Question about HP LaserJet CP3505n Printer
Magenta cartridge is leaving toner on pages that don't even have Magenta on them
    Champion:
  • HP Expert
  • 202 Answers
Replace the megenta tooner ur printer will be worked properly......
Posted on Jul 16, 2010
Sp c821dn printer displays "out of toner" magenta message even when magenta toner is replaced with new one.
is their toner in the new cartridge installed? if not you have to refill the magenta cartridge and do the calibration of the printer
Apr 07, 2017 | Magenta Office Equipment & Supplies
HP CP1515n Toner tray stuck on right side
you should check transfer belt or fuser unit.
Aug 24, 2016 | HP LaserJet CP1515n Printer
I have a Lexmark C522 Color Laser printer, all cartridges are showing as ok, no error messages but printed pages have specks of magenta toner on them
It sounds as though you have a leaking toner cartridge. If you aren't using Lexmark brand toner, that is VERY likely.. nobody seems to be able to make a good compatible cartridge. Test by replacing it.
Feb 22, 2014 | Lexmark C522n Laser Printer
Magenta toner showing up in 2 dots on paper printed from Aficio MP C3000. Replaced Magenta toner, but dots have not faded. What do we need to clean, and what do we use to clean it? Thank you.
If it's a repeating defect, as in you see the same spots at an exact same distance multiple times on one page then it sounds like you have some debris on the Magenta Drum,
here's a page from Precision Roller for a replacement. (This is more to show you a picture of it than suggesting you replace it which is last resort.. expensive!)
The drum is a photosensitive metallic roller that effects the image quality,
if you remove the drum and examine it you should be able to see the spots on the roller.
You should have a drum for each color so it would be near the magenta toner cartridge.
IMPORTANT!!
The drum is very well.. delicate, do NOT touch the drum with any chemicals, do NOT touch the drum with your bare hand, and also do NOT expose the drum to light for an extended period of time.
You can use a Q-tip to very carefully remove the spots if you find them or you could also use a can of compressed air.
If you do not see the spots you may or may not be able to actually turn the gear to move the roller. If it seems difficult then don't force it, try putting it back in the machine print a page and remove it and hope you can see the debris on the exposed portion.
Did this help? Don't forget to leave me a positive review if it did! Good luck! :)
Jun 08, 2011 | Ricoh Office Equipment & Supplies
Excess cyan toner is on electrostatic transfer sheet even after wiping it. All black and white pages are printed with cyan background.I am even using original cartridges.
Since you have Cyan toner in places where it should not be then the only possible cause is a defective Cyan Toner cartridge. I worked on one just last week where the customer complained about Magenta toner on their prints. I also noticed Magenta toner on the Transfer Belt just as you see Cyan toner on the Transfer Belt. I replaced the Magenta Toner Cartridge and everything cleared up nicely. The Transfer Belt Unit can also cause similar problems but it would not be ONLY one color like Cyan. It would be a mixture of all colors. My bet is replace the Cyan toner and you will be fine. If you have an old empty one just shake it up a bit and try it as well. This might allow you to verify before buying a new cartridge.
Good Luck and Thank You for using Fixya.
Wheatland Services
Feb 06, 2011 | HP Color LaserJet 2600n Printer
Ricoh CL4000DN. I recharged the magenta toner using the OEM cartridge. I replaced the chip as instructed and all elements snapped together without difficulty. However, now there is a "check toner...
Hi, the chip on those toner bottles stores information about how much toner is left, so once that chip registers an empty toner bottle, it won't work even if you attach it to a new toner bottle. You'll need the chip from a new toner bottle, or one that hasn't registered no toner.
Jan 22, 2011 | Ricoh CL4000DN Laser Printer
Magenta (yellow) unit is PAST end of life... (I have changed cartridges I still have this message. I tried to read instruction, and I got following message: Install P/N 108R00649 following the instalation)
Hi armaskopljak:
You have replaced the toner cartridge but you still have to replace the imaging unit which is the drom that the toner cartridge attaches to.
Toner Cartridge OK, Low, Empty When 15,000
(high-capacity cartridge) or
7,500 (standard-capacity
cartridge) pages are
printed (5% print density).
Imaging Units At/Near end-of-life When 30,000 pages are
printed out or when the
pixel counts are
exceeded.
A fuse in the new
imaging unit will blow
upon installation,
resetting the counter.
Verify color calibration. Clean lenses.
Xerox Part Numbers
Toner Cartridges:
Standard Capacity Yellow 016-1975-00
Standard Capacity Magenta 016-1974-00
‘ Standard Capacity Cyan 016-1973-00
Standard Capacity Black 016-1976-00
High Capacity Yellow 016-1979-00
High Capacity Magenta 016-1978-00
High Capacity Cyan 016-1977-00
High Capacity Black 016-1980-00
Imaging Units
Cyan 016-1993-00
Magenta 016-1994-00
Yellow 016-1995-00
Black 016-1996-00
Hope this helps
Jul 10, 2009 | Xerox Phaser 7300DN Laser Printer
The red is not printing
At a guess you are using recycled toners? If the recycler has not worked out the refilling procedure properly, the problem you experienced with the exploding Cyan toner is common. It is possible in the act of blowing out the loose cyan toner your have used to much air pressure, possibly blowing toner into the laser beam units, or damaging the toner sensor unit for magenta.
A diagnostic inspection, by a technician would be suggested.
Cheers: DeJudge
Dec 30, 2008 | HP Color LaserJet 2600n Printer
Magenta cartridge empty
When you take the toner cartridge off the imaging unit, is there magenta toner in the open slot of the IU? Assuming that there is nothing wrong with the toner cartridge, you are possibly looking at a bad engine control board.
Jun 11, 2008 | Xerox Phaser 7300DN Laser Printer
HP LaserJet CP3505n Printer Logo
mukhtar21 shaikh
mukhtar21 shaikh
