Question about Maytag Kitchen Ranges
Maytag oven is not heating up - but stove burners work fine
Hello
I have had a Maytag MGR5765QDW Gas Range since 2004. Just today, I went to preheat the oven to cook a dish and the oven would not heat up at all. I cancelled and tried again a few times and nothing happened.
The range burners are working just fine. Any help/guidance is greatly appreciated.
Regards
Ed Sleeper
Bridgewater NJ
SOURCE: Amana gas range ARGS7650 oven not working, stove top working
check clock has not accidently been switched to Auto this can also happen if someone has interupted the power supply
Posted on Dec 26, 2007
aborcass
  • 2651 Answers
SOURCE: oven doesn't heat
sounds like you have a bad oven ignitor, although oyu see it glowing orange its not hot enought hoopen the gas valve, very common occorance. 2 maybe 4 screws and 2 wires, order aand replace the bake ignitor
Posted on Mar 26, 2008
SOURCE: I have a maytag stove
I have a Maytag stove Model #MER5875QCW The problem is it
Takes for ever for the stove to reach 350c Can anything be done?
Posted on May 24, 2008
shinn8
  • 85 Answers
SOURCE: maytog gas oven model 5765QDB--oven will not heat up
Sounds like your oven igniter is bad.
Part number is 74007498
Posted on May 18, 2009
  • 8 Answers
SOURCE: My Gas stove takes over an hour to preheat sometimes.
Would be helpful to know brand and model. However, most gas ovens use a glowbar mechanism that regulates the amount of gas released into the oven. The glowbar also ignites the gas (and usually stays on all the time the oven is on). Often, the glowbar fails to heat up sufficiently and, as a result, doesn't allow the oven to release sufficient gas. If this happens, you may also smell small amounts of gas in the kitchen. The glowbar is hot enough to ignite the limited amount of gas being released into the oven. This is probably why the oven heats up but heats up very slowly. It's also possible that the heat being experienced in the oven is being generated from the glowbar itself without any gas being ignited. If this is the case however, it is unlikely that your oven to get very hot at all.
The way to test to see if they glowbar is failing is to test the amperage traveling to the glowbar when the oven is on. You can do this using a "clamp on meter" (purchased at any Home Depot or Lowes). Depending on the particular kind of glowbar you have, it should read above a certain amperage (in my case the reading was 2.7 amps and it should have been between 3.2 and 3.7 amps). I ordered a new glowbar from www.appliancepartspro.com and installed it myself (very easy). It fixed the problem. Here is a link that explains it pretty well (http://www.appliance411.com/faq/gas_range_ignition_systems.shtml#glow). Hope this helps.
Posted on Jul 25, 2009
I have a maytag gas stove model mgr5720adh When I use the oven during the preheat is fine it does take longer to preheat but when it maintaining the temp I start smelling gas.
Change the igniter the igniter is not getting hot enough to open the safety valve and what it does there's not enough heat on the igniter to ignite the flame of the burner
Jan 17, 2017 | Maytag Kitchen Ranges
I have a Maytag gas stove model MGR5730BDW. The oven won't light. The broiler works just fine. The bottom ingiter glows orange and gets hot but the burner won't light.
Hello, Thank You for using FixYa. I will be helping you today.Just because the ignitor glows does not mean its good..switch the two around and see if the oven comes on. They still glow even when they start to go bad.
Thank You and please rate my answer if it was helpful..
Jun 16, 2011 | Maytag 30" Self-Cleaning Freestanding Gas...
I noticed my oven was taking longer and longer to reach the preheat temperatures I was setting. As time went on, the stove was not heating up past 285 and now the temperature never increases but I can...
It is probably as simple as changing the ignitor...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
Aug 16, 2010 | Maytag MGR5770 Gas Kitchen Range
Oven won't heat, display out, gas burners on stove
Hello, you will probably need to pull it out and put it on something. Make sure the breaker is off to it before you test it. There is a thermostat in the very back that could be bad,check for continuity on that. Also check for continuity on the bake and broil element terminals itself,even though you have checked it to ground. If those check good,then the problems is in the control board.
Thanks
May 31, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Oven appears to start, takes forever to preheat,
This is what I would do: I would unplug the range and connect my test cord to your range cord. I use an ammeter along with my test cord to read the amp draw of the bake ignitor. If it cannot get above 3.5 amps I know the ignitor is bad or weak. Since the oven is working that means there is a good circuit. In order for the safety bi-metal to open the amp draw must reach 3.5 amps or better. So to me I am thinking bad ignitor. To get to it I remove the door oven racks and bottom, I then remove the flame spreader and unplug the quick connect to the ignitor. I remove the burner and ignitor and replace the ignitor on a work bench. I am too old to be bending over and trying to do any parts replacement inside an oven. LOL. I have a training film which shows how the silicone carbide ignitor works HERE. Post a model number and I may have a service manual, do not forget to rate the answer.
Feb 26, 2010 | Kenmore 30172 / 30174 / 30179 Gas Single...
Xl44 oven burner pulses, doesnt properly heat up.
it seems the burner in the oven is clogged, by grease, carbon or corrosion, it may need replacing, specialy if this is an older unit
Jul 30, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Kenmore Propane Range won't bake
The glow plug underneath the over floor need to be replaced
Dec 19, 2008 | Kenmore 36665 / 36669 Gas Kitchen Range
Bottom oven does not heat
i ceertainly think that there is problem with the burner. as per the working principle of an Oven the ignitor is doin its job so the problem is with the burner please do check it out...
Nov 25, 2008 | Maytag MGR6772 Gemini Gas Kitchen Range
MAYTAG GAS RANGE MODEL # MGR5765QDW
sounds like a bad bake ignitor, common issue with all gas stoves.
Nov 05, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Ranges Logo
324 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
