Question about GE Profile JGP636 Gas Cooktop
My GE gas cooktop keeps making a clicking noise and one of the four burners doesn't ignite unless I light it with a match. What should I do?
    President:
  • 1,891 Answers
The burners use a sw on the gas shaft of each burner to make the igniton work. i belive one of the sw are shorted or housing broken . replace it . / tip when I replace one i do them all .. saves time later . falure caused by spills ect and normal ware .. mm
Posted on Jul 16, 2010
All 4 electrodes spark when only one is turned on
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good "blue" arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Jul 20, 2010 | GE 36 in. JGP628 Gas Cooktop
Have a four burner gas GE Profile cooktop. How do
The igniter module is working fine. One of the switches (which are on each valve shaft) is stuck or shorted out. Pull a wire off each one at a time to determine which one is bad. Careful! 120 volts to each wire. Also, this can happen after you spill water into the valve area, if that sounds right, let it dry out.
Jan 29, 2010 | GE 30 in. JGP328 Gas Cooktop
Gas burners won't light
Make sure the little tiny flash holes are open. They allow a little bit of gas to seep out so the igniter can light the burner. If you can light the burners with a match, check those holes.
If yours are the "sealed" type burners, make sure they are not a half a turn out (180° around)
Jan 10, 2010 | GE Cooktops
The igniter on the right front burner of my GE Gas cooktop does not work....I must use a lighter or match to ignite....What can I do? There is no clicking sound when I turn on the burner?
all burner igniters work at the same time - you may have a faulty electronic spark unit. change the spark unit. go to repair clinic dot come for the unit. also would be wise to check the ingniter start switch on the gas burner control knob
Oct 17, 2009 | GE 36 in. JGP628 Gas Cooktop
GE XL44 range - electric igniter for top burners not working.
Sounds like igniter problem. Did some one pull the electrical cord or has a fuse or breaker blown/ Things to check. Your igniter is run by electricity.
Dec 30, 2017 | GE Profile JGP636 Gas Cooktop
One burner requires a match to light
had same problem. Used fine sandpaper on the little head (just above the white ceramic) that creates the spark. over the years the edges of the littel metal ring had gummed up but a 1 min sanding got it down to shinny metal and it sparked nicely.
Nov 30, 2008 | GE Monogram ZGU48N4GHSS / ZGU48L4GHSS...
Stove-top burners
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range RepairBurners Keep on Clicking
heatman101
bvn
Jul 10, 2008 | Belling 27 in. CTC465 Electric Cooktop
GE Profile JGP636 Gas Cooktop Logo
932 people viewed this question
Top GE Cooktops Experts
Marvin
Marvin
Steve Allison
Steve Allison
Dave Harrison
Are you a GE Cooktop Expert? Answer questions, earn points and help others
