Question about Cameras
I have a Canon ZR200 digital video camcoeder and there are lines that show up on my recordings. I have cleaned the heads 3 times and it has not helped. I have seen someone post that maybe the the video assembly could be replaced. Where is that and how easy is it to replace?
  • 3,083 Answers
I know of no such designated part being "the video assembly", but I'm sure they were referring to the whole video cartridge assembly, which would probably be expensive to fix, even if you fix it yourself. If the heads are clean, the lines are probably caused by a slightly loose ribbon connector that connects to the main control board. This is not an easy fix, since the unit has to be disassembled to get at the connector. If you're a pretty mechanically inclined person, you might be able to do it yourself. If you decide to have some else service it, tell them the symptoms, and get an estimate first, since the cost of repair can be quite high.
Posted on Jul 16, 2010
My playback video jumps after recording on tape also audio lever rises and fall i does not have this problem when record on the memory card i have a canon Zr camcorder
I have seen this problem many times, the recorder unit needs to be replaced, either something in the tape path has become out of alignment or dirty like a capstan motor or gears or the video head assy is defective. I hope this helps.
Sep 04, 2010 | Canon ZR200 Mini DV Digital Camcorder
Recording playback has lines through it.
try with head cleaner tape 2 or 3 times mostly it works if not change video head assembly
May 24, 2010 | Canon ZR200 Mini DV Digital Camcorder
I have gray lines on my Canon video camera display - on tape and playback. It happens on playback to the TV as well. Other tapes have it on display also. Thoughts?
Its sign of clogged/ dirty video head in your camcorder, put Video Head Cleaning tape in camcorder to clean video heads, problem will be solved.
MiniDV Video Head Cleaning Tape is available in stores.
Thanks.
Dec 04, 2009 | Canon ZR200 Mini DV Digital Camcorder
Canon zr200
The heads are dirty, purchase a soft head cleaning tape and run it for 25 secs.
Dec 26, 2008 | Canon ZR-950 Mini DV Camcorder
Gray lines across video screen during playback
my canon zr 200 in playback is fine but when i turn it on to record i have multi colored bars on screen and wont record
Jan 06, 2008 | Canon ZR200 Mini DV Digital Camcorder
Canon ZR200
Hey,
I just started to have the same problem, 5 grey lines and intermittent audio. I the settings and i tried different tapes and No Joy. Then I tried to record onto an old tapes to see if the new recording would do it and the camera showed me a strange icon for exposure. I set the exposure back to 'Easy' and Viola, I recorded and the playback is now clean. Even old tapes play OK now...
The settings must have gotten wacked somehow. I glad it worked out, good luck.
Oct 06, 2007 | Canon ZR400 Mini DV Digital Camcorder
Gray Lines
What do you mean by "Its only when i go to record or view previous recording"? in what situation doesn't it show the gray lines? What about the viewfinder? do you get lines there aswell? If you don't see the gray lines when you transfer the video out of the camera, then you don't have a head problem, a screen problem maybe. Don't hurry to use cleaner tapes because they can hurt the head, the actual cleaning procedure is one that scrapes the head and leaves some damage. more info please
Jun 10, 2006 | Canon ZR200 Mini DV Digital Camcorder
Lines in replay
Digital video camcorder are recording signals in very thin line (as thin as 1/8 of a hair.) Therefore, following symptoms may appear if video heads become dirty even a little. If such symptoms appear, clean the video heads with a commercially available dry cleaning cassette. If the symptoms reappear shortly after cleaning, the video cassette may be defective. Stop using the cassette. Video heads may become dirty under the following conditions: (1) When using the camcorder in humid or hot places. (2) When using cassette with damaged or dirty tape. (3) When using the camcorder in dusty places. (4) When using the video heads without cleaning them for a long time. Note: Before you make important recording, clean the video heads and make a test recording first. We also recommend cleaning the video heads after use before storing the camcorder.
Sep 04, 2005 | Canon GL2 Mini DV Digital Camcorder
Cameras Logo
14 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
