A washing machine does not work. A Kenmore super capacity 3.5 model # 417.48112701, It is an electronic controlled equipment ,the unit lights the various lamps indicators but does not operate. The indicator over the start button blinks.I noticed that the door lock indicator does not light after the door is closed. Please advise ,Thank You. Rafa
  • 1 more comment
  • Rafael Lopez Jul 16, 2010
    Thank You for the various recommendations I will be inspecting the equipment for these repairs to see if them puts back the unit in service .
    Thank You Rafael
    Thank You Rafael
    Thank You Rafael
  • 6,784 Answers
HI. There are two areas of concern here. The first will be the door locking mechanism. This device, if defective, will shutdown all actions. The main CCU(control Board) monitors the door locking mechanism when the load sequence is initiated. If it cant lock the door, or if the locking mechanism dose not respond(open circuit), it will shutdown the unit. The second area of concern will be the actual main control board module(CCU). This will essentially be the culprit if the door locking mechanism proves to be functional. Follow the below instructions to test the door locking mechanism.
The door switch may be accessible without removing the front panel or cabinet. The switch is located in the front panel of the unit, around the perimeter of the door opening. Inspect the switch to determine if it can be popped out or accessed by removing a fastening screw. If it cannot be accessed from the front, it will be necessary to open the dryer cabinet. When reaching into the unit be careful of sharp edges on the cabinet and interior supports.
Locate the door locking mechanism(on the inside right section of the front panel), it typically has two wires connected to it(yours will have six terminals and two connectors). Label the wires and connections so that you can properly reconnect them later. The wires are connected with slip on connectors. Firmly pull the connectors off of the terminals (do not pull on the wire itself). Inspect the connectors and the terminals for corrosion. If either is corroded they should be cleaned or replaced. Next; Use a multimeter to test for continuity. Set the meter to the ohms setting X1. For a six terminal wire switch, touch one probe to each terminal. You should get a reading of infinity. With the probes still in place, press and hold the switch, the reading should change to zero.
If the switch does not test as described, it should be replaced but if the switch passes the test, replace the main control module.
Posted on Jul 16, 2010
  • Michael Masters
    Michael Masters Jul 16, 2010
    Here is a link to an exploded diagram of the cabinet. The part that you will need to test will be labeled number 8 on the diagram provided.
  • Michael Masters
    NOTE_ I have posted a picture below of the door locking mechanism. You will only need to test the wax motor terminals. There are two terminals. Use the same procedure above to test.
Trying to figure out the washer capacity for model # 22622 100 from around 2002 or so
suggest you check with the manufacturer's website . model numbers do nothing for us
Aug 30, 2017 | Washing Machines
Kenmore washer 3.5 super capacity. Machine spins
It sounds like your tub bearing is bad or going bad. It could be the adjustment on your spin cycle. Does your unit allow you to adjust this. Also are you overloading. Can you send me the brand and model of your unit and I help you more.
JimmyC
Oct 05, 2009 | Kenmore 3.5 cu. ft. Front Load Electric...
Front loading washer won't spin
my amana washer wont spin and does not drain
Sep 11, 2009 | Kenmore Washing Machines
Flooded Kenmore Super Capacity Washer & Dryer
It appears your motor/motor controller has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 12, 2009 | Kenmore 3.2 cu. ft. Top Load Washer
Won't fill w/ water, Kenmore 3.5 Super Capacity Front Loader
The pressure switch is likely to blame. Change it.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 28, 2009 | Kenmore 3.5 cu. ft. Front Load Electric...
What is the capacity of my Kenmore washer?
3.2cu ft.
May 26, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Washing machine suddenly stopped working during cycle
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
Jan 01, 2009 | Kenmore 3.5 cu. ft. Front Load Electric...
WHAT IS THE LOAD CAPCITY SIZE OF WASHER MODEL 110.20702990
On newer, and sometimes a little newer, Whirlpool and Kenmore (Kenmore is made by Whirlpool) considers a few things in determing capacity. Most of the inner baskets are the same size, but they also add in agitator action into the mix. A Kenmore with an auger top agitator would have higher capacity than a Kenmore with just a normal agitator, even though it has the same sized drum. So a super capacity washer would have theoretically less CLEANING CAPACITY than a super capacity plus. The agitator action is actually what determines capacity on these models. So, with that in mind, cubic load should be about the same on both units. Sorry that I had to go into "Bill Nye The Washer Guy" mode, but thats about the only way to describe. Let me know if I can confuse you any more haha. Seriously though, if you need further help or info, write back, and will try to get you some other information. Remember, this theory only works on top load "normal people" washers, not the front loaders.
Nov 22, 2007 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Washing Machines Logo
161 people viewed this question
Top Washing Machines Experts
