Question about Buck Honda Prelude 1999 Car Stereo/radio Wire/wiring Harness
I am replacing the radio in my '97 chev silverado truck with a after market radio. It comes with a different wiring plug with 12 wires and the present one has 15 and basically the color coded wires do not match, How can I find out which of present wires I need and what function for the color of wire?
    Problem Solver:
  • 10 Answers
Easy fix is to go to a car audio retailer such as best buy an pick up a wire harness adaptor they generally cost 10 to 15 bucks this will save you the hassle of tracing down the wires however general wires are red-power black-ground blue remote amp turn on eight of the wires are for the front and rear speakers thier colors are paired an example would be solid green and then green with a black line these two wires are for one speaker +/- connections you can connect on speaker one at a time and then use the balance and fader control on the radio to check which wire are for front/rear and left/right speakers the factory radio has extra wires which usally control power antena,and dimmer switch for when you turn the headlights on
Posted on Jul 16, 2010
Testimonial: "perfect!"
RADIO HAS NO POWER
It can be faulty radio amp or radio control fuse is blown out.Check voltage at radio wires.You should get 12 volts.
For more help on car radio problems, I suggest you to go through these troubleshooting links, these will help you: -----
Click the link below: ---
Cigarette lighter, Remote central locking, and Radio stopped working
http://whoisbyme.blogspot.in/2012/07/cigarette-lighter-remote-central.html
VW passat radio off safe mode? VW radio CODE?
http://schematicsdiagram.blogspot.in/2012/03/vw-passat-radio-off-safe-mode-vw-radio.html
How to wire new Radio on 1990 Toyota Celica?
http://schematicsdiagram.blogspot.com/2011/12/how-to-wire-new-radio-on-1990-toyota.html
Radio Stereo Wiring Diagram for 1991 Chevy 1500?
http://schematicsdiagram.blogspot.com/2011/12/radio-stereo-wiring-diagram-for-1991.html
How to remove radio on Acura Car models?
http://repairhelpcenter.blogspot.com/2011/11/how-to-remove-radio-on-acura-car-models.html
Where is Radio Fuse located on 2007 Dodge charger?
http://schematicsdiagram.blogspot.com/2011/12/where-is-radio-fuse-located-on-2007.html
How to reset Radio code after car battery is died?
http://howtobyme.blogspot.com/2011/12/how-to-reset-radio-code-after-car.html
Can car radio code block Passkey anti theft system ?
http://schematicsdiagram.blogspot.com/2011/12/can-car-radio-code-block-passkey-anti.html
After Market Stereo wiring for 1999 Chevrolet Silverado 1500?
http://schematicsdiagram.blogspot.com/2011/12/after-market-stereo-wiring-for-1999.html
Chevy car radio doesn't allow to switch to the XM Band to get the radio ID?
http://schematicsdiagram.blogspot.com/2012/01/chevy-car-radio-doesnt-allow-to-switch.html
No power to radio on 2005 Toyota Scion Xb?
http://repairhelpcenter.blogspot.com/2012/01/no-power-to-radio-on-2005-toyota-scion.html
Lexus rx330 Radio has power but no sound?
http://repairhelpcenter.blogspot.com/2012/01/lexus-rx330-radio-has-power-but-no.html
Radio goes ON and OFF while driving?
http://technoanswers.blogspot.com/2012/01/radio-goes-on-and-off-while-driving.html
Lincoln Town Car Radio stereo wiring?
http://technoanswers.blogspot.in/2012/02/lincoln-town-car-radio-stereo-wiring.html
Radio wiring diagram for 1997 Lincoln Town Car?
http://technoanswers.blogspot.in/2012/02/radio-wiring-diagram-for-1997-lincoln.html
How to remove cd player from dash on 2003 Lincoln Aviator
http://technoanswers.blogspot.in/2012/01/how-to-remove-cd-player-from-dash-on.html
These details will help you thanks.
Dec 25, 2012 | 1998 Saturn SL
Stereo
It can be wiring issue.The stereo wiring has to be inspected.
Dec 07, 2012 | 2009 Chevrolet Cobalt
Radio won't work. reset battery and it works until you shut the car off, then won't come back on.
May be it needs complete reprogramming.
To reprogram the radio there is 4 digit code. That code has to be inserted, once these code is inserted, your car radio will get into its actual setting where you can set/select your radio setting.
Many a time's radio asks for the code after car battery is disconnected.
On some cases to retrieve the code its mentioned in manual or else car dealer is other option to get car radio code.
Dec 06, 2012 | 2006 Volvo XC90
2002 saturn lw 300 radio quits
Yes it can be Amp problem,but there are many other possibilities like loose connection,radio wires getting short.
I suggest you to go through the troubleshooting help links related to car radio problems.
Click the link below:-----
Cigarette lighter, Remote central locking, and Radio stopped working http://whoisbyme.blogspot.in/2012/07/cigarette-lighter-remote-central.html
VW passat radio off safe mode? VW radio CODE? http://schematicsdiagram.blogspot.in/2012/03/vw-passat-radio-off-safe-mode-vw-radio.html
Nov 23, 2012 | 2006 Saturn Vue
2007 chev cobalt changed battery now radio doesn't power on at all
For radio related problem, check the radio help links .Click the link below to go through its procedure:----- How to reset Radio code after car battery is died?
------------- Can car radio code block Passkey anti theft system ?
How to wire new car Radio?
Radio Stereo Wiring Diagram?
How to remove radio on Car models?
Where is Radio Fuse located?
----------- After Market Stereo wiring?
No power to radio Scion Xb?
Radio wiring diagram for Car?
How to remove cd player from dash?
This will help.
Thanks.
Feb 28, 2012 | Cars & Trucks
I am attempting to install an after market stereo in my 1997 Lincoln TC. The wiring diagrams I am finding online are not matching the wires (in the dash) from my market stereo? There are two black wires,...
you can go to radio shack or other store and buy a plug adapter for your brand of radio that will match both the radio and the cars wiring so all you have to do is disconnect the factory radio and plug in the adapter to the radio and the original car wiring plug and your set to go without figuring out which wires to connect to and removing the possibility of causing wiring problems with the car
Mar 02, 2011 | 1997 Lincoln Town Car
I need to know what each color means on the existing radio stereo wires please... 1999 chev silverado.
I think this is the right table, but I don't know if it will display right. If not, go to http://www.installdr.com/InstallDocs/GM/PDF/460005.pdf
Typical GM Factory Typical New Radio
Pin What It Is In Dash Wire Color Equivalent Wire Color
A Left Front Spkr (-) Light Gray White w/ Black Stripe
B Left Front Spkr (+) Tan White
C Right Front Spkr (-) Light Green Gray w/ Black Stripe
D Right Front Spkr (+) Dark Green Gray
E Ground Wire Black Black
F Not Used
G Headlight Dimmer Wire Gray Orange (if available)
H Power Antenna Turn On Pink Blue
I +12 Volt Ignition Wire Yellow Red
J +12 Volt Battery Wire Orange Yellow
K Right Rear Spkr (-) Light Blue Purple w/ Black Stripe
L Right Rear Spkr (+) Dark Blue Purple
M Left Rear Spkr (-) Yellow Green w/ Black Stripe
N Left Rear Spkr (+) Brown Green
Sep 06, 2010 | 1999 Chevrolet Silverado 1500
How do i take the radio out of my 2000 silverado
When you remove the radio do not cut the wires. They sell a after market piece that plugs into the factory wiring harness and it in return has the wires cut at the end to splice into the radio. They also have a after market bracket that the after market radio fits into and slides back into the same place as the old one does with the same clip style. Your auto parts store should carry everything you need.
Jun 01, 2010 | Car Audio & Video
Buck Honda Prelude 1999 Car Stereo/radio Wire/wiring Harness Logo
125 people viewed this question
Top Buck Car Audio & Video Experts
xxxxxx xxx
Libran Moreno
Gil Shultz
Are you a Buck Car Audio and Video Expert? Answer questions, earn points and help others
