not get very hot at all. Replace the sensor to get this unit back in working order
Posted on Jul 16, 2010
  • Dan Przekop Jul 16, 2010
    Many Thanks!
    That is awesome news. But... my next question ... where exactly is the moisture sensor? Can I get to it from the front of the dryer and without removing the drum? I'm nervous about going much farther than removing the top and front.
Just replace Assy Ignitor on my Frigidaire Dryer FGR211AS1 but glows for a second
Hello stephaniadel - The gas igniter has to reach a certain intensity before the gas valve will come on. There are two coils that mount to the top of the gas valve which opens and closes the valve. If these coils have failed, the valve will not open, even if the igniter is operating properly. If I was in your position, I would personally recommend connecting with a professional to accurately pinpoint any potentially more serious issues.
Mar 21, 2013 | Dryers
Just hooked up my gas dryer. worked great thru 5 loads and then quit heating,help!
What did you do move it from one place to another place? You may have shifted the lint around and cause a limit to get tripped.
Here is the manual and more
A gas dryer has a burner assembly consisting of an ignitor, 2 coils, and a flame sensor. The ignitor does 2 functions. It lights the fire and confirms the fire is on like a thermocouple. When it is heated it holds in the coil. If the glowbar is not lit then the coils will not open. The ignitor must be heated to allow that. So if the ignitor and flame sensor is fine and the dryer works when cool but stops heating when hot I would say you need to replace the solenoids.
Nov 17, 2010 | Frigidaire GLGR331A Gas Dryer
My dryer has stopped heating completely. Worked fine for six years and stopped heating four days ago.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Nov 06, 2010 | Frigidaire FLEB8200DS Top Load Stacked...
Dryer will not heat
My guess is you probably got some lint on the ignitor and cause a burnout or a limit to trip. If you don't hear the clicking associated with the ignitor heating up and the flame sensor kicking it off then I would check to see if maybe a limit was tripped. On gas dryers when the limit trips the dryer will operate but simply will not heat up. I have a full page with service manual included HERE
Jul 12, 2010 | Frigidaire GLGR331A Gas Dryer
I have a gas Frigidaire dryer that heats once or twice
your cycling/hi-limit switch needs to be replaced,it is located on the outside of the burner tube to avoid an overheat condition and cycle the flame according to your heat setting on the control panel
Mar 14, 2010 | Frigidaire GLGQ332A Gas Dryer
Already bought a Frigidaire Gallery Dryer about 2 years ago.
kinda if its not spinning, it will over heat and shut down on high limit
Jul 02, 2009 | Dryers
Dryer doesn't heat...
Check the following to address this issue--
1. Gas valve coils
Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
2. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
3. Igniter
Igniter may burn out or break. Replace the igniter if found defective.
Note: Igniters are very fragile and break easily. It is recommended to handle the igniter only touching the ceramic part of it (usually white in color).
4. Flame sensor (or radiant heat sensor)
Replace the sensor (located near the igniter) if found defective.
Jun 03, 2009 | Frigidaire FGR211AS Gas Dryer
Dryer drum spins but no heat
These units have a limit switch is located near the burner compartment. It is about the size of a dime or penny with 2 wires going to it. In between the wires, there is a small button that you can depress firmly. This should reset the limit. If it trips again, you will need to replace the limit switch. Hope this helps.
Apr 11, 2009 | Frigidaire Dryers
Frigidare Gas Dryer - get some heat, but NOT hot enough!!
You say its a gas dryer...there is no element. Have you cleaned the lint trap. Is the vent clear of obstructions? I suspect one of these issues will be the problem
Mar 16, 2009 | Frigidaire FGQ1442ES Gas Dryer
1317150009709 frigidaire dryer0how do i get at the pilot light or
There are 2 house fuses in the dryer circuit. If
1 of the 2 fuses is blown, the drum may turn
but the heater will not operate.
Gas supply valve is not open (gas models).
Dryer does not have anough air supply to
support the burner flame (gas models).
LP gas supply tank is empty or there has been
a utility interruption of natural gas (gas
models).Replace fuse.
Check to make sure supply valve is open. See INSTALLATION
INSTRUCTIONS for procedure.
See INSTALLATION INSTRUCTIONS.
Refill or replace tank.
Dryer should heat when utility service is restored
Feb 16, 2009 | Frigidaire FGQ332ES Gas Dryer
Frigidaire FGR211AS Gas Dryer Logo
50 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
