Question about ASUS M2N-E SLI (M2N-E SLI GREEN) Motherboard
My computer was built piece by piece worked just fine Some problem occurred that made taking apart my Computer necessary When I reassembled it it no longer worked. It turns on the fan goes for a sec or 2 then stops.. What changed? How do I fix it?
  • ASUS Master
  • 4,806 Answers
This could be anything from a faulty graphics card, bad power supply or even the motherboard.
What you need to do is disconnect all of the hardware except the motherboard, power supply and memory. Then try turning the machine on.
If it turns on start putting things back one at a time to see which item is causing the machine not to start.
If it won't turn on with just the memory and power supply installed then you either have a faulty motherboard or power supply, but to test these you have to check the voltage on the power supply which isn't easy.
Your best bet would be to get a compatible working power supply and hook that up.
If it still won't fire up then you know the motherboard has come to the end of its life and needs replacing.
Let me know if there is anything else.
Good luck and regards.
Posted on Jul 16, 2010
Need to reassemble my dell inspiron 1545 laptop
How could you take something apart without making making notes for reassembly?!?!? Does not make sense, Shirley.
Well you can try to download from Dell their user manual - mine has a section for making repairs and disassembly/reassembly..........
If nada then you will have learned a valuable lesson when you take it to a computer repair shop for reassembly.. And save your chips because it will not come cheap since those suckers are labor intensive and ....................
Mar 12, 2016 | Dell Computers & Internet
I was trying to clean and took about the bottom three pieces and can't figure out reassembly..forgot to take a picture!
Hello Caron, thank you for your inquiry!
Based off the information you have provided you took apart the bottom panel of your Frigidaire dishwasher and need help reassembling it. I have attached a parts schematic of your dishwasher to help assist you further. Best of luck! -Matt
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Kinston/5995552584.pdf
Dec 19, 2015 | Frigidaire Gallery 24" Built-In Dishwasher...
Fills with water, won't start wash cycle, won't drain on CANCEL. What's wrong?
I had a flap reversed in the drain line when I bought mine new. It was only allowing partial drainage. Had a service guy take it apart and switch it around. Seems to work ever since. It was under warranty at this time.
Nov 21, 2015 | KitchenAid KUDM24SE Built-in Dishwasher
How do i transfer my photos from a nonworking computer to a flash drive
If you aren't very familiar with computer components you are going to want to try to find a friend to assist you or a very well laid out tutorial online. There could be a number of reasons why you are experiencing problems and I don't have the details listed here to try to figure out what they might be. Assuming your hard drive is not the issue why your computer has stopped working, you can take apart the laptop and retrieve the hard drive with all your files on it intact. My guess would be something else happened, likely a software bug that is preventing your operating system from starting correctly. The computer might be a simple fix if you have someone take a look at it.
If you just want the photos and don't care about the computer, either find a tutorial or a friend to assist. Use a screw driver to start taking apart the computer and extract the hard drive. You will then need either another part (or friend who has one), sata cable and molex adapter to power the drive.
The simplest way to explain it is, take the laptop apart and get your drive. Then using the necessary parts, plug it into a different computer and you can recover your photos just fine.
May 04, 2014 | Compaq Presario X1000 Notebook
Power button not working
Do you mean, it won't switch on?
Jan 21, 2014 | Gateway NV52L06u Laptop PC
Taking apart
Question about Brookstone Desk Fans: Slim Personal Desk Fan
Taking apart I took mine apart by removing the small screws that hold it together. my top fan cage was broken and loose. I glued it back together and the next day I just reassembled it and it works fine.. just look at what you are doing and dont FORCE anything common sense should allow you to do this... I am a retired auto mechanic 80+ years old and it did not give me any trouble until the e-clip jumped off, but I found it and all is well.. the screws are shiny and the case is black, so take them all out and lay in a pattern so you can reverse the pieces for reassembly..
Feb 19, 2013 | Brookstone Desk Fans: Slim Personal Desk...
Rm-yd029 sony remote mute button not working
Hopefully this isn't too late for you. It will at least be available for others who face our problem.
Step 1: Remove the battery cover.
Step 2: Remove the screws that are under the battery cover.
Step 3: Remove the sliding panel at the bottom of the remote. Gentle pressure under the center of the door will lift it over the retaining tab. You might have to apply a little pressure on one side of the door to get it to release. Again... GENTLE.
Step 4: Work a very thin screw driver into the small gaps at the bottom of the remote in the area that was under that sliding door. I used a jewelers screwdriver. Gently work the blade around and back and forth until you hear a tab pop. Then get the other side's tab to pop. Use fingers and blade to get that end segment to pop open.
Step 5: Carefully work your way up both sides of the remote with the screwdriver releasing tab after tab. You can pop one on one side and then go after the matching one on the other side. Sometimes you can do two at a time on one side before doing the other side. Try not to apply pressure on the silver/gray side trim. It is decoration only. Get the blade in between the black top piece and the black bottom piece to pop them apart. Do this along the sides up to the top.
Step 6: The retaining tabs that are at the very top of the remote can be released with a gentle pulling apart and slight twisting of the top piece and bottom piece. Everything should be open and the layers should come apart easily.
Note: Be aware that the plastic frame parts on the big circular pad in the center of the remote face may fall out when you pull things apart. Not a big deal. Just make sure you reassemble it correctly. Be patient and look closely at it. It goes together pretty much one way and has sized tabs that help to get it right.
Step 7: Do whatever cleaning you need to do. For my situation, some liquid had gotten into the volume control area. I used a q-tip to clean it up.
Step 8: Before snapping it back together, fit all of the layers in the bottom piece then do a test of the buttons to make sure they work. (Replace the batteries if you removed them, of course.)
Step 9: Assuming all of the buttons worked and you are ready to reassemble, transfer all of the layers into the top piece (best done with the top piece upside down) and make sure they fit well. Make sure the two silver/gray trim pieces are firmly in place on the bottom layer. Hold the upside-down bottom piece above the upside-down top piece and snap the bottom piece into the top piece.
Step 10: Recheck that the buttons work. Re-open and try again, if necessary.
Step 11: Assuming all the buttons work, replace the sliding panel from step 3. Get its tracks aligned with the remote's tracks and it should be a simple pop in. Heavy force is not necessary.
Step 12: Replace the screws
Step 13: Replace the battery cover.
Hopefully this worked for you.
Aug 19, 2012 | Televison & Video
Dear PC Experts, I have a computer HP Pavilion m9300t and have been using three years already. The problem occurs about 4 months ago. When I turned on my computer, it looks fine in the beginning. As I...
It's probably the graphics card. They are one of the most common items to go bad over time. You could try to open your computer and blow out the dust from the video card, the CPU, the Fans, the Power Supply, and any other area you see dust collecting. You'll want to unplug the unit and take it outside to do this. Also, if you have more than one port on the back that will take the monitor cable, try plugging the monitor into that to see if that works. (some machines have a video card in a PCI slot as well as a built in video port... if the PCI card is bad, the built in port could still work).
Apr 15, 2011 | Computers & Internet
Can't get any sound out of the speaker system, am sure it is not muted. tried taking components apart, restarting and tried with another computer.......no sound. ideas?
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers
hope this helps
Oct 05, 2010 | Bose Companion 3 Series II Multimedia...
ASUS M2N-E SLI (M2N-E SLI GREEN) Motherboard Logo
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
