Question about Frymaster Dean 2424G Deep Fryer
Natural Gas to Propane
My fryer is model # GM35GMS it is currently natuiral gas and our Club wants to have it set up to use liquid propane. Can we buy a kit ?
    Champion:
  • 254 Answers
Hello
Yes you will need to buy the orifice to convertit to propane.
After you install the orifice, you will need to also adjust the manifold pressure with a monometer. And you will also need to put the stickers on the gas valve that will state that this unit has been converted for use with propane. If you have any other questions feel free to comment back.
Thanks
Posted on Jun 03, 2008
Instuctions on how to change a pitco fryer from nat gas to propane
Hi there!
You need to order a gas valve conversion kit (from nat to propane), propane pilot orifice and propane burner orifice,
Gas valve conversion kit consists of a replacement spring thicker than of natural gas valve spring, gas valve cap and a sticker.
Pilot orifice for propane has smaller bore than of natural.
Burner orifice for propane has also smaller bore than of natural burner orifice (one for each burner).
You will be able to find these parts on the list of Pitco Distributor when you visit http://www.pitco.com
Regards.
Jul 08, 2012 | Pitco Frialator E24 Deep Fryer
I am trying to switch a natural gas deep fryer to propane and cannot fimd the correct part
Hi there.
You can visit http://www.imperialrange.com , you can verify there the correct parts list for the model of your fryer for the conversion from natural to propane and you will be able to search there the nearest authorized parts and service provider in your area.
You will be needing burner orifice for propane, pilot orifice for propane (if available, if not, the whole pilot assembly), Gas valve spring for propane (if available, if not, the whole gas valve for propane).
Regards.
Aug 03, 2011 | Imperial IFS40 Deep Fryer
I have a older 40,000 BTU 3 burner natural gas deep fryer. I would like to convert to propane gas. The orifice number is size 32. Do I need to get different orifices to convert? The serial number is...
Hi there.
Burner orifice size for propane gas is number 55. You have to replace all burner orifice with this size if you want to use the fryer with propane gas. Pilot burner orifice should be replaced with propane pilot orifice.The gas valve spring should also be replaced with propane spring kit. The difference between the two spring is the natural gas spring is lighter or thinner compare with the propane gas valve spring.
Regards.
Jul 13, 2011 | American Range AF40 Deep Fryer
I bought a dcs fryer at a restaurant auction. I had it installed in my restaurant, and when I got it going flames were shooting out of the back. I had it looked at, but because there is no serial number...
The difference between Natural Gas Set Up and Propane Gas Set Up on Fryers are as follows:
Natural gas burner orifice has larger bore (#52) than Propane Gas burner orifice (#55 or #56).
Gas Valve's spring kit for natural gas has less tension (thinner) than Propane.
You have to order burner orifice ( the quantity depends on the number of burners your fryer has), pilot orifice and Gas Valve Spring Kit for Propane Gas if your fryer is set for Natural Gas or vice versa.
Regards.
Jun 22, 2011 | DCS Kitchen Appliances - Others
Vulcan 2grc45 fryer can it be converted to propane
All gas operated Fryers can be converted either from propane to natural gas use or from natural gas to propane use. Contact your local supplier on your country and and ask for the conversion kit.
Apr 01, 2011 | Vulcan Kitchen Appliances - Others
I have a small counter top fryer set up for lp gas how do i change to nat
check the supplier for the conversion kit.the kit contains burner orifice, pilot orifice and gas valve spring which are commonly needed for conversion from propane to natural gas or from natural gas to propane.
****natural gas orifice has larger bore than propane, gas valve spring for propane is thicker than for natural gas.
Mar 29, 2011 | Cecilware FMS-40 Deep Fryer
Where do i find propane to natural gas conversion kit for weber spirit e310 gril
Apparently, Weber does not make a conversion kit to convert the grill from propane or from natural gas to propane. According to the Owners Manual - "Liquid propane gas is not natural gas. The conversion or attempted use of natural gas in a liquid propane unit or liquid propane
gas in a natural gas unit is dangerous and will void your warranty." (From Page # 3 of the Owners Manual)
See below link.
http://www.weber.com/help/manuals/pdf_files/2008_updated/89525_030308_2008.pdf
Feb 23, 2011 | Weber Spirit? E-310 Propane Grill
Deep fryer from a restarant to change over to propane need orfices
I am looking at buying a pitco double deep fryer. It is natural gas, is it possible and at what cost to switch it over to propane. Model: F14S-CV - Serial: G99DC09212 Thanks Derek
Jul 19, 2009 | Pitco Frialator SG14 Deep Fryer
Label says propane, needs to run on natural gas.
You need to change the gas valve,burner orfices,pilot and maybe a gas regulator.I service these fryers often as im a hobart tech.Goto hobartcorp.com,type in your model and the parts list.Any ? let me know.
May 06, 2009 | Vulcan EF3 Deep Fryer
Converting a pitco frialator from natural gas to propane
you need to change the pressure regulator,burner orfices and possibly the gas valve.goto northernparts.com and type in the model of the fryer for propane
Dec 12, 2007 | Pitco Frialator SG14 Deep Fryer
Frymaster Dean 2424G Deep Fryer Logo
321 people viewed this question
Top Frymaster Dean Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dan Webster
Dan Webster
Treefrog15
Treefrog15
Are you a Frymaster Dean Kitchen Appliances - Other Expert? Answer questions, earn points and help others
