Question about Kenmore 88752 Top Load Stacked Washer / Dryer
Need timer for washer/dryer model number 88752
    Problem Solver:
  • 13 Answers
That's not a complete model number, but you can find some manuals on the item here:
http://www.managemylife.com/mmh/search_v2?q=88752&content_type=OwnerManual
So, we at least know it's a 11088752, and there's a few variations of what can come after it....
These different models all seem to have different numbers for their timer--both for the washer and dryer timer, since each part of the unit has its own. Look inside the door, you should see the full model number.
With that, you can go to http://www.searspartsdirect.com search for that model and the right parts will show.
Posted on Jul 16, 2010
Dryer won't make heat
I think your heating element is defective and needs to be replaced.
Regards.
Jan 28, 2012 | Kenmore 88752 Top Load Stacked Washer /...
Need Manuel
Go to managemylife.com and enter your model number under the "MANUALS" link. You owner's manual is available in .pdf format and can be downloaded or printed for FREE. If you need further assistance, please post back with your complete MODEL NUMBER and let me know. I hope you find this information helpful.
Oct 08, 2010 | Kenmore 88752 Top Load Stacked Washer /...
Kenmore top load stacked washer/dryer (model number : 110.98575120)
Yes - you are correct.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 03, 2010 | Kenmore 88752 Top Load Stacked Washer /...
Dryer works but washer won't turn on. Washer worked until a few days ago. No warning or events. Just doesn't respond to switch. I can't find a fuse box on the unit itself.
Hi, Have you tried plugging a lamp into the outlet or plugging this into another outlet/extension cord. Check the receptical to see if it is a ground fault style. If it is, push the reset button on it.
If there is power to the washer, there could be a timer issue. UNPLUG the washer. Remove the 2 screws holding the control panel to the cabinet. Some screws are located in front coerners and some in the back corners.
Once the control panel is loose, locate the wire harness on the timer and try wiggling it to get better connection. Plug the washer back in and see if it starts.
Please let me know if this helps or if I can assist you further.
Vic
Jul 10, 2009 | Kenmore 88752 Top Load Stacked Washer /...
How do I remove the Washer Control Knob from a Kenmore compact stack washer dryer?
If you suspect you have a defective timer it can easily be replaced by performing the following steps:
1. Unplug washing machine... and pull out the timer knob. Some knobs have a removeable center cap and hidden screw. Some are simply slip-fit. Remove the knob.
2. Remove console. This can be accomplished in one of two ways depending on which type of console you have.
a. If the console has removable end caps, the caps lift off by prying on the top from the back of the washer.
The cap will pull off towards you as you are facing the unit from the front of the washer.
There will be a screw under each end cap that you will need to remove.
b. If the console does not have removable end caps, you will need to slide a putty knife under the front corner of each side and push in while lifting up.
There is a retaining clip under each side that has to be released.
3. Once the console has been released it will lift up and fold back over the back of the washer in its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
4. Disconnect all power plugs and remove the timer's mounting screws.
5. Reinstall reverse of removal.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 08, 2009 | Kenmore 88752 Top Load Stacked Washer /...
No heat in a Kenmore stackable washer dryer
there should be a small fuse on the heater box,if that is not working the element will not work also-mike
Apr 16, 2009 | Kenmore 88752 Top Load Stacked Washer /...
Dryer stopped working
The dryers drive belt most likely broke. it must be replaced with a new one.
Dec 20, 2008 | Kenmore 88752 Top Load Stacked Washer /...
Dryer won't start
Check and make sure the power is on at the breaker box, or fuses.
Start at the power source.
Jun 05, 2008 | Kenmore 88752 Top Load Stacked Washer /...
Dryer spins but wont heat - element okay
HAVE YOU CHECKED THE MAIN FUSE FOR THE DRYER?WHITE AROUND THE SIDES AND DARK IN MIDDLE,UNSCREW THE KNOB COUNTER CLOCK WISE TO REMOVE KNOB,SHOULD BE 2 SCREWS HOLDING TIMER REMOVE THEM AND THE PANEL SIDE SCREWS,THANKS-MIKE
May 29, 2008 | Kenmore 88732 Top Load Stacked Washer /...
Kenmore 88752 Top Load Stacked Washer / Dryer Logo
95 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
