Question about Hayward SAND FILTER, PRO SERIES
Removing the fingers - Hayward SAND FILTER, PRO SERIES
  • 760 Answers
I'm asuming you're asking how to remove the fingers after the sand is out? Some models just simply unscred from the central hub. Others, fold up to remove. You can download a manual for your exact model from www.hayward.com
Posted on Jul 16, 2010
How do I remove a mini sd card that seems to not want to be removed? seems stuck on a lip.
Most mini sd are removed by pushing in slightly to unlock. Then removed with fingers
Jan 03, 2015 | Tracfone Wireless Alcatel A392G
How to get tdc on by commodore
remove no 1spark plug Place you finger over the plug hole and turn the engine over un til you have pressure under your finger. Remove your finger and use something like a piece of wire and move the piston up until the wire starts to move back down. move the crank back and forward until either way moves the wire . This will be TDC compression /firing stroke.
Aug 01, 2014 | Cars & Trucks
There are icons on my computer that were accidently put on there. the icons I mean are pop ups for computer repair kits and music, ect...
place your finger on the icon, leave it there 'til a menu pops up, or an image of a trash can. With your finger-still on the screen- drag the image on the trash can, remove finger from the screen, solve your problem. If that doesn't work, go into settings and find your shortcuts in the menu and select the removal of the shortcuts you wish to delete. This will not remove them from your device, just put them out of sight.
Sep 04, 2013 | Computers & Internet
Removing finger guard and cleaning ceramic grinder in Saeco product
Before starting, find the parts diagram for the Incanto Deluxe (google search: "incanto deluxe" "parts diagram").
To remove the finger guard, first remove the silicon plug (part number 90 in parts diagram) in the center of the grind adjustment knob by poking an unbent paperclip with a small hook along the silicon plug's edge, twisting 90 degrees and pulling the plug out. Next unscrew the phillips head screw (part number 15) way down in the center of the adjustment knob and remove the knob. Then remove the phillips head screw (part number 120) holding the finger guard to the bean hopper.
I'm not sure how to work on the grinder, but from here at least you should be able to get to it. I suspect that simply removing the finger guard may make things a lot better.
Mar 14, 2012 | Saeco INCANTO DELUXE Espresso Machine
My 1989 buick skyhawlk passenger side window keeps falling its not electric
your window crank mechanism in the door is striped or bent, remove inner door panel and inspect window parts, look in bottom of door for possible parts that may have fallen off. KEEP all fingers clear of moving parts as if the window falls or something you could loose or injure them !!!!!!!!!!!!!!!!! Cant express enough but be careful. I have had cars fall on me, smashed fingers, broken fingers, broken hand, all due to car repairs so believe me when i say a mechanical window mechanism will remove or smash a finger very easily.
Feb 25, 2011 | 1989 Buick Skylark
We tried to rekey our kwikset smart key, but couldn't and now the original key doesn't work
I had mine do the same thing right before I was leaving to the airport [re-keying for the house-sitter]. I was setting the lock and I hear a spring-type ping and the keying was lost.
The tumbler can be reset to your key. However, it involves disassembling the device and has small parts.If you are feeling lucky, you can do this yourself or take it to a qualified person.
If you are feeling lucky:
A: Disassemble the lock from the door
B: Remove the door handle from around the key side.
C: Remove the U retaining-clip from the outside of the lock that is securing it to the shaft.
D: Remove the lock from the shaft
E: Remove the U retaining-clip from the tumbler body and the case
F: You will have to press the five fingers down evenly on the length of the case to slide the cylinder out of the case. (I cut a plastic card with small wire cutters to make a tool, but you could probably use thick card-stock and some scissors.)
Be careful; you will have to watch for and secure the check ball on one side of the tumbler and the finger lock bar on the other side as you slide this out.
G: Remove and store the check ball securely as well as the finger lock bar. (careful with the plate surrounding the fingers that the finger lock bar resides in)
H: Remove the finger locking plate. Carefully, make sure the fingers are still inside and oriented correctly and the spring at the back of the finger locking plate is left in place.
I: You will notice a u channel groove in the fingers and the finger locking plate. Align the fingers in the finger locking plate evenly so that the grooves in the fingers match the groove in the finger locking plate.
J: Replace the finger locking plate with fingers aligned evenly with the u channel groove back onto the tumbler body and hold back against the spring left on the rear of the tumbler body. This puts the tumbler into re-key position.
K: Replace the finger locking bar onto the finger locking plate while holding the assembly against the spring and tumbler body. (If this is done correctly, the finger locking bar will now be flush with the side of the finger locking plate and not raised as normal.)
L: While holding the tumbler assembly together and maintaining the locking plate pressed against the spring, Insert your new key into the tumbler body.
M: While holding this assembly in this position, add the check ball to the tumbler assembly.
N: While holding the assembly in position, slightly depress the black plastic block at the back of the finger locking plate and slide this tumbler assembly back into the tumbler case taking care to rotate the case 90 degrees clockwise from normal. (Note the U channel groove inside the tumbler case that normally receives the finger lock bar and use that for orientation.)
If the tumbler does not insert cleanly, verify the finger locking bar is flush. If it is not, redo while maintaining proper pressure to keep the finger locking plate firmly against the spring in re-assembly. Also, verify the fingers are not protruding from the tumbler body. If they are, redo the procedure taking care to align the fingers properly on assembly and maintain proper force on the finger locking plate against the tumbler body during re-assembly and new key insertion
O: Rotate the key and tumbler body in the case to the normal position (counter-clockwise 90 degrees).
P: While holding the tumbler body firmly against the case, remove the key.
Q: Re-insert the key and verify smooth rotation.
R: Align the tumbler body and case back to the normal position and while holding the tumbler body firmly against the case, remove the key.
S: Replace the U retaining-clip that belongs on the back of the tumbler body to secure it within the case.
T: Replace the tumbler body in the main lock shaft and secure with the shaft U retaining clip.
Mar 24, 2010 | Kwikset Professional Door Lock...
My Dyson will not lock into the stand position
- Stand behind the vacuum cleaner
- Remove the AI PIPE (it has two purple buttons that you push together to lift it up and out - it looks like a Tuba)
- Lay the handle down
- Stick your index finger and middle finger into the vacant AI Pipe Hole (the square hole)
- Reach over with your thumb and press the black button in front of the square hole
- WHilst pushing the black button, lift your index finger and your middle finger and move the gray plastic piece up (lift the square holse basically)
- Remove your fingers from the square hole
- Lift the handle and stand your machine back upright again
- Place the AI Pipe back into the square hole
Jul 16, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
My Dyson DC07 will not stand upright. It just lays in the recline position.
- Stand behind the vacuum cleaner and look at the right-hand side wheel
- Lay the handle down and look for a black button that will be exposed in front of the square hole
- Whilst pushing the black button, lift your index finger and your middle finger and move the gray plastic piece up (lift the square hole basically)
Jul 08, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Fuse box
under the drivers side dash by the door
Aug 27, 2008 | 1988 Ford Crown Victoria
Hayward SAND FILTER, PRO SERIES Logo
53 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
