I have an exclamation mark next to my PCIC or PCMCIA controller in my system harware setup. It looks like i have an incompatible driver error. where can i get the correct driver for my old Tosh 4090cds laptop windows 98, please?
    Problem Solver:
  • 95 Answers
Have you tried the toshiba website or driverguide.com
Posted on Apr 20, 2008
Provider entry msafd tcpip could not perform simple loopback communication error 10050
click start control panel administrative tools computer management then select event viewer depending on what operating system you have this may vary
extend the events there you will ((see errors in red)) you will no what exactly what the error was and at what time it occured
you might be able work your way through the problem
you will have to open up your network connections click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ? you will need to update or install the driver or it could be firewalled or
you could click start control panel administration tools computer management device manager look for network adapters + expand Ethernet driver if you see a yellow question exclamation mark or a red X you will need to update/reinstall the driver for the device if you computer came with a motherboard disk the driver could be on it
hope this helps
Nov 19, 2011 | Microsoft Windows XP Professional
Computer does not see cd wp system
you might have to physically unplug the plug you cd rom back in this should activate the found new harware wizard or you might try
make sure that the cd rom is getting enough power test all leads that are attached to the cd rom including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd rom then plug them back in this will activate found new hardware wizard or
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives you might see a yellow question mark ? right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
Nov 23, 2010 | Sony CRX320EE CD-RW/DVD-ROM Combo Drive
This dvd writer can read and write dvd, cannot read and burn cd
control panel admistrive tools,computer management,device manager scroll cd/dvd rom drives right click you can update driver disable or uninstall select properties from there you can troubleshoot or select driver you can update roll back driver uninstall if at any time you see a yellow question mark? you need to install a driver
or it might be a registry problem you did mention if you could see this dvd burner in windows explorer
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Nov 17, 2010 | LG GH22LP20 DVDRAM Burner
My computer sound is not working
first off, is the driver properly installed?
To verify this, go to
(Windowx XP\Vista\7)
Control Panel
System
Device Manager\hardware
Sound and Video Controllers
Look for yellow exclamation mark, or a red x under the sound and video game options
if you see either marks, right click on the device in question and look for 'update driver', or enable device.
If there are no marks (yellow exclamation, or red x) then the sound card is likely installed and is just muted.
look in the system tray for a speaker icon, right click on it, look for a unmute option, or trey raising the volume
Nov 08, 2010 | Computers & Internet
MY COMPUTER IS NOT SHOWING THE CD DRIVER. HOW CAN I EXPLORE THE FILES OF MY CD?
you might have to physically unplug then plug back in this should activate the found new harware wizard or
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Nov 05, 2010 | Sony CRX320EE CD-RW/DVD-ROM Combo Drive
There is no sound on my computer Pavilion Deskjet
Goto control panel, system, harware, device manager and see if there is an exclamation mark next to sound device
Aug 09, 2010 | Computers & Internet
HL-DT-ST DVD +-RW GSA-H21N ATA Device is not working gives a code 10....tried for new drivers was all updated..tried to uninstall and reboot then reinstall nada. This is a acer comp.
Right click on “Computer” or “My Computer” in XP. Select Manage and then on the right side select device manager. On the left if you see a yellow exclamation mark next to your drive and were getting any of the above error codes then we have a simple fix.
Go ahead and right click on the CD or DVD drive that has a yellow exclamation mark next to it and select delete or remove.
try to search:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control
\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Now that you are at the {4D36E965-E325-11CE-BFC1-08002BE10318} Folder on the right side you will see several entries. right Click and delete the Upperfilters and Lowerfilters. These will be remade once you reboot.
This will try to look for the drivers again..
Jul 12, 2009 | Acer Computers & Internet
Yes, there are three yellow question marks NEXT TO EACH STATED BELOW 1.?other devices 2.?ethernet controller 3.?mulitimedia audio controller
Ok that means you need a driver for each of those. You will either have to go to the manufacture website (ex. dell.com) or the motherboard manufacture (if you built it yourself) look up the correct model pc/motherboard and download the drivers for each item (ethernet, multimedia controler). After you run each of the downloads either it will remove the exclamation mark or if not you can right click the item with exclamation and hit "update driver" and click next through all the menus and it should install.
May 28, 2009 | Dell (8H390) Sound Card
USB Ports Not working
you need to go to device manager and look in the list at the bottom for the usb root hub and see if there are any red crosses or exclamation marks, red crosses mean device dissabled, exclamation means not recognised and no suitable driver. click on the link below and select motherboard downloads for the usb drivers http://support.gateway.com/support/drivers/search.asp?param=usb&st=kw If you do find that the motherboard is faulty, then you can purchase a PCMCIA USB 2.0 card, as long as your notebook has the PCMCIA slot, as i am sure it has.
Jul 03, 2007 | Gateway 4540GZ Notebook
Dwl-g650 wirless card
you have the driver instaled for the card, but is the cardbus controller installed, go to device manager and look at pcmcia line and see if controller is there, or whether there is an exclamation mark on other unknown devices. You will need to go to the compaq site and identify the driver for the pcmcia controller
May 14, 2007 | D-Link Wireless CardBus NIC 802.11G [...
Open Questions:
We provide best team support to all Toshiba users active for 24*7 hrs. Call us +1888784-9316 With 24x7 major subsidiaries and affiliates worldwide, Toshiba Corporation is known as a world class innovator and global high technology product leader worldwide. Toshibha launched laptop computers from its kitty way back in 1985 and by Financial Year 2010 they have managed cumulative shipment of more than 100 million Laptops. Toshiba has been known to set benchmarks when it comes to quality and features that results in exceptionally high performance. In spite of the exceptional features you may experience issues related to data recovery, backup and security and may be deprived of any support by the Toshiba Support. In the event of an OS Crash there is always a chance that you may Toshiba Support your critical data. Virus attack or accidental data deletion are also some of the other reasons that could cause mess. An updated backup will warrant that you do not lose your critical data forever. DataAlign comes to you rescue in these situations. DataAlign offers comprehensive technical assistance for your computer's data backup, recovery and security. DataAlign lets you schedule backups to execute daily, weekly or monthly. Our award winning cloud backup Toshiba Customer Service lets you schedule your backups continuously throughout the day. Data Align gives you affordable services that saves you both time and money and that lets you take control of other important things in life like growing your business or spending time with near ones. TOSHIBA is known for its diversified product range and services worldwide. Still, there are several issues that a TOSHIBA user can face on the TOSHIBA computer. Problems faced by TOSHIBA customers BIOS update Toshiba Backup Slow Performance Windows 10 upgrade Data Backup and Transfer Office and outlook setup Wifi and Internet Issues Audio & Video Issues Startup and Boot problems Windows updates Computer Tune-up Issues Virus Removal Issues Our highly talented and expert IT Team can help you fix most of the issues that you face with Toshiba Virus . And the best thing is that we can help you get your data backed up on our secure cloud storage. Why Our Toshiba Help Desk Number Technical Support Team Are Best? With several years of experience in our kitty working with a wide variety of customer group, we have gained an edge when it comes to providing technical support for TOSHIBA Computers. To add to it, our expert technicians trained specifically on TOSHIBA computers are always ready to help you best possible solution for any issue that you may face with your TOSHIBA product. 24X7 availability and assistance for your TOSHIBA computer. We have a dedicated & experienced support team to handle issues for your TOSHIBA computer We ensure little to no downtime with maximum uptime and highest productivity for your TOSHIBA Computer. We ensure Data backup and retrieval assistance We ensure end to end ownership & solution for issues you face with your TOSHIBA computer. Quick and efficient support over the remote. You can sit back & relax while one of our techs fix the issue for you. All these issues and many more, concerning Toshiba users are directly and efficiently resolved by our technically knowledgeable team who can be Reached 24/7 on our Toshiba Contact +1 888 784-9316.
Apr 27, 2018 | Toshiba Computers & Internet
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
