Question about LG LS-K2430HL Heat Cool Mini Split Air Conditioner
WALL MOUNT AC DOES NOT COOL ALL THE TIME , I FIND THE AIR COMING OUT OF THE UNIT IS NOT AS COOL AS IT ONCE WAS .THERES NO FROST ON THE WALL UNIT AND I DONT SEE ANY WATER LEAKS.
  • 57 Answers
Check air filter. Check lines outside going to indoor unit. One should be cold. One should be warm.
Posted on Jul 16, 2010
Unit not working correctly. The unit worked for the winter, few days ago I turn on the AC and noticed that it wasn't cooling like it should.
It's could be the board or a heat relay. See if you have 24 volts on "x2" im assuming, emergency heat when in cool mode if so it's the board. Or unhook black or x2 or your emergency heat from board and run unit in cool. If heat stays on its a relay
Jun 02, 2016 | Heating & Cooling
Why is my brisk air duo therm rv ac freezing up on the inside.
Where you see frost all the time, wait for unit to thaw and start cooling again and carefully slide hand up in that hole and see if you can feel cool air leaking in from divider that separates cool and return air, that will cause freeze-ups as well. Use foil tape if necessary to stop any cool air coming in to return air from around divider. Also, if you have any diffusers closed, (on ducted system in ceiling) or partially closed, open them all up full flow. If you restrict the cold air from coming out too much, it can also cause freeze up. One more thing, take cover off where cool air box is and double check that something isn't restricting the flow of cold in to the duct work if it has ducted system.
Jul 12, 2014 | Dometic Rooftop RV Air Conditioner
I have a whirlpool wall heat/ac unit, model ACE184XL0. All of a sudden, the heat quit working. Fan still blows, and AC still seems to work, although I can't tell if it's just pulling in cold outside air...
Dear it is a thermostat system. You can simply check it by setting temp at 30 then check either warm air is coming or cool air. at this time warm air should come. If warm air is not coming means there is a fault is realy in your pcb. It can be simply remove no need to worry.
Oct 14, 2013 | Whirlpool ACE244XS Air Conditioner
My Honeywell AC unit doesn't seem to be working properly. It will not retain a temperature. I set the thermostat to hold a temperature of 70 degrees. Room temp still reads 74 degrees. Something is working,...
The frost on the pipe indicates you have a dirty filter, dirty evaporator coil, Blower not running at the proper speed (to slow) or you are low on refrigerant.
Jun 29, 2010 | Heating & Cooling
Frezeeer works fine. Refridgerator (top) does not
good morning,
with this unit there are two issues that could be cusing this...
check to make sure you can hear the fan in the freezer,
2nd check your back wall for frost, sometimes this model ices up in the air chanels, to know for sure you will have to remove both the walls and the back wall, it takes a lil time but it can be done with only a screwdriver,
once you get the back wall off look up in the corners, of the freezer, it there is frost or ice blocks , remove those and reassemble you should be ok
make sure the drawer is closing properly
Oct 23, 2009 | Amana ABB1927DE Bottom Freezer...
Best height of inside unit of a split AC
which type of mounting is suggested wall or ceiling, if it is suggested that wall mount is nominal then the height is optional, mount it as high as possible. If ceiling mount is suggested then closet to outside wall as possible
Jul 26, 2009 | Friedrich QuietMaster RS10J10 Air...
Bottom working but top fridge barely cool
it sounds like your bottom mount refrig. has a defrost problem. check for heavy frost on the frzr's rear wall. also make sure your frzr fan motor is running.if your fan is running,then check for air flow coming out the air vent in the freshfood compartment. i need a model# to see how your defrost system is controlled.
Jul 15, 2009 | Whirlpool GB2SHDXTS Stainless Steel
The Intertherm AC Model B3BV-030K-A is blowing warm air
If you don’t see any frost on the suction line or big line on the furnace
(that goes from the furnace to the outdoor unit) and the filter and coil are clean then you are probably low on refrigerant.
Apr 14, 2009 | Heating & Cooling
Thru the wall AC units(small)
If the Ac unit can not fit your window, you can put a wall unit, you don’t have to open the wall and mount a stable unit, you just need to buy a portable AC unit put on.
This way cost you not too much.
Jul 09, 2008 | Haier hwr10xc6 Air Conditioner
Window or wall mount
The differance between a window and wall mounted A/C is the mounting system.
Window units are usually smaller BTU systems they set in the window, so you do not have to cut a hole in the wall to install it.
For a bedroom say 10 x 10 you can use @ 5000 btu it plugs into a standard 120 volt electric outlet. If the room is bigger then go bigger say @ 6000 btu or so. Take your room dementions with you when shopping for a unit. sometimes they have sizing on the side of the unit box.
Wall units are usually larger units. Like whole house 18,000 btu
they slide in and out of the case and use a 240 volt seperate circuit.
Best place to shop for A/C's are Home Depot, Lowes, Sams Club, B.J.'s, and Cosco they buy in large volumeusually give a Good deal I've seen 5000 btu units as low as $89.00
Just don't drop the unit out the window when installing it
From the second floor it will void your warranty. LOL
Good Luck Phil
May 19, 2008 | Frigidaire FAC124 wall/Window Air...
LG LS-K2430HL Heat Cool Mini Split Air Conditioner Logo
235 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
